April 04, 2025, 02:02:16 02:02
Author Topic: Graphical LCD display module with Touch - advice needed  (Read 4321 times)
Codeman
-Given: 31
-Receive: 20
« on: August 09, 2013, 10:38:04 10:38 »
Dear All,
I'm in need to design a custom controller and I need a human interface with graphical display (can be color or mono) and can be 320x240 pixels or better. Must be at least 4.3 inch. I prefer with integrated bezel, but this is not a must...
Can anyone recommend a good supplier?
Thanks and BR
-Given: 841
-Receive: 4365
« Reply #1 on: August 09, 2013, 11:00:15 11:00 »
mikroe.com - mikroElektronika plus library to help start your coding.
bobcat1
-Given: 4378
-Receive: 96
« Reply #2 on: August 17, 2013, 01:04:27 13:04 »
Barre in mind that graphic TFT LCD with touch need lot of RAM memory from your micro
for instance 320 x 240 display need about 230 K of ram memory for 24 bit resolution
All the best
Bobi
Old_but_Alive
-Given: 767
-Receive: 121
« Reply #3 on: August 17, 2013, 02:30:27 14:30 »
have a look at the mikroE EVE stuff, it will save you a heap of time
http://www.mikroe.com/add-on-boards/display/connecteve/
and
http://www.mikroe.com/click/eve/
no bezel, but the interface is SPI
« Reply #4 on: August 18, 2013, 03:13:37 03:13 »
Optrex / Kyocera makes pretty easy to use stuff, though they are not the cheapest
T-55265GD057J-LW-ACN
Truly and Newhaven also make good stuff, but you have to get the touch screens separate with most of their displays (I think)
