March 12, 2026, 06:00:07 18:00
Author Topic: The simplest indicator of the audio signal  (Read 6779 times)
Catcatcat
-Given: 316
-Receive: 1878
« on: December 18, 2013, 05:23:15 17:23 »
Simple VU-meter with LEDs with integrated driver WS2812B
demo video
http://youtu.be/a_l2giyGSZQ
The project used a controller PIC12F1822. The project was implemented in MPLAB X IDE v1.95, the compiler Microchip MPLAB XC8 C Compiler V1.21
More details can be found on my website http://catcatcat.d-lan.dp.ua/samyiy-prostoy-indikator-urovnya-zvukovogo-signala/
I hope this project will be of interest/
project in the attachment
« Last Edit: December 19, 2013, 07:43:53 19:43 by metal » Logged
Curious
« Reply #1 on: October 26, 2015, 02:18:32 02:18 »
Interesting project. I love WS2812 LEDs.
The code you use to encode the pattern to program the WS2812 could be simplified a lot if you simply used a bit mask variable instead of doing a hardcoded binary test of every combination.
Instead, do something like:
unsigned char m;
for(....)
    m = 0b10000000;
    do {
        if ((temp & m) == m) {
            // code for outputting 1 to WS2812
        } else {
            // code for outputting 0 to WS2812
        // shift the bitmask to the right
        // after shifting 8 times, m will be 0
        m >>= 1;
    } while (m > 0);
This will result in much small code and it will also be a lot more efficient since you only need to test the mask once (in your code, you test it 8 times for each loop).
Hope this helps.
