November 27, 2024, 09:46:17 21:46
Author Topic: extern "C" Question  (Read 5968 times)
LzEn
-Given: 48
-Receive: 86
Lazy Efficient
« on: October 21, 2014, 08:53:35 08:53 »
After spending 2 days trying to figure out why my STM32L1 EXTI is not branching to my IRQHandler, I found out the problem. First I will state I am new to the ARM architecture, and probably my first time writing C++ code for MCUs.
So back to the problem, it turned out that there was a linker problem. I added an ' extern "C" ' in front of the IRQHandler and now it works normally.
Can someone please explain to me in some basic language what did this 'extern "C"' do exactly. Why C++ could not link the functions together.
extern "C" void EXTI0_IRQHandler(void)
     if (EXTI->PR & (1<<0))
        EXTI->PR |= (1<<0);
        Led1.Set();
extern "C" void EXTI9_5_IRQHandler(void)
if (EXTI->PR & (1<<6))
                EXTI->PR |= (1<<6);
Led1.Toggle();
Thanks.
hate
-Given: 156
-Receive: 355
« Reply #1 on: October 21, 2014, 10:04:21 10:04 »
In brief, C++ compiler adds extra information to function headers i.e. class information to distinguish functions of different classes with the same name. C compiler doesn't normally add anything to the headers as there is normally nothing needed. Adding 'extern C' takes care of that issue basically. It tells the C++ compiler not to mangle the function header so external C code can be linked successfully.
Edit: Using 'extern C' on interrupt handlers doesn't seem right, I believe the compiler should take care of that. Have you checked other examples on interrupt syntax?
« Last Edit: October 21, 2014, 10:14:07 10:14 by hate » Logged
Regards...
LzEn
-Given: 48
-Receive: 86
Lazy Efficient
« Reply #2 on: October 21, 2014, 10:31:46 10:31 »
Ahh makes sense, thanks for the clear answer and right to the point.
After I found the problem, I read in many places of people having the same problem and it was fixed with the extern C. I didn't try a C code yet, but I tried many different codes. I am actually writing to the registers directly now, so I don't think the problem can be elsewhere. But I will check again, with some example code.
That is what I am doing exactly, the code is just for testing so it is not in its best shape :
//MCU : STM32L151
//The user will pass pin and port enumeration that I created. On my turn I will enable the corresponding Interrupt.
// The user will also pass an Edge for the interrupt.
RCC->APB2ENR |=  (1ul << 0);                   // Enable SYSCFG clock
SYSCFG->EXTICR[registerIndex] &= ~(15ul      << 4* (pinIndex %4));    //pinIndex is an enumaration on Pins I created
SYSCFG->EXTICR[registerIndex] |=  (portIndex << 4* (pinIndex %4));
EXTI->IMR |= (1ul << pinIndex);
switch(edgeLevel)
case FALLING_EDGE:
       EXTI->RTSR |= (1ul << pinIndex);
break;
case RISING_EDGE:
EXTI->FTSR |= (1ul << pinIndex);
break;
case BOTH_EDGES:
break;
if(pinIndex == 0)
    NVIC_SetPriority(EXTI0_IRQn,priority);
    NVIC_EnableIRQ(EXTI0_IRQn);
else if (pinIndex ==1)
NVIC_SetPriority(EXTI1_IRQn,priority);
NVIC_EnableIRQ(EXTI1_IRQn);
else if(pinIndex ==2)
NVIC_SetPriority(EXTI2_IRQn,priority);
NVIC_EnableIRQ(EXTI2_IRQn);
else if(pinIndex ==3)
NVIC_SetPriority(EXTI3_IRQn,priority);
NVIC_EnableIRQ(EXTI3_IRQn);
else if(pinIndex ==4)
NVIC_SetPriority(EXTI4_IRQn,priority);
NVIC_EnableIRQ(EXTI4_IRQn);
else if(pinIndex >4 && pinIndex <=9 )
NVIC_SetPriority(EXTI9_5_IRQn,priority);
NVIC_EnableIRQ(EXTI9_5_IRQn);
else if(pinIndex >9 && pinIndex <=15 )
NVIC_SetPriority(EXTI15_10_IRQn,priority);
NVIC_EnableIRQ(EXTI15_10_IRQn);
Here are the enumerations, nothing special:
typedef enum PINn
PIN0,
PIN1,
PIN2,
PIN3,
PIN4,
PIN5,
PIN6,
PIN7,
PIN8,
PIN9,
PIN10,
PIN11,
PIN12,
PIN13,
PIN14,
PIN15,
}PINn_Type;
typedef enum PORTn
  PORTA,
  PORTB,
  PORTC,
  PORTD,
  PORTE
}PORTn_Type;
hate
-Given: 156
-Receive: 355
« Reply #3 on: October 21, 2014, 10:57:12 10:57 »
I checked the links below and it seems using 'extern C' on interrupt handlers is the official way of doing things. Although seems strange, quite logical.
http://embdev.net/topic/191474
http://processors.wiki.ti.com/index.php/Invoke_a_C%2B%2B_Class_Member_Function_from_an_Interrupt
Sorry for the trouble, it's my lack of C++ experience with microcontrollers.
Regards...
LzEn
-Given: 48
-Receive: 86
Lazy Efficient
« Reply #4 on: October 21, 2014, 11:48:27 11:48 »
No trouble at all, on the contrary. I was looking for some solid link about it, the one you provided from TI should do the trick.
Thanks again, helped a lot.
nPn
« Reply #5 on: October 25, 2014, 01:57:18 01:57 »
For future reference, "nm" utility in GNU tools lets you see symbols contained in binary objects, which helps when debugging this kind of thing.
In ARM I'd do "arm-none-eabi-nm main.o" to see symbols contained and referenced in file main.o.
And I should see "00000000 T Start" for Start symbol in T (.text section). If you have C++ symbols it looks like "00000000 T _ZN3Foo5StartEv" so if you pipe into arm-none-eabi-c++filt you get "Foo::Start()." Of course if object from C file reference _ZN3Foo5StartEv it won't work so you use extern "C" to make it C linkage and match reference.
ficho
« Reply #6 on: September 23, 2016, 08:43:47 08:43 »
HI,
It depends also witch compiler you are using, try to find compilers manual.
Lot of things are explained in it...
regards ficho
bobcat1
-Given: 4285
-Receive: 94
« Reply #7 on: September 25, 2016, 08:02:46 08:02 »
The best way is NOT to use EXTERN to access variable or function in your code
It will save lot of bugs and debugging time
I always use module functions to access variables or structure with in the code
