November 25, 2024, 02:55:39 02:55
Author Topic: Matlab- Arduino- serial com  (Read 5147 times)
pouchito
-Given: 61
« on: July 04, 2014, 10:07:21 22:07 »
I want to send 3 numbers separated by commas from the GUI serially through the COM port  to the arduino.
the arduino will later on use these values for example as the delay() time input for each of the 3 LEDs.
i found this code:
MATLAB:
function stepInput_Callback(hObject, eventdata, handles)
xyz = get(hObject,'String');
disp('Value entered: ')
disp(xyz)
global COM;
global s;
s = serial(COM,'BaudRate',9600);
fopen(s);
disp('After OPEN')
disp(s)
fprintf(s,xyz);
fclose(s);
disp('After CLOSE')
disp(s)
Arduino Code:
int x;
int y;
int z;
void setup() {
pinMode(2,OUTPUT);
pinMode(6,OUTPUT);
pinMode(10,OUTPUT);
Serial.begin(9600);
void loop() {
if (Serial.available()) // check if Serial data is available to read
    x = Serial.parseInt();
    y = Serial.parseInt();
    z = Serial.parseInt();
   if (Serial.read() == '\n') // check if ENTER has been pressed (newline)
      digitalWrite(2,1);
      delay(x);
      digitalWrite(6,1);
      delay(y);
      digitalWrite(10,1);
      delay(z);
      digitalWrite(10,0);
      delay(z);
      digitalWrite(6,0);
      delay(y);
      digitalWrite(2,0);
      delay(x);
but it is not working at all
can u help me figure out the problem
« Last Edit: July 05, 2014, 05:46:28 17:46 by pouchito » Logged
hate
-Given: 156
-Receive: 355
« Reply #1 on: July 05, 2014, 12:00:57 00:00 »
'xyz' here is a single variable, if the code had been:
[x y z] = get(hObject,'String');
then 'x', 'y' and 'z' would be different variables. I can't tell anything else without testing the code myself but the problem seems to be the Arduino code:
is reading the SINGLE 'xyz' variable into 'x' and not reading anything else into 'y' and 'z'. You may want to check it out.
And next time please use code tags and COMMENT your code so that others may get an idea about what it's doing without the need to consult MATLAB documentation!
Regards...
pouchito
-Given: 61
« Reply #2 on: July 05, 2014, 06:23:08 18:23 »
Thank you hate and sorry for the bad formatting, i edited my original post.
i modified it as u suggested:[x y z] = get(hObject,'String');    instead of xyz = get(hObject,'String');
but nothing changed.
i m not able to read any values.
do u think the problem is in the arduino part.
what i want to do is to send 3 different long bytes variable to the arduino.
can u help me please ?
TucoRamirez
-Given: 257
-Receive: 115
Tuco ... dead or Alive
« Reply #3 on: July 05, 2014, 06:36:06 18:36 »
have you tested your serial data on any terminal soft in order to verify that are you sending what u expected?
pouchito
-Given: 61
« Reply #4 on: July 05, 2014, 06:55:42 18:55 »
no i did not, i m sure that information are being transmitted since the arduino is flashing
i will try to test it on a serial terminal, hope i ll know how :S
hate
-Given: 156
-Receive: 355
« Reply #5 on: July 05, 2014, 08:00:03 20:00 »
My suggestion was based on a general issue in your code. For this change to help with anything, get() function must be returning 3 values which I have no idea if it does. I even have no idea what get() function performs! Before I can be of more help can you please explain the MATLAB code further? For example what is the purpose of the definition of the function in the first line and where it is used in the code?
Regards...
-Given: 834
-Receive: 4322
« Reply #6 on: July 05, 2014, 10:16:00 22:16 »
Did you use the built in serial coms in Arduino Ctrl Shift & M it will show more than just flashing a led.
hate
-Given: 156
-Receive: 355
« Reply #7 on: July 06, 2014, 09:27:35 09:27 »
Unfortunately that can only work if he has 2 serial ports, one for MATLAB communication and one for IDE communication.
Regards...
