April 29, 2025, 01:44:17 13:44
Author Topic: i need nokia 3310 CCS C driver  (Read 18359 times)
hunter07
-Given: 19
« on: December 29, 2005, 09:04:23 09:04 »
Could you help?
lanyong
« Reply #1 on: January 02, 2006, 09:22:22 09:22 »
ccs c drive 3310?
the 3310 was compiled by ccs c?
bayramonur
« Reply #2 on: January 02, 2006, 09:42:17 09:42 »
Librarys:
http://rapidshare.de/files/10243056/3310_lcd.zip.html
Samples:
http://www.techdesign.be/projects/009/009.htm
http://www.techdesign.be/projects/011/011.htm
lanyong
« Reply #3 on: January 02, 2006, 10:51:48 10:51 »
O , I Think That Is A Cell Phone.
It Is A Lcd.
nyoknyok
« Reply #4 on: February 20, 2006, 10:12:00 10:12 »
Hi everyone,
I work with nokia 3310 lcd which I downloaded with this site http://rapidshare.de/files/10243056/3310_lcd.zip.html but i wont work for me. I use the PIC16F873 microcontroller.  Any help will be appreciated, I also attached my program so that you can review it.
  Thank you..
     nyoknyok
smainj
-Given: 70
-Receive: 75
« Reply #5 on: July 28, 2007, 02:20:00 14:20 »
http://rapidshare.de/files/10243056/3310_lcd.zip.html ==> file not found
please upload it. thanks
sinmax
« Reply #6 on: August 17, 2007, 04:14:14 04:14 »
I can help u,
email to [email protected]
stam
« Reply #7 on: November 24, 2007, 08:54:22 20:54 »
Does anyone now if there is an other nokia phone with the same lcd? I have an old 7110 but it doesnt seem the same...
Thank u Smiley
fagari
-Receive: 41
« Reply #8 on: November 25, 2007, 08:15:21 08:15 »
Sample Source Code :
Graphic LCD Nokia 3310 (LPH7779) routines v3
CCS compiler
by Michel Bavin 2004 --- [email protected] --- http://users.skynet.be/bk317494/ ---
august 29, 2004
// ex:
// nokia_init();
// nokia_gotoxy(0,0);
// printf(nokia_printchar,"test???");
#define nok_sclk  PIN_D4
#define nok_sda   PIN_D3
#define nok_dc    PIN_D2
#define nok_cs    PIN_D1
#define nok_res   PIN_D0
char char_row,charsel,charpos,chardata;       // for nokia_3310 lcd
int16 ddram;
char plot_value;
int32 plot_value32;
int32 plot_umsb,plot_lmsb,plot_ulsb,plot_llsb;
BYTE const TABLE5[240]=            {0x00,0x00,0x00,0x00,0x00,   // 20 space          ASCII table for NOKIA LCD: 96 rows * 5 bytes= 480 bytes
  0x00,0x00,0x5f,0x00,0x00,   // 21 !
  0x00,0x07,0x00,0x07,0x00,   // 22 "
  0x14,0x7f,0x14,0x7f,0x14,   // 23 #
  0x24,0x2a,0x7f,0x2a,0x12,   // 24 $
  0x23,0x13,0x08,0x64,0x62,   // 25 %
  0x36,0x49,0x55,0x22,0x50,   // 26 &
  0x00,0x05,0x03,0x00,0x00,   // 27 '
  0x00,0x1c,0x22,0x41,0x00,   // 28 (
  0x00,0x41,0x22,0x1c,0x00,   // 29 )
  0x14,0x08,0x3e,0x08,0x14,   // 2a *
  0x08,0x08,0x3e,0x08,0x08,   // 2b +
  0x00,0x50,0x30,0x00,0x00,   // 2c ,
  0x08,0x08,0x08,0x08,0x08,   // 2d -
  0x00,0x60,0x60,0x00,0x00,   // 2e .
