December 21, 2024, 04:55:30 16:55
Author Topic: [REQ] Enroute 4 CAD/CAM  (Read 7098 times)
sakbal
-Given: 384
-Receive: 35
« on: April 01, 2014, 02:51:16 14:51 »
I'm looking for the enroute 4 medicine file.
Much appreciated, if anyone still has it and willing to share it.
It use to be available on rapidshare, but no more.
« Reply #1 on: April 01, 2014, 10:51:07 22:51 »
For those who are curious, this is woodworking and signmaking CAD, as if that's anything special compared to mainstream CAD programs. http://www.enroutesoftware.com/WhyEnRoute/default.aspx
It does have a Mach post though http://www.enroutesoftware.com/HowToBuy/Driverlist.aspx
v5 has a full download:http://www.enroutesoftware.com/Objects/Documents/EnRoute%205_0_0_23.zip
Now all you need is a dongle
Anyway, sakbal, if you post the v4 executable (mediafire is a good place), I'll post the medicine files I just found for you - because it's not about YOU, it's about US.
You'll have to test it and report back if it works -I don't have the time or interest to check it
optikon
-Given: 1109
-Receive: 2007
« Reply #2 on: April 02, 2014, 03:38:37 03:38 »
I also dont have time or interest to check. But Found what looks like a v5 patch.
Looks suspicious,  but virustotal thinks its ok.
Report results!
See attached.
« Last Edit: April 07, 2014, 11:15:32 11:15 by optikon » Logged
sakbal
-Given: 384
-Receive: 35
« Reply #3 on: April 07, 2014, 08:06:49 08:06 »
Thanks Solutions
The En4 source...
« Reply #4 on: April 07, 2014, 12:31:40 12:31 »
You know what button to push if it works
You know how to bitch if it doesn't
Cuz it's UNTESTED at the time of this posting
sakbal
-Given: 384
-Receive: 35
« Reply #5 on: April 08, 2014, 06:47:37 06:47 »
Tried ER5. It does not run on X64, will try it on x86.
« Reply #6 on: January 13, 2015, 01:08:15 01:08 »
To clarify - the executable does not run on x64 (v5 is x64 capable), nor does the patch. Also does not run in Win XP compatibility mode
