You think I am funny guy huh?
November 27, 2024, 04:44:38 16:44
Author Topic: help needed : Grounding/Earthing/electronic 0Volt issue  (Read 4148 times)
Old_but_Alive
-Given: 746
-Receive: 120
« on: December 29, 2013, 08:55:34 08:55 »
I need a bit of advice.
I am sorting out a new product with some problems ( I just joined the company).
I dont like the way electronic 0volts s connected to the chassis ( plastic with EMC spray coating).
It is only partially sprayed on the inner plastic surface, so in no way is a Faraday cage.
The product is not earthed, unless the USB connection is made to a desktop PC which is earthed.
The product has passed all its EMC/CE stuff including ESD zapping.
There are problems, and i believe that ESD is causing blow ups.
I have attached a link to the edaboard I already asked the question of, and got a couple of replies which say "no problem"
any help would be gratefully appreciated.
-Given: 231
-Receive: 983
« Reply #1 on: December 29, 2013, 01:02:48 13:02 »
Is it the same parts that blow up each time?
Old_but_Alive
-Given: 746
-Receive: 120
« Reply #2 on: December 29, 2013, 02:24:37 14:24 »
if only it was that easy.
I first of all need to establish the correct arrangement for shielding/ground/0volts.
one of the products has micro pins going out directly to push button ON/Off switch, indicator LEDS, which is bad practice, no transzorbs, resistors, bugger all.
If you looked at the link to eda, I am surprised that the opinion is that all is OK from an earthing point of view.
I need some peer to peer support.
-Given: 834
-Receive: 4322
« Reply #3 on: December 29, 2013, 03:12:37 15:12 »
1. is the on/off switching 19V or 230V?
A power brick to pcb/unit is a standard way to power say printers  laptops and so on.
plus to have only supply pair shielded is also common, no direct link to earth.
If there is 230v or higher on the board then there could be a design issue.
Old_but_Alive
-Given: 746
-Receive: 120
« Reply #4 on: December 29, 2013, 04:49:04 16:49 »
only 19V to the unit, so no safety issues
ok, if no direct link to earth, where does the ESD energy go ?
I have always been lead to believe :-
earth chassis/anything that can be touched, that directs static to earth
connect electronics through 10nf/1KV capacitors to earth for emc.
so electronics should  NOT be connected to earth
The ON/OFF switch is metallic, but the 2 pins just connect  0volts a micro pin to  an un protected ATMEL micro pin.
optikon
-Given: 1106
-Receive: 2007
« Reply #5 on: December 29, 2013, 05:16:12 17:16 »
Where does the energy go?
If a path does not breakdown, it just gos into storing energy in the stray C by charging it up.
If it does breakdown, where does the ESD current flow? If it is actually breaking down, it is likely through stray capacitive paths. Most notably, back through the power converter. ESD is a fast event and can take out stuff along the way. Any part of the design that can be touched by a person should be impedance limited and/or clamped(voltage limiting) through a low impedance path back to earth (not easy in your case)
Each ESD and EMC case can be very different and I caution against rules of thumb that you may have been lead to believe.
You seem fairly confident in ESD being the cause. Can you get an ESD gun and start testing breakdown strength and paths? Knowing what particular parts of the design are susceptible, is 90% of the solution.
"so electronics should  NOT be connected to earth"
Each case is different. There are many types of designs where it makes sense to isolate from Earth and many where it doesn't. I would not make a generalization like that at all.
« Last Edit: December 29, 2013, 05:25:06 17:25 by optikon » Logged
« Reply #6 on: December 30, 2013, 09:10:16 21:10 »
did you have a schematic you can share?  Nothing jumps out as really being "wrong" with how it is set up.  You couldn't GO wrong with transorbs on the input and output, and 100ohm/100pf LPF on each signal input and output (such as the button or any I/O).  If the metal spray isn't doing a good job (have you measure the impedance?) maybe you could be conducting static in through the metal button.
Is there a possibility of surges in the circuitry when input or output are connected or disconnected?