  0x20,0x10,0x08,0x04,0x02,   // 2f /
  0x3e,0x51,0x49,0x45,0x3e,   // 30 0
  0x00,0x42,0x7f,0x40,0x00,   // 31 1
  0x42,0x61,0x51,0x49,0x46,   // 32 2
  0x21,0x41,0x45,0x4b,0x31,   // 33 3
  0x18,0x14,0x12,0x7f,0x10,   // 34 4
  0x27,0x45,0x45,0x45,0x39,   // 35 5
  0x3c,0x4a,0x49,0x49,0x30,   // 36 6
  0x01,0x71,0x09,0x05,0x03,   // 37 7
  0x36,0x49,0x49,0x49,0x36,   // 38 8
  0x06,0x49,0x49,0x29,0x1e,   // 39 9
  0x00,0x36,0x36,0x00,0x00,   // 3a :
  0x00,0x56,0x36,0x00,0x00,   // 3b ;
  0x08,0x14,0x22,0x41,0x00,   // 3c <
  0x14,0x14,0x14,0x14,0x14,   // 3d =
  0x00,0x41,0x22,0x14,0x08,   // 3e >
  0x02,0x01,0x51,0x09,0x06,   // 3f ?
  0x32,0x49,0x79,0x41,0x3e,   // 40 @
  0x7e,0x11,0x11,0x11,0x7e,   // 41 A
  0x7f,0x49,0x49,0x49,0x36,   // 42 B
  0x3e,0x41,0x41,0x41,0x22,   // 43 C
  0x7f,0x41,0x41,0x22,0x1c,   // 44 D
  0x7f,0x49,0x49,0x49,0x41,   // 45 E
  0x7f,0x09,0x09,0x09,0x01,   // 46 F
  0x3e,0x41,0x49,0x49,0x7a,   // 47 G
  0x7f,0x08,0x08,0x08,0x7f,   // 48 H
  0x00,0x41,0x7f,0x41,0x00,   // 49 I
  0x20,0x40,0x41,0x3f,0x01,   // 4a J
  0x7f,0x08,0x14,0x22,0x41,   // 4b K
  0x7f,0x40,0x40,0x40,0x40,   // 4c L
  0x7f,0x02,0x0c,0x02,0x7f,   // 4d M
  0x7f,0x04,0x08,0x10,0x7f,   // 4e N
  0x3e,0x41,0x41,0x41,0x3e    // 4f O
BYTE const TABLE6[240]=            {0x7f,0x09,0x09,0x09,0x06,   // 50 P
  0x3e,0x41,0x51,0x21,0x5e,   // 51 Q
  0x7f,0x09,0x19,0x29,0x46,   // 52 R
  0x46,0x49,0x49,0x49,0x31,   // 53 S
  0x01,0x01,0x7f,0x01,0x01,   // 54 T
  0x3f,0x40,0x40,0x40,0x3f,   // 55 U
  0x1f,0x20,0x40,0x20,0x1f,   // 56 V
  0x3f,0x40,0x38,0x40,0x3f,   // 57 W
  0x63,0x14,0x08,0x14,0x63,   // 58 X
  0x07,0x08,0x70,0x08,0x07,   // 59 Y
  0x61,0x51,0x49,0x45,0x43,   // 5a Z
  0x00,0x7f,0x41,0x41,0x00,   // 5b [
  0x02,0x04,0x08,0x10,0x20,   // 5c
  0x00,0x41,0x41,0x7f,0x00,   // 5d
  0x04,0x02,0x01,0x02,0x04,   // 5e
  0x40,0x40,0x40,0x40,0x40,   // 5f
  0x00,0x01,0x02,0x04,0x00,   // 60
  0x20,0x54,0x54,0x54,0x78,   // 61 a
  0x7f,0x48,0x44,0x44,0x38,   // 62 b
  0x38,0x44,0x44,0x44,0x20,   // 63 c
  0x38,0x44,0x44,0x48,0x7f,   // 64 d
  0x38,0x54,0x54,0x54,0x18,   // 65 e
  0x08,0x7e,0x09,0x01,0x02,   // 66 f
  0x0c,0x52,0x52,0x52,0x3e,   // 67 g
  0x7f,0x08,0x04,0x04,0x78,   // 68 h
  0x00,0x44,0x7d,0x40,0x00,   // 69 i
  0x20,0x40,0x44,0x3d,0x00,   // 6a j
  0x7f,0x10,0x28,0x44,0x00,   // 6b k
  0x00,0x41,0x7f,0x40,0x00,   // 6c l
  0x7c,0x04,0x18,0x04,0x78,   // 6d m
  0x7c,0x08,0x04,0x04,0x78,   // 6e n
  0x38,0x44,0x44,0x44,0x38,   // 6f o
  0x7c,0x14,0x14,0x14,0x08,   // 70 p
  0x08,0x14,0x14,0x18,0x7c,   // 71 q
  0x7c,0x08,0x04,0x04,0x08,   // 72 r
  0x48,0x54,0x54,0x54,0x20,   // 73 s
  0x04,0x3f,0x44,0x40,0x20,   // 74 t
  0x3c,0x40,0x40,0x20,0x7c,   // 75 u
  0x1c,0x20,0x40,0x20,0x1c,   // 76 v
  0x3c,0x40,0x30,0x40,0x3c,   // 77 w
  0x44,0x28,0x10,0x28,0x44,   // 78 x
  0x0c,0x50,0x50,0x50,0x3c,   // 79 y
  0x44,0x64,0x54,0x4c,0x44,   // 7a z
  0x00,0x08,0x36,0x41,0x00,   // 7b
  0x00,0x00,0x7f,0x00,0x00,   // 7c
  0x00,0x41,0x36,0x08,0x00,   // 7d
  0x10,0x08,0x08,0x10,0x08,   // 7e
  0x78,0x46,0x41,0x46,0x78    // 7f
void    nokia_init(void);
void    nokia_write_command(char bytefornokia_command);
