April 04, 2025, 07:04:07 19:04
Pages: 1 [2]  All
Author Topic: rfid with more than 10cm distance. does it exists ?  (Read 16606 times)
eidtech
« Reply #25 on: September 28, 2013, 12:17:01 00:17 »
Do you have a link?  I'm very curious as I was looking for a longer range passive RFID system.  The antenna had to be a reasonable size (<1' wide) and the RFID tag had to be <1.5" wide (preferably smaller).
To get 3M (~10') range with a passive RFID tag, it seems a very large antenna and a high RF field strength would be required.
Zac...
http://www.ti.com/product/ri-trp-r9td With that transponder you can reach 2 or 3 meters. Obviously you need a large antena (1 meter per side aprox).
You can less distance with a small antena.
hef4015
-Given: 90
-Receive: 14
« Reply #26 on: October 14, 2013, 09:38:31 21:38 »
Smaller passive RFID tags are available with 13,56 MHz. The range can be extended by using amplifiers for the reader. The range could also be extended by using multiple antennas. The antennas are connected to the reader through some semiconductor switches.
This is just no project for a couple of days.  Cheesy
Switching between different antennas can extend the range.
Pages: 1 [2]  All