Old_but_Alive
-Given: 746
-Receive: 120
« Reply #7 on: December 31, 2013, 06:47:27 06:47 »
thank you all for your help and brainpower.  Kiss
@optikon
good advice and thoughts, I agree with you
@Gallmimu
I cant share schematics unfortunately.
on one of the products, there is an ATMEL micro with several connectors, one of which takes the power button contact pins via a wiring loom, takes one directly to the micro pin, no protection, not even a series resistor, the other button pin back into the pcb, onto 0 volts via 2K resistor.
again on the same 18 pin connector NO protection on any pins, 2 LEDS RED/GREEN on the case via a wiring loom. on the pcb each has a series 100R resistor just limiting current to the usual few milliamps.
There are smart lithium batteries via a connector in the product, and so have an I2C bus which again goes straight to the ATMEL micro, no protection at all, only the usual 2K pullups
The ATMEL is programmed/debugged via a JTAG connector.
I blew the debugger up last week, it is of course a USB device, so when connected allows an earth connection via the desktop PC.
I have no idea why the debugger blew up, and that worries me. I am currently building an isolated JTAG adaptor 'cos the ATMEL JTAGICE mkII costs £300
At some point in the future, I will redesign and beef up the protection.
But I still have it in my brain to not connect 0volts to the chassis, connect the chassis ( its a poor metallic sprayed plastic case, and certainly no Faraday cage) via a 10nf/1KV Cap, and a 1M resistor to the earth on the power brick.
« Last Edit: December 31, 2013, 06:50:13 06:50 by Old_but_Alive » Logged
« Reply #8 on: January 01, 2014, 06:14:08 06:14 »
Hmm,
Still weird.  Though protections would be nice, they really shouldn't be that necessary except under pretty harsh EMI conditions.
Is there a chance that your power bricks are not properly isolated from mains?  Have you ever tried taking a running unit and used a multimeter to measure between 0V and GND on your computer?
It's definitely weird that you blew the programmer but this might be suggestive of a ground level shift between your device and the programmer.
Another stupid thought, is your power brick AC ground really connected to ground?  I ask because if your power brick has X/Y caps in it to ground and the ground isn't connected properly this could allow an AC leakage up into the connector ground in your device.
Just trying to throw out ideas...
Old_but_Alive
-Given: 746
-Receive: 120
« Reply #9 on: January 01, 2014, 08:59:31 08:59 »
@Gallmimu
I am really thankful for your thoughts.
there is a connection from the power brick (XP Power) dc pin plug metal housing to the earth pin on the mains plug as measured by an ohmeter.
Of course, I expect there to be X/Y caps to earth.
as to "It's definitely weird that you blew the programmer but this might be suggestive of a ground level shift between your device and the programmer."
the situation was that the product wouldnt show signs of life, so I blindly replaced the 100 pin TQFP Atmel device, as that controls everything.
I connected the debugger/programmer, successfully JTAG blew the code into the device, so all was well then.
I was single stepping/breakpointing trying to find out the problem, than at some point ( dont remember the circumstance ) I think I noticed the debugger getting hot/not working.
The debugger on its own connected to USB for power now gets very hot, and there is an LM317 inside, which really gets hot.
Strange thing, the debugger/programmer can be powered by either USB or 9V DC normal 2.1mm DC plug.
So, the USB connection power gets hot, the external 9V power is fine !!!!, but the thing wont JTAG work anymore
Since I dont have the schematic of the ATMEL JTAGICE MkII, its hard to go much further.
I have a second working debugger, but am scared to plug it in, so am currently building an isolated JTAG adapter, so cant blow the debugger up again ( I pray )
I only joined the company 4 weeks ago, and havent used ATMEL before, but am experienced in PIC,ARM and other micro's so not a newbie.
I do think the problem is something to do with earthing/0v/usb
I have been in engineering for 45 years, so know a thing or two  ( OC71,2N3055,uA709)  Grin
« Last Edit: January 01, 2014, 09:02:40 09:02 by Old_but_Alive » Logged
« Reply #10 on: January 01, 2014, 04:25:26 16:25 »
My understanding is 0V most of the time connected to chassis ground, except if an isolated device needed. To ground (earth) or not (floating) is a choice, to earth is for safety, floating is to avoid ground loops (aka noise) and for some measurement instruments.