void    nokia_write_data(char bytefornokia_data);
void    nokia_write_dorc(char bytefornokia);
void    nokia_gotoxy(int8 xnokia, int8 ynokia);
void    nokia_erase_y(int8 ynokia);
void    nokia_erase_x(int8 xnokia);
void    nokia_printchar(int8 cvar);
void    nokia_clean_ddram(void);
void    table_to_nokialcd(void);
void    nokia_plot(int8 xnokia,int8 plot_value8);
void    nokia_write_data_inv(char bytefornokia_data_inv);
void    nokia_clear_screen(void);
void    nokia_clear_xy(int8 xnokia, int8 ynokia);
void    nokia_print_uparrow(void);
void    nokia_print_downarrow(void);
void    nokia_print_leftarrow(void);
void    nokia_print_rightarrow(void);
void    nokia_print_degree(void);
void    nokia_print_lowbatdegree(void);
  output_high(nok_dc);            // bytes are stored in the display data ram, address counter, incremented automatically
  output_high(nok_cs);            // chip disabled
  output_low(nok_res);            // reset chip during 250ms
  delay_ms(10);         // works with less.....
  output_high(nok_res);
  nokia_write_command(0x21);   // set extins extended instruction set
  nokia_write_command(0xc2);   // Vop  v1: 0xc8 (for 3V)// v2: 0xa0 (for 3V) // v3: 0xc2 (2v6-5v)   ********************************************************************************************************************
  nokia_write_command(0x13);   // bias
  nokia_write_command(0x20);   // horizontal mode from left to right, X axe are incremented automatically , 0x22 for vertical addressing ,back on normal instruction set too
  nokia_write_command(0x09);   // all on
  nokia_clean_ddram();      // reset DDRAM, otherwise the lcd is blurred with random pixels
  nokia_write_command(0x08);   // mod control blank change (all off)
  nokia_write_command(0x0c);   // mod control normal change
  nokia_gotoxy(0,0);         // 84*6=504      clear LCD
  for (ddram=504;ddram>0;ddram--){nokia_write_data(0x00);}
  output_low(nok_dc);   // byte is a command it is read with the eight SCLK pulse
  output_low(nok_cs);   // chip enabled
  nokia_write_dorc(bytefornokia_command);
  nokia_write_dorc(bytefornokia_data);
void nokia_write_dorc(char bytefornokia)         // serial write data or command subroutine
  char caa;
  for (caa=8;caa>0;caa--) {
    output_low(nok_sclk);
    // delay_us(2);
    if ((bytefornokia&0x80)==0){output_low(nok_sda);}
    else {output_high(nok_sda);}
    output_high(nok_sclk);
    bytefornokia=bytefornokia<<1;
void nokia_gotoxy(int8 xnokia, int8 ynokia)      // Nokia LCD 3310 Position cursor
  nokia_write_command(0x40|(ynokia&0x07));   // Y axe initialisation: 0100 0yyy
  nokia_write_command(0x80|(xnokia&0x7f));   // X axe initialisation: 1xxx xxxx
  nokia_gotoxy(0,ynokia);
  printf(nokia_printchar,"              ");
  char column;
  for (column=0;column!=6;column++){
    nokia_gotoxy(xnokia,column);
void nokia_printchar(int8 cvar)               // Write 1 character to LCD
  charsel=cvar;
  table_to_nokialcd();
void table_to_nokialcd(void)   // extract ascii from tables & write to LCD
  if (charsel<0x20)return;
  if (charsel>0x7f)return;
  for (char_row=0;char_row<5;char_row++) {      // 5 bytes
    if (charsel<0x50){charpos=(((charsel&0xff)-0x20)*5);chardata=TABLE5[(charpos+char_row)];}            // use TABLE5
