November 25, 2024, 05:00:51 05:00
Author Topic: Exemple on dspic with hitech dspic compiler  (Read 5018 times)
Yazi
-Receive: 23
« on: December 29, 2005, 09:26:29 09:26 »
//this exemples are tested on the hard with dspic30f2010 it work fine
//using timer1
#include
#include
#define PLL_VALUE 8.0
#define CLOCK_TICKS 4000000
#define TCY_PER_SECOND (PLL_VALUE*CLOCK_TICKS/4.0)
#define PRE_SCALE 256.0
void setupTimer1(float timeInS)
unsigned long period;
period=(unsigned long)(timeInS*TCY_PER_SECOND/PRE_SCALE)-1;
SetPriorityIntT1(3);
EnableIntT1;
OpenTimer1(T1_ON & T1_GATE_OFF & T1_IDLE_STOP & T1_PS_1_256 & T1_SYNC_EXT_OFF & T1_SOURCE_INT,period);
void interrupt tc_int(void) @ T1_VCTR
T1IF=0;
WriteTimer1(0);
LATE++;
int main(void)
TRISE=0;
setupTimer1(1.0); // argument is interval (in seconds) between interrupts
while(1);
//e using timer2
#include
#include
#define CLOCK_TICKS 4000000 //External 4Mhz cristal
void setupTimer2(float timeInS)
SetPriorityIntT2(1);
EnableIntT2;
OpenTimer2(T2_ON & T2_GATE_OFF & T2_IDLE_STOP & T2_PS_1_256 & T2_SOURCE_INT &T2_32BIT_MODE_OFF,period);
void interrupt tc_int(void) @ T2_VCTR
T2IF=0;
WriteTimer2(0);
LATE++;
int main(void)
TRISE=0;
setupTimer2(1.0); // argument is interval (in seconds) between interrupts
while(1);
//if you tray with Setuptimer2(3.0) you have only 0.902816 second as interval betwin interrupt
//because periode =((3*4000000*Cool/4*256)-1 =16E35 the PR2 is only 16bits he take only 6E35=28213
//calcul interval betwin interrupt= (PLL_VALUE*CLOCK_TICKS/4.0*PRE_SCALE)/28213= 902.816ms
//Simulation under MPLAB give 902.942125 ms
// exemple 3 timer 2and 3 as 32 bits timer mode with dspic compiler
#include
#include
void setupTimer23(float timeInS)
SetPriorityIntT2(3);
EnableIntT3;
OpenTimer23(T2_ON & T2_GATE_OFF & T2_IDLE_STOP & T2_PS_1_256 & T2_SOURCE_INT &T2_32BIT_MODE_ON,period);
void interrupt tc_int(void) @ T3_VCTR
T3IF=0;
WriteTimer23(0);
LATE++;
int main(void)
TRISE=0;
setupTimer23(1); // argument is interval (in seconds) between interrupts
while(1);
//with 32bit timer the interval betwin interrupts can go to 137438.95 sec (near 38 hours)Wink
« Last Edit: December 29, 2005, 09:27:48 09:27 by Yazi » Logged