TucoRamirez
-Given: 257
-Receive: 115
« Reply #8 on: July 06, 2014, 11:25:06 11:25 »
except if you create a bridge on Virtual ports ...
pouchito
-Given: 61
« Reply #9 on: July 06, 2014, 12:01:38 12:01 »
I tried the arduino part and the serial monitor
It s working properly
But when i m sending from matlab it s not working
So i guess my problem is with matlab, right ?
Hate, concerning the function i used:
it s simply what i got when i insert a text box in the gui interface of matlab, it s nthg imp.
« Last Edit: July 06, 2014, 12:05:08 12:05 by pouchito » Logged
pablo2048
-Given: 136
-Receive: 86
« Reply #10 on: July 06, 2014, 12:59:18 12:59 »
I think that there can be problem in Your Arduino sketch - main loop can be executed too fast to catch all characters of an integer for .parseint() method - try check if there is valid '\n' character (if Serial.read() == '\n' is true...)
pouchito
-Given: 61
« Reply #11 on: July 06, 2014, 01:17:34 13:17 »
I inserted a
after the:
instead of the end
and i changed the :
if (Serial.read() =='\n')
to
if (Serial.read() <='\n')
now the leds are turning ON whenever i press the "enter" key regardless of the values
where am i mistaken ?
pablo2048
-Given: 136
-Receive: 86
« Reply #12 on: July 06, 2014, 01:46:49 13:46 »
Ok, simple solution - get characters from serial into an array (use stream class) and after receiving "\n" just use .parseInt ...
pouchito
-Given: 61
« Reply #13 on: July 06, 2014, 02:30:27 14:30 »
not working :S
can you modify it maybe i m doing sthg wrong :S
pablo2048
-Given: 136
-Receive: 86
« Reply #14 on: July 06, 2014, 02:45:13 14:45 »
Ok - one maybe weird idea - are You sure that Your Matlab code sends "\n" correctly (i'm not familiar with matlab)? Can You please check this? It seems that Arduino serial.parseint method wait internally for the next character...
pouchito
-Given: 61
« Reply #15 on: July 06, 2014, 06:04:28 18:04 »
Do u think the problem is in the matlab part ?
pablo2048
-Given: 136
-Receive: 86
« Reply #16 on: July 06, 2014, 07:31:23 19:31 »
I'm not sure, but now i suspect line-ending output from matlab rather than Arduino part...
hate
-Given: 156
-Receive: 355
« Reply #17 on: July 06, 2014, 09:22:21 21:22 »
Can you please elaborate this? I always thought debugging an Arduino with the serial port already connected to some application was a real pain. I believe the method you mentioned is meant for these situations. Wink
@pouchito:
Can you please answer the following questions with appropriate code lines.
1- In which variables are your 3 delay values stored?
-> insert code line(s) here!
Can you see those values in the corresponding variables on MATLAB debugger which is usually at the top right of the main window named 'workspace'?
2- Which com port does the code initialize and where in the code?
3- How are these values are sent to serial port and where in the code?
4- Can you receive anything at the Arduino side, did you test it with the built-in serial monitor?
5- If the answer is yes to the previous question, did you try sending something like:
23
85
15
and did you get the expected behavior on the Arduino part?
Regards...
pouchito
-Given: 61
« Reply #18 on: July 06, 2014, 10:41:03 22:41 »
Thank you hate for your time.
i found the code on the net and it is not me who wrote it.
i will try to answer ur questions:
in xyz :
no, i cannot see it in the corresponding variables debugger but in the command window i m receiving like a summary and i found this:
Read/Write State
      TransferStatus:     idle
      BytesAvailable:     227
      ValuesReceived:     0
      ValuesSent:         3
i m working on com5
s = serial('COM5','BaudRate',9600);
fprintf(s,'%f',char(xyz));
i think here i have a problem
i tried the arduino code with the serial monitor (no matlab) and it is working properly. i sent (1000,1000,1000) and i receive (1000,1000,1000)
but when i use the matlab to send the info serially, i can see that the COM port opens since the arduino flashes but i receive no output.
Posted on: July 06, 2014, 11:02:21 23:02 - Automerged
i ve been working on this project nights and now one line (pause) simply make it work yeyyyyyy Smiley
thank you all for ur help
