April 27, 2025, 01:11:26 01:11
Author Topic: Advanced JPEG Compressor 5.0  (Read 4309 times)
hacbit
-Given: 21
-Receive: 35
« on: October 20, 2007, 04:39:45 16:39 »
This program allows you to convert images to JPEG format using the most powerful JPEG compression engine, shrink the large file size of your graphic files, optimize pictures for quickly loading from the Web, e-mail smaller image files faster and not exceeding email size limitations, resize images and make thumbnails.
This program works as dedicated JPEG converter, allowing you to open existing images in many formats (BMP, TIFF, GIF, PNG, ...), and a JPEG optimizer, compressing existing JPG images.
The possibility to create, edit and apply named compression profiles considerably helps in processing various types of graphic files. The Batch Processing function makes it easy to process multiple images applying the selected compression profile.
Graphic Detail Quality Equalizer is a unique feature of the program that gives you significant flexibility in adjusting the compressed image quality.
http://rapidshare.com/files/60708248/BrUnA.Advanced.JPEG.Compressor.v5.0.Cracked.rar
