hodahel
-Given: 189
Catch me...
« Reply #25 on: July 08, 2015, 06:10:44 06:10 » |
I'll try to messed with my TL866CS.
hodahel
-Given: 189
Catch me...
« Reply #26 on: July 09, 2015, 06:27:37 06:27 » |
I'm bit lost here..  Where can I get this firmware dumper?
« Last Edit: July 09, 2015, 06:29:40 06:29 by hodahel »
-Given: 839
-Receive: 4336
« Reply #27 on: July 09, 2015, 10:03:09 10:03 » |
I'm bit lost here.. Where can I get this firmware dumper? in my last post there are two files TL866.EXE and Update.dat last firmware update for the TL866. you use TL866.EXE and it will update the firmware in your TL866CS to TL866A you don't need to pump the update.dat to hex unless you want to, you just flash your device with TL866.EXE
« Last Edit: July 09, 2015, 10:30:30 10:30 by pickit2 »
hodahel
-Given: 189
Catch me...
« Reply #28 on: July 09, 2015, 12:13:28 12:13 » |
Actually I already hacked my CS to A but I'm just curious with that "DUMP" and "ADVANCED" buttons..  Just sharing this.. well, in this case you can do it in two ways: a simple and safe method and a dangerous and "complicate" method.
The simple method of changing from TL866CS to TL866A version: 1. download my firmware updater here: TL866 firmware updater and unzip it. 2. connect your device to USB cable. 3. run TL866.exe from the above downloaded archive 4. in the update.dat file section browse for that file (you can find this file in the minipro installation folder) 5. in the "Firmware to write" section select TL866A firmware 6. click reflash button
Your device will be reflashed with the A firmware version. Done!
The only drawback of this method is that future firmware upgrades can be done only with my tool, the minipro software will revert to original "CS" version.
The dangerous and complicated method: 1. run TL866.exe from downloaded archive 2. in the update.dat file section browse for that file (you can find this file in the minipro installation folder) 3. in the "Firmware to write" section select firmware dumper 4. click reflash button now a custom firmware will be programmed into your device, just wait to finish 5. The Advanced button will become available, just click it and another window will appear! 6. in this advanced window we have three fields: Bootloader section, Copy protection section and device serial number section 7. in the Bootloader section select "A Bootloader" and click Write button now your bootloader will be reflashed. 8. just close this advanced window and from main window in the "Firmware to write" section select TL866A firmware 9. click reflash button
now your device will be reflashed with the A version firmware. done!
With this method your device will be permanently transformed to A version and future upgrades will be possible from minipro software. But why is this method dangerous? because if something goes bad (power failure, computer crash etc.) during bootloader reflash your device will be bricked (and you will need an external programmer).
Marcustv
-Given: 197
-Receive: 14
« Reply #29 on: July 12, 2015, 09:08:57 09:08 » |
Whaoo .. I using the first programming procedure. Now I have a TL866A I am very happy Thank you very much
Marcustv
-Given: 197
-Receive: 14
« Reply #30 on: July 12, 2015, 10:46:31 10:46 » |
I hope it will be useful ....
Beltza
-Given: 228
-Receive: 42
« Reply #31 on: July 25, 2015, 03:41:41 15:41 » |
New software update:
Version: V6.17 Support:13216 --2015.07.11
Fix:ATMEGA48 Algorithm for Compatibility
Marcustv
-Given: 197
-Receive: 14
« Reply #32 on: December 30, 2015, 06:12:53 18:12 » |
New software is out ver. 6.50 now is possible program chip with 1.8 V Need special Adapter
Beltza
-Given: 228
-Receive: 42
« Reply #33 on: September 21, 2016, 08:43:34 08:43 » |
The update is old, but this is the complete changelog of the 6.50 version:
Version: V6.50 - 2015.12.25
ADD:Support 25 Flash OTP programm Support 1.8V 25 serials Flash (Need special Adapter DIY) Ic Support up to 14000+, more detail see IC supported List.
Beltza
-Given: 228
-Receive: 42
« Reply #34 on: May 21, 2017, 07:39:15 07:39 » |
New update from 2017-05-09. Versión 6.60.
