cjack
-Given: 100
-Receive: 1557
« Reply #275 on: December 05, 2022, 05:21:02 05:21 » |
Version 5.113
cjack
-Given: 100
-Receive: 1557
« Reply #276 on: January 19, 2023, 05:22:44 05:22 » |
Version 5.114
Eddy71
-Given: 35
« Reply #277 on: January 28, 2023, 10:51:43 10:51 » |
In this version the key generator been not changed?
tanveerriaz
-Given: 51
-Receive: 410
« Reply #278 on: January 28, 2023, 11:42:02 11:42 » |
SCG-PCWHD-keygen working this ver.
despic
« Reply #279 on: March 23, 2023, 08:22:00 08:22 » |
Version 5.114 has problems with the use of the SPI module, apparently with the most recent PICs, for example with the PIC18F16Q41, I hope that problem will be solved with version 5.115
jellybean442
-Given: 131
-Receive: 47
« Reply #280 on: March 25, 2023, 09:30:29 09:30 » |
The release notes for 5.115 mention a couple changes relating to SPI, but I don't know if that covers your specific issue. 5.115 Fixed some header file defines for PIC16F180xx family. 5.115 Fixed the PCD #use rs232() when using the transmit buffer to not lose some characters. 5.115 Fixed an issue with setup_vref() function for PIC18F67J11 family. 5.115 Updated #use spi() for PIC18F45K50 family so the alternate HW DO pin can be used with it. 5.115 Updated how #use spi() sets up the SPI baud rate when using HW SSP peripheral on some PIC16/18 parts. 5.115 #opt compress now excludes functions with #asm as-is.
cjack
-Given: 100
-Receive: 1557
« Reply #281 on: March 25, 2023, 09:53:26 09:53 » |
Version 5.115
cjack
-Given: 100
-Receive: 1557
« Reply #282 on: October 12, 2023, 05:00:43 17:00 » |
Version 5.116
ero
-Receive: 30
« Reply #283 on: October 13, 2023, 06:32:58 06:32 » |
I kindly ask to someone upload again the SCG-PCWHD-keygen which is not exist anywhere. I checked the forum I found some links but they are already dead.
Thanks Ero
fofo
-Receive: 60
« Reply #284 on: October 13, 2023, 10:44:09 10:44 » |
SCG-PCWHD-keygen-105
ero
-Receive: 30
« Reply #285 on: October 13, 2023, 01:54:36 13:54 » |
Thank you but I can not load that one which is full trojan inside.
ero
giappolo
-Given: 1710
-Receive: 620
« Reply #286 on: October 13, 2023, 04:45:34 16:45 » |
Tested with Norton 360, file is good
patchjack
-Given: 11
-Receive: 54
« Reply #287 on: October 14, 2023, 08:30:14 08:30 » |
How to use the keygen?
forter
-Given: 1100
-Receive: 28
« Reply #288 on: October 14, 2023, 08:38:44 08:38 » |
Kaspersky finds nothing!
-Given: 841
-Receive: 4364
« Reply #289 on: October 14, 2023, 09:32:51 09:32 » |
open keygen input Name <username> input Company <anything> select where the 4 licence *.crg files will generated keygen will generate the 4 codes & close
sphinx
-Given: 622
-Receive: 283
« Reply #290 on: October 14, 2023, 10:28:16 10:28 » |
Just wondering if anything has changed in 116 version since in XP it says not valid x32 application. i did have a look at their website but cant find info on it
thnax in advance
sphinx
-Given: 622
-Receive: 283
« Reply #291 on: November 04, 2023, 08:48:29 08:48 » |
i am answering my question on this one, the installer seems to be changed and not installing on xp but working on 7 i copied installed files to xp and software doesnt complain.
i have compiled some tiny program files and those seems to work in proteus simulation.
/sphinx
p.s. perhaps time to upgrade to w7 from xp.
despic
« Reply #292 on: March 17, 2024, 07:41:09 19:41 » |
The new version v5.117 is now available, for those of us who had problems with the SPI of the new PIC18... it seems that this version will solve it!
PIC_dude
-Given: 24
« Reply #293 on: April 01, 2024, 09:40:07 09:40 » |
Can you put the link? Or maybe cjack? Please!
jellybean442
-Given: 131
-Receive: 47
« Reply #294 on: May 03, 2024, 05:56:33 05:56 » |
The v5.117 release looks like the usual... fix one problem and bury it in a bunch of minor changes. lol From their newsletter:
Recent changes include: 5.117 IDE COMPILER > CLEAN function now deletes .hex files. .ccspjt files are are NOT deleted 5.117 Improved RTOS error message added when a task is not defined. 5.117 Updated Debugger not showing RAM for parts with more than 64K RAM. 5.117 Fixed the USE RS232 receive_buffer= option when used with over 4K RAM. 5.117 Fixed spi_read() function to properly wait on newer PIC 18 devices when a parameter is passed to it to clock out. 5.117 Updated i2c_slaveaddr() function to update all slave address registers for newer PIC18 devices. 5.117 #pin_select now accepts PORTF pins on the dsPIC33CK1024MP710 family. 5.117 All CN pins are now available for PIC24FJ64GB106, PIC24FJ64GB108 and PIC24FJ64GB110 devices. 5.117 Updated PCD Wizard TCP/IP to fix an issue with displaying web pages on some parts.
New: PIC16F17154 New: PIC16F17155 New: PIC16F17156 New: PIC16F17174 New: PIC16F17175 New: PIC16F17176 New: PIC16F18154 New: PIC16F18155 New: PIC16F18156 New: PIC16F18174 New: PIC16F18175 New: PIC16F18176 Updated: PIC24FJ64GB106 Updated: PIC24FJ64GB108 Updated: PIC24FJ64GB110
cjack
-Given: 100
-Receive: 1557
« Reply #295 on: May 31, 2024, 04:48:32 16:48 » |
Sorry for the delay  Version 5.117, just for Sonsivri friends
Wilksey
-Given: 162
-Receive: 2550
« Reply #296 on: May 31, 2024, 05:13:52 17:13 » |
I tried installing over the top of 5.116 but it keeps giving me an error?Ignore this, it was a PEBKAC error, not enough coffee! Works fine (with anti virus on)
« Last Edit: June 01, 2024, 10:28:24 22:28 by Wilksey »
patchjack
-Given: 11
-Receive: 54
« Reply #297 on: June 01, 2024, 06:41:40 06:41 » |
Sorry for the delay  Version 5.117, just for Sonsivri friends  I am in china, where can’t visit mega disk. Can you upload it to Baidu Super Network Disk?
mick
-Given: 2102
-Receive: 122
« Reply #298 on: June 01, 2024, 08:25:26 20:25 » |
Hello China
try this link
Posted on: June 01, 2024, 08:23:06 20:23 - Automerged
Installing over 5.116 working OK for me... turn off antivirus...
patchjack
-Given: 11
-Receive: 54
« Reply #299 on: June 02, 2024, 01:57:23 01:57 » |
Hello China
try this link
It can’t download too. Thank you still.
