March 13, 2026, 08:18:19 20:18
Pages: 1 [2]  All
Author Topic: Human voice with picbasic  (Read 22167 times)
smartguy
« Reply #25 on: November 24, 2007, 04:56:09 16:56 »
if you record it on PC you can use http://audacity.sourceforge.net/  removing the small pauses and
other between the sounds to get more out of the ISD devices.
Aso if you use numbers only records number 1-20 , 30 , 40 ...
when you what to speak 24  , use 20 and the 4
br
Smartguy
 Smiley Smiley
Sun_rise_pt
-Given: 87
« Reply #26 on: November 24, 2007, 07:09:11 19:09 »
In the french magazine Electronique Pratique have two voice recorders on EEPROM.
Please look the code here:
http://electroniquepratique.com/images/images_doc/PROG_EP295_044.zip
...and the PCB layout:
http://electroniquepratique.com/images/images_doc/CI_EP295_044.zip
First you make a voice record on your PC with wav format file...
The file wav_bin.exe are a converter (and cleaner of some "trash") from wav file to bin.
The PIC scans the EEPROM and drives a LPF and after a AF amplifier.
The circuit and firmware are very simple and all works fine
caveman508
-Given: 12
READ, REAd, REad, Read
« Reply #27 on: February 06, 2008, 04:37:59 04:37 »
check this out, I tried it and was fairly pleased, just not enough time to go into it further.
http://www.romanblack.com/picsound.htm
Caveman
lillbear
-Given: 223
-Receive: 182
« Reply #28 on: February 07, 2008, 06:36:31 18:36 »
Is here any picbasic or C gurus, if they could do a dummys guide to Romans Black sound asm-file HowTo use with picbasic or CCS or mikroC  Tongue
yours
ipek
-Given: 60
-Receive: 79
« Reply #29 on: February 07, 2008, 11:38:17 23:38 »
http://rapidshare.com/files/90011881/basic-voice.rar.html      double prj...
and   http://www.compile-it.com/Proton/PIC_WAV_PLAYER.zip
Pages: 1 [2]  All
