April 22, 2026, 10:14:50 22:14
Author Topic: micro to matlab serial comunication  (Read 5293 times)
hamid9543
-Given: 80
« on: April 19, 2014, 06:47:35 06:47 »
hi .
can you help me for conect picmicro (ccs) to matlab with serial comunication?
xpress_embedo
-Given: 122
-Receive: 254
« Reply #1 on: April 21, 2014, 03:16:43 03:16 »
What problem you are facing in doing so??
Just use PIC Micro-Controller UART and RS232 Line Driver IC such MAX3232/MAX232 to send data on PC, instead of receiving on Hyper-Terminal program of windows, use MATLAB to receive data.
First of all you have to Open the Communication Port.
The Following Command Creates a Serial Port Object associated with COM1 and will set its Baud Rate = 9600 bps
 s = serial('COM1','BaudRate',9600);
Then you have to open this port, the command is as follow:-
fopen(s)
To Send a String to RS232 Port:
fprintf(s,'Sonsivri');
To Receive Data from RS232 Port in MATLAB
fgets(s)
To Close the Port
flcose(s)
delete(s)
I am also attaching some links with tutorial on MATLAB Serial Based Communication, apart from that refer MATLAB Documentation, everything is properly explained in that document.
« Last Edit: April 21, 2014, 03:22:48 03:22 by xpress_embedo » Logged