Added support for:
IS25LQ080B/IS25LQ016B /IS25LQ032B
PN25F04A/PN25F04C/PN25F08/PN25F08B PN25F16/PN25F16B/"PN25F32/PN25F32B PN25F64/PN25F64B/PN25F128B
GD25LQ05B/GD25LQ10B/GD25LQ20B/GD25LQ40B/GD25LQ80B
GD25LQ16/GD25LQ32C/GD25LQ32D/GD25LQ64C GD25LQ128/GD25VQ21B/GD25VQ40C/GD25VQ80C GD25VQ16C/GD25VQ32C/GD25VQ32C/GD25VQ64C
-Given: 839
-Receive: 4336
« Reply #35 on: May 21, 2017, 02:16:24 14:16 » |
Beltza
-Given: 228
-Receive: 42
« Reply #36 on: May 21, 2017, 05:20:49 17:20 » |
When I started this thread I was warned for post a link to an non English site.
-Given: 839
-Receive: 4336
« Reply #37 on: May 21, 2017, 07:14:21 19:14 » |
When I started this thread I was warned for post a link to an non English site. EDIT : No Warning in System Logs
True you posted a link to a non English Site ie: http://www.autoelectric.cnIf you had read the Rules you can post a Direct link to a file /not the site. Rule: Posting: 23-Post direct links only. Do not post links to any forums ( www.blablaforums.com) or personal page ( www.blabla.com).
« Last Edit: May 21, 2017, 07:25:39 19:25 by pickit2 »
Beltza
-Given: 228
-Receive: 42
« Reply #38 on: May 22, 2017, 06:22:37 06:22 » |
Ouch! Sorry. Didn't understand the rule correctly.
Marcustv
-Given: 197
-Receive: 14
« Reply #39 on: March 02, 2018, 04:56:06 16:56 » |
A new version of the software is out 7.05 , for the new version of TL866II programmer
-Given: 839
-Receive: 4336
« Reply #40 on: March 02, 2018, 08:08:17 20:08 » |
This is a new Programmer. Support for the TL866A & CS came to an end.
Marcustv
-Given: 197
-Receive: 14
« Reply #41 on: March 09, 2018, 05:45:23 17:45 » |
A new 6.70 software version for the old classic TL866 has been released. Software development for this programmer is not over.
Marcustv
-Given: 197
-Receive: 14
« Reply #42 on: April 24, 2018, 06:17:28 06:17 » |
A new software version for the TL866 A and CS was released 6.71
Marcustv
-Given: 197
-Receive: 14
« Reply #43 on: July 22, 2018, 06:54:21 06:54 » |
A new software version for the TL866 A and CS was released 6.81
Marcustv
-Given: 197
-Receive: 14
« Reply #44 on: July 22, 2018, 09:03:35 09:03 » |
I tested this latest version of the 6.81 program I have a TL866CS modified in TL866A. When connecting the programmer, during firmware update, it is detected that it was a TL866CS modified in TL866A. A Web page of the manufacturer opens and warns that many modified or cloned programmers exist on the market, it works the same correctly. I tried to read and write devices, without any problem. My programmer counts to be seen as a TL866A
-Given: 839
-Receive: 4336
« Reply #45 on: July 22, 2018, 12:01:21 12:01 » |
So how did you update your TL866xx ?
Marcustv
-Given: 197
-Receive: 14
« Reply #46 on: July 23, 2018, 05:46:55 05:46 » |
I have updated the programmer from the TL866CS version to the TL866A version following the instructions described in this forum. The update operation is something I had done before installing 6.81 software. The new software, he realizes that originally my programmer was a TL866CS, and for this he tells me that he could be a "pirated" programmer, ... but it works the same as TL866A
kayvee
-Given: 99
-Receive: 101
« Reply #47 on: July 23, 2018, 09:13:24 09:13 » |
There is much discussion of this over at eevblog in the TL866 review thread.
-Given: 839
-Receive: 4336
« Reply #48 on: July 23, 2018, 10:29:29 10:29 » |
Yes but the question was how did you update ? with their software or by using TL866.EXE. It maybe they are checking serial numbers. and just reporting it as wrong. for now, later on they may brick it.
Marcustv
-Given: 197
-Receive: 14
« Reply #49 on: July 23, 2018, 03:01:27 15:01 » |
I made the upgrade I think two years ago, now sincerely, I do not remember which system I used for the change.
