November 29, 2024, 04:30:02 04:30
Author Topic: Transmagic Plus v7.0 ISO  (Read 6610 times)
aslan_korhan
-Receive: 60
« on: September 25, 2007, 04:27:53 04:27 »
TransMagic, Inc. is a leading developer of 3D CAD translation software products that address the interoperability challenges facing the manufacturing industry. TransMagic offers uniquely packaged multi-format translation software products that allow companies to quickly translate models between all 3D CAD/CAM/CAE systems. Supported file types include 3D CAD models from CATIA V4, CATIA V5, Unigraphics, Pro/ENGINEER, Autodesk Inventor, AutoCAD (via *.sat), and SolidWorks, as well as, ACIS, Parasolid, STL, STEP and IGES.
TransMagic offers a complete line of 3D CAD translation software products with functionality for translation, file repair, viewing, collaboration and high-speed, unattended batch processing.
Companies using TransMagic products include many major automotive, aerospace and tool & mold manufactures such as DaimlerChrysler, Peterbilt, Panasonic, Honeywell, Toyota, SAAB, Subaru, Caterpillar, and Northrop Grumman.
To maximize interoperability with your CAD software, see our CAD Translation Software Compatibility Guide to learn how to translate between all CAD systems including CATIA V4, CATIA V5, Unigraphics, Pro/ENGINEER, Autodesk Inventor, AutoCAD, SolidWorks, ACIS, Parasolid, STL, STEP, IGES and more!
Download
http://www.filefactory.com/file/1f636c
http://www.filefactory.com/file/c2b69c
http://www.filefactory.com/file/51d965
http://www.filefactory.com/file/6161e2
http://www.filefactory.com/file/a7c3bf
mars01
-Given: 697
-Receive: 1774
« Reply #1 on: October 23, 2017, 08:58:09 20:58 »
TransMagic Complete R12 SP0.1 v12.01.800
World-Class 3D CAD Translation, Repair and Comparison
With TransMagic You Can…
- Open, view and query any major 3D CAD format in the world
- Translate CAD models to polygonal, neutral and native formats
- Automatic repair capabilities to deliver a water tight solid
- Publish 3D PDF with PMI views intact for easy, clean communications
- Compare revisions so you know exactly what changed before you cut steel
- Automate translation and repair of thousands of files at a time
https://transmagic.com/
Not the latest version but there is nothing newer here ...
Uploadfiles link
optikon
-Given: 1106
-Receive: 2007
« Reply #2 on: October 23, 2017, 10:16:04 22:16 »
Uploadfiles link
Anybody know, is the patching fixed correctly? This version had some licensing issues when save as different formats. Just FYI.
mars01
-Given: 697
-Receive: 1774
« Reply #3 on: October 23, 2017, 10:52:16 22:52 »
It did the same on me.
Once I started the software it asked me for the license which I provided by launching the keygen in Sandboxie and then copying the code from Transmagic into the keygen and then getting the license.
But.
After I launched the software it immediately reacted and said that there is a "mandatory" update and if I didn't do it then the license will be void at the end of September (which is the past at this moment).
I tried to convert one file it said after that that the license will be converted to viewer but after relaunching the software it refused to launch.
I added then a rule in the firewall to block the executable which can be found in:
C:\Program Files\TransMagic Inc\TransMagic R12 sp0\System\code\bin
After that I played a bit, deleted some text found in a file named TMInfo.txt in the same folder Smiley Then disabled temporarily the firewall rule.
In the ended it accepted to start (until then it told me to contact customer support Smiley )
I then provided again the license but this time I checked in the keygen the checkmark where it said "Time Limit 19-07-19", generated a new license and got this message now:
Translation units: Unlimited ...
Re-enabled the firewall block rule.
Did some conversions with the provided samples (to STEP files needed for Altium 3D and especially for CircuitStudio 3D) and it seem to work ...
LE: Unfortunately it can't read Solidworks newer file formats ...
« Last Edit: October 23, 2017, 11:15:20 23:15 by mars01 » Logged
HackAndCrack
-Given: 175
-Receive: 802
« Reply #4 on: October 23, 2017, 11:58:32 23:58 »
Link doesn't work in my country. adding https also doesn't work. Can you please provide zippyshare.com link for setup file and keygen ?
mars01
-Given: 697
-Receive: 1774
« Reply #5 on: October 24, 2017, 11:09:22 11:09 »
Reuploaded to Zippyshare.
