November 29, 2024, 11:51:12 23:51
Author Topic: MkroC HID Maximum Report Size  (Read 4341 times)
odsk
-Receive: 12
« on: June 02, 2014, 03:52:21 03:52 »
Hello;
I am using MkroC for PIC and while creating a descriptor using HID terminal I need to select the size of the transfer report size. The size by default is 64 for in and out reports. what is the maximum report length I can use? MikroC won't let enter 255 for example.
PIC used is 18f4550.
Thanks,
ODSK
« Reply #1 on: June 02, 2014, 09:18:34 09:18 »
in usb standard for hid, size can be changed and is not limited, but be aware that a maximum of 64 bytes can be sent at one time, the report length should be equal or less than the endpoint size, so the endpoint size is the problem as HW guarantees sending/receiving 64 bytes in one packet, if the report is bigger than the endpoint size you must send the report in several times, usually people use a for loop to accomplish sending arrays larger than 64 byes.
the following lines in your usbdsc.c
const char HID_INPUT_REPORT_BYTES = 64;
const char HID_OUTPUT_REPORT_BYTES = 64;
« Last Edit: June 02, 2014, 09:32:44 09:32 by metal » Logged
XxMohannadxX
-Given: 23
-Receive: 78
« Reply #2 on: June 02, 2014, 10:13:37 10:13 »
Hello;
Thanks,
ODSK
you can use CDC it has a max of 128 bytes and it is also available in mikroc
