leaveme
-Given: 38
-Receive: 15
« on: August 09, 2013, 11:39:47 11:39 » |
I have a situation where I need to convert the input PWM of 1V-3.5V to an output of 0V-5V and I use the schmitt trigger (74HC14) to do that. The output PWM then connected to PIC18F2520 for further processing. But I need to reduce the number of parts due to space constraints.
I would like to ask, can I do it by the PIC itself (without using a 74HC14) or any other thought?
« Last Edit: August 09, 2013, 11:42:03 11:42 by leaveme »
-Given: 834
-Receive: 4323
« Reply #1 on: August 09, 2013, 01:06:43 13:06 » |
have you tried direct input, logic level for low is 0 - 0.8 and a high 2.7 - 5volt average
opps I see your low is 1 volt.
can you add fet ?
« Last Edit: August 09, 2013, 01:09:47 13:09 by pickit2 »
leaveme
-Given: 38
-Receive: 15
« Reply #3 on: August 09, 2013, 01:42:31 13:42 » |
Just few more info about my project. The PWM is generated from the controller and converted using 74HC14. PIC then takes the PWM and drives two different devices. Unit-1 requires the the direct PWM but Unit-2 requires analog voltage. Here is the flow chart: |---- PWM1 ---> Control Unit-1 PWM (1V-3.5V) ---> 74HC14 (0V-5V) ---> PIC18F2520 --| |---- PWM2 --- RC filter ---> Control Unit-2 (Analog 0V-5V)
@pickit2: Fet can be added. But how about the switching time?
« Reply #4 on: August 09, 2013, 04:52:23 16:52 » |
switch time on a fet could be fine depending on how it's driven. At 50Hz I doubt you'd have a problem unless you need less than 1us latency (which I doubt since you are feeding it through a processor. You'll want a logic level low input capacitance FET.
Checksum8
-Given: 124
-Receive: 102
« Reply #5 on: August 09, 2013, 04:54:29 16:54 » |
That pic has two analog comparators. If these pins are available in your project it could be one solution. See data sheet
leaveme
-Given: 38
-Receive: 15
« Reply #6 on: August 09, 2013, 05:46:10 17:46 » |
Few more words please...
zab
-Receive: 58
« Reply #7 on: August 09, 2013, 07:05:29 19:05 » |
Comparator are used to compare the signal with a reference signal and out put is determined by this reference accordingly you can get high or low signal. If your input signal is higher than ref out put would be high If it is low then output would be zero. It is very simple. Just use these comparators to do the required job without converting the voltage level.
Checksum8
-Given: 124
-Receive: 102
« Reply #8 on: August 09, 2013, 07:09:35 19:09 » |
The PIc18F2520 has a "Comparator Module" which contains two analog comparators. The I/O pins are on portA. In your example you would feed the pulse train into the positive input of one of the comparators. On the negative input, a resistor voltage divider set to half of your 1v to 3.5v signal or about 2.25v. Every time the input crosses 2.25v the output of the comparator changes states. Now you have a 5 volt output. I have used these to 10khz so I doubt you will have any problems at 50hz. This module can also generate internal interupts on change. There is also an internal voltage reference, which may eliminate the need for external voltage divider. Read this to start http://ww1.microchip.com/downloads/en/DeviceDoc/41215c.pdf
« Last Edit: August 09, 2013, 07:20:47 19:20 by Checksum8 »
-Given: 496
« Reply #9 on: August 10, 2013, 12:10:17 00:10 » |
+1 use the analog feature (comparator) on the PIC.
leaveme
-Given: 38
-Receive: 15
« Reply #10 on: August 10, 2013, 05:33:20 05:33 » |
Thanks guys. So, you are suggesting me to use the internal comparator. Is it something like this: // CCS C
#define TEST_LED PIN_A4
// Trigger comparator INT on change #int_COMP void COMP_isr(void) { if(C1OUT == 1) output_high(TEST_LED); else output_low(TEST_LED); }
void main() { output_low(TEST_LED); // Turn off the LED initially
// Comparator input voltage is on pin A0, with internal // Vref, and inverted Comparator output. // The inversion is done so that when the input voltage // is greater than Vref, the comparator output will go high. setup_comparator(A0_VR_A1_VR | CP1_INVERT); // CM2:CM0 = 110, CMCON=0000 0110 setup_vref(VREF_LOW | 15); // Vref = 5v * (15/32) = 2.35v // Wait for the Comparator mode change delay_us(20);
clear_interrupt(INT_COMP);
enable_interrupts(INT_COMP); // Enable INT COMP enable_interrupts(GLOBAL); // Enable Global INT
while(1); }
« Last Edit: August 10, 2013, 05:46:13 05:46 by leaveme »
Catcatcat
-Given: 284
-Receive: 1654
« Reply #11 on: August 10, 2013, 08:08:51 08:08 » |
The logic levels, the same, you can simply connect directly
Vineyards
-Receive: 37
« Reply #12 on: August 10, 2013, 08:58:39 08:58 » |
Above suggestions will work unless there are no ground contention related problems (ground loops). I wouldn't connect an external signal to any of the pins of a microprocessor without employing some sort of isolation. Isolation necessitates additional components (DC-DC converters, digital/analog isolators or optocouplers).
If you avoid them your circuit may work on the bench but will probably fail in an industrial environment.
Signal
-Given: 113
-Receive: 81
« Reply #13 on: June 30, 2014, 03:28:16 15:28 » |
If noise immunity and isolation problems are not considering here then simple resistive divider is completely enough. No need of comparators or other level shifters. PIC18F2520 has TTL inputs too. From http://ww1.microchip.com/downloads/en/DeviceDoc/39631E.pdf: VIL = 0.8 V (D030A) VIH = 2 V (D040A) For 5/8 divider we have: 1 V -> 0.625 V, 3.5 V -> 2.18 V. Added Ohms and small overshot are not a problem if levels are stable enough and while 50 Hz gives a time even for light filtering.
« Reply #14 on: July 01, 2014, 03:24:38 03:24 » |
heh, you are a year late to this part!
