April 22, 2025, 01:55:30 13:55
Author Topic: 1-wire slave - emulated DS18B20 - and sniffer  (Read 8337 times)
xtal
« on: May 19, 2014, 02:39:32 14:39 »
Attached is code for a 1-wire sniffer [12F1822] ,  and an emulated DS18B20 temperature sensor 12F6783 @ 8mhz and 12F1822 @8*4mhz.
The temperature only shows an emulated temperature, the CONVERT code would have to be altered along with adding a sensor.
The sniffer supports bauds of 115200, 230400, 460800, 921600 [ must use virtual comm port for high bauds except 115200]
The sniffer also enabled/disable the display of search data, how ever using this you might miss something [i.e] for example
IButtonviewer never showed a convert command, until I enabled the search data , and there it was , right after the search data
which does not agree with the DS18B20 flow chart, therefore my slave code was changed to act like a real DS18B20..
The DS18B20 code is really just a building block, for other stuff if wanted...
The big draw back is the supporting code for my Desktop.....
Posted on: May 19, 2014, 03:37:55 15:37 - Automerged
files
Nicolina1988
-Given: 28
-Receive: 85
« Reply #1 on: August 24, 2014, 03:20:47 15:20 »
Thank for the interesting idea about the sniffer. I have 2 questions:
Is there limitations to use lower baudrates  down to 2400?
To translate ths basic code a CCS C style are there any time critical parts of it that may break the functionality?