Connecting mcu pins to outside without any protection is a big NO, not ESD i think but EMC (inductively coupled) is the enemy. A series resistor with value below 1K wont be enough to protect the clamping diode inside mcu pin, an external bi-dir clamping diode after the resistor will do the job, while in industrial environment an optocoupler (6N137) is the standard practice.
As for the blown debuger, i may check the circuit if it has some conflicts between JTAG pins and used I/O.
« Reply #11 on: January 02, 2014, 05:26:12 05:26 »
Ha, no shame in having hard problems (or simple ones that hide very well).  You'll figure it out.  Sorry I don't have any other ideas.
Old_but_Alive
-Given: 746
-Receive: 120
« Reply #12 on: January 02, 2014, 07:36:58 07:36 »
@Ichan,
thank you for your info.
the JTAG debugger pins are solely dedicated to the debugger.
0v and +3v3 are directly connected back to the debugger, which is normal.
I guess I am just going to have to re-spin the board with proper protection.
As to the earthing/grounding issue, I have learned from you guys.
I did a design last year for an aircraft manufacturer, who in the spec insisted that the chassis MUST be isolated ( megohms @ 500V ) from any electrical circuit.
So I thought that was the best way.
« Reply #13 on: January 02, 2014, 06:09:26 18:09 »
I don't think there is anything wrong with isolated or floating circuits.  It just has to be thought about carefully when you have, or introduce other current paths (like a USB port, power brick ground etc.)
« Last Edit: January 02, 2014, 11:42:33 23:42 by Gallymimu » Logged
-Given: 231
-Receive: 983
« Reply #14 on: January 02, 2014, 07:19:09 19:19 »
I have read through this thread once more. And the more I think about it. It looks like some sort of a power supply problem to me. Perhaps it has transient problems releated to connection or disconnection of the power.
fpgaguy
-Receive: 166
« Reply #15 on: January 02, 2014, 09:21:54 21:21 »
one thing I found before is that sometimes you have JTAG device provide ground path, but the device you are working with has a different idea of ground level - so maybe check for potential between those two
especially if this problem only occurs near the time of jtag use / connection
second thing I would check is for spikey things coming from the power source, and then
where else in your system the cables run from this device - ie do they go near something that radiates something that can be coupled in - IE is the power switch wire acting like antenna
-Given: 834
-Receive: 4322
« Reply #16 on: January 02, 2014, 10:25:38 22:25 »
I second the power supply is the main reason, for your problems, if your still using the full length of low voltage lead.
Plus you don't say what device is controlling (relays.. high voltage.. motors)
As for JTAG failing, I read somewhere, it best to let the JTAG device power unit for program/debug or was it let unit supply the power, not to use two supplies.
Old_but_Alive
-Given: 746
-Receive: 120
« Reply #17 on: January 03, 2014, 07:59:27 07:59 »
@ everyone.
I really appreciate the time, effort and  brainpower being applied to this problem.
the power brick is a 19V/6amp being powered by 240v ac.
it does have heaters and stepper motors,and fans, but they are not on since the unit is not working properly.
there are several smps regulators in the the unit,  2 off 19V->12V @6A, mainly for the heaters and motorsand small 12V fans, plus the usual 12->5V->3.3v for the electronics.
I will check, but I thik that the Atmel JTAGICE MkII does not supply 3V3 to the unit. It actually reports back the units 3v3 voltage, and indeed wont JTAG program if its out of the range 1.6-3.6V.
I do believe that the power switch wiring and the red/green LED's wiring from the PCB to them is a problem, and I will fix that in a re-spin.
As I have several times, my main area of uncertainty is the earthing of the chassis to 0Volts of the electronics.
Its a plastic chassis with a poor spraying, and probably only 30% covered with BIG holes for airflow etc.
just re-looked at the schematic, I would love to post a section, but dare not without permission.
the 19V comes in on a connector, then into a common mode choke. across the input of the choke are 100nf/50v,10nf/50 v caps.
the connector  is a 10 pin , 2 pins connected to a gnd symbol ( which is the electronics 0volts), BUT the choke input/caps are connected to a 0v symbol.
so, i think that 0V symbol is connected to the chassis.  i need to really check  the overall wiring loom diagram to be sure on this.
sorry to be vague at the moment.