    else if (charsel>0x4f){charpos=(((charsel&0xff)-0x50)*5);chardata=TABLE6[(charpos+char_row)];}            // use TABLE6
    nokia_write_data(chardata);      // send data to nokia
  nokia_write_data(0x00);      //    1 byte (always blank)
  char i;
  plot_value32=0;
  // plot_value32|=1;         // unremark this if you want dotgraph instead of bargraph
  for (i=0;i!=plot_value8;i++){
    plot_value32|=1;         // remark this if you want dotgraph instead of bargraph
    plot_value32<<=1;
  plot_value32|=2;            // bottom line is always filled
  plot_llsb=(plot_value32&0xff);
  plot_ulsb=((plot_value32>>8)&0xff);
  plot_lmsb=((plot_value32>>16)&0xff);
  plot_umsb=((plot_value32>>24)&0xff);
  nokia_gotoxy(xnokia,1);
  nokia_write_data_inv(plot_umsb);
  nokia_gotoxy(xnokia,2);
  nokia_write_data_inv(plot_lmsb);
  nokia_gotoxy(xnokia,3);
  nokia_write_data_inv(plot_ulsb);
  nokia_gotoxy(xnokia,4);
  nokia_write_data_inv(plot_llsb);
  char caa;
    delay_us(2);
    if ((bytefornokia_data_inv&0x01)==0){output_low(nok_sda);}
    bytefornokia_data_inv=bytefornokia_data_inv>>1;
  nokia_erase_y(0);
  nokia_erase_y(1);
  nokia_erase_y(2);
  nokia_erase_y(3);
  nokia_erase_y(4);
  nokia_erase_y(5);
  nokia_gotoxy(xnokia,ynokia);
  nokia_printchar(" ");
  nokia_write_data(0x04);
  nokia_write_data(0x02);
  nokia_write_data(0x7f);
  nokia_write_data(0x10);
  nokia_write_data(0x20);
  nokia_write_data(0x08);
  nokia_write_data(0x1c);
  nokia_write_data(0x2a);
  nokia_write_data(0xf8);
  nokia_write_data(0x06);
  nokia_write_data(0x09);
  // nokia_printchar("  ");
  nokia_write_data(0x0f);
stam
« Reply #9 on: November 25, 2007, 01:03:23 13:03 »
Hello fagari!
Thanks for the source code!
One question if you can help!
Is there any way to create custum characters? For example some letters in greek...
For example can i change this:
to some other values and print something else? Or it's standar these numbers (0x00 etc)?
Thanks! Smiley
fagari
-Receive: 41
« Reply #10 on: November 25, 2007, 10:33:52 22:33 »
Hello stam
Yes it is very easy. You can change any character or add new character.
example :
This character is 8*5 mode
       HEX CODE                        ASCI CODE         CRACTER
               MAP (binary)
0x00 -> 00000000
0x07 -> 00000111
0x00 -> 00000000
0x07 -> 00000111
0x00 -> 00000000
New Character T
0x01,0x01,0x7F,0x01,0x01,   //          22                   T
               MAP (binary)
0x01 -> 00000001
0x01 -> 00000001
0x7F -> 01111111
0x01 -> 00000001
0x01 -> 00000001
« Last Edit: November 25, 2007, 10:51:56 22:51 by fagari » Logged
fagari
-Receive: 41
« Reply #11 on: November 25, 2007, 10:50:27 22:50 »
Stam
This is litle program for character generator. Maybe useful for you.
stam
« Reply #12 on: December 06, 2007, 11:09:08 23:09 »
Thanks for replies! Smiley
I understand how can i make custom characters!
Now I'm trying to make the full alphabet for greek letters!
Smiley
glenjoy
« Reply #13 on: January 17, 2008, 12:57:11 00:57 »
I think this is a driver for LCD right?
future
-Given: 11
« Reply #14 on: January 18, 2008, 02:46:20 14:46 »
also here
http://www.microsyl.com/nokialcd/nokialcd.html
