voltas5
-Given: 103
-Receive: 83
« Reply #125 on: April 18, 2015, 07:23:50 07:23 » |
5.045 Another version and some more fixes from CCS
5.045 #locate now issues a warning if you locate a variable on top of another 5.045 A PIC24 problem with the < and > operators on floats with interrupts is fixed 5.045 A problem with multiple compilation units and some static variables not being zeroed is fixed 5.045 A warning in string.h has now been eliminated 5.045 A bug allocating multiple odd sized rom structures in PIC24 is fixed
Updated: PIC12F1571 Updated: PIC12F1572 New: PIC16F1574 New: PIC16F1575 New: PIC16F1578 New: PIC16F1579 New: PIC16F1764 New: PIC16F1765 New: PIC16F1768 New: PIC16F1769
« Last Edit: April 18, 2015, 08:10:50 08:10 by voltas5 »
duende_azul
-Given: 117
-Receive: 1262
« Reply #126 on: April 21, 2015, 04:19:27 04:19 » |
Version 5.045
« Last Edit: July 22, 2015, 11:30:03 23:30 by duende_azul »
voltas5
-Given: 103
-Receive: 83
« Reply #127 on: May 22, 2015, 06:05:50 06:05 » |
A new release of the CCS C compiler for PICmicro(r) microcontrollers has been released. The new version is: 5.046
Recent changes include: 5.046 Fixed an problem with -> where the target was a bit field of another structure on PCM parts 5.046 An IDE issue with error files kept outside the project directory is fixed 5.046 A wrong checksum in "#ID checksum" when using #fill_rom is fixed 5.046 A PIC24 problem with oversized printf widths on %LU and %LD is fixed 5.046 Support for auto clock tuning is added for chips that have this feature 5.046 A #USE RS232 bug is fixed when buffers larger than 256 are specified
Updated: PIC16F1614 Updated: PIC16F1615 Updated: PIC16F1618 Updated: PIC16F1619
« Last Edit: May 22, 2015, 12:10:40 12:10 by voltas5 »
duende_azul
-Given: 117
-Receive: 1262
« Reply #128 on: May 23, 2015, 10:24:59 22:24 » |
CCS 5.046 Last version.. again..
« Last Edit: July 22, 2015, 11:30:47 23:30 by duende_azul »
voltas5
-Given: 103
-Receive: 83
« Reply #129 on: June 20, 2015, 11:31:02 11:31 » |
------------------------------------------------------------------------------------------------ CUSTOM COMPUTER SERVICES, INC. ------------------------------------------------------------------------------------------------
A new release of the CCS C compiler for PICmicro(r) microcontrollers has been released. The new version is: 5.047
Recent changes include: 5.047 A bug converting some floating point numbers just below zero to an integer is fixed. 5.047 A bug with 32 bit enum's is fixed 5.047 A problem with the 1705 comparator is fixed 5.047 IDE mouse-over improved for structures and ROM variables
New: PIC16C99 Updated: PIC16F1503
duende_azul
-Given: 117
-Receive: 1262
« Reply #130 on: June 23, 2015, 07:35:19 19:35 » |
5.047
« Last Edit: July 22, 2015, 11:31:25 23:31 by duende_azul »
CHJAY
-Given: 483
-Receive: 155
« Reply #131 on: June 27, 2015, 07:14:52 07:14 » |
A new release of the CCS C compiler for PICmicro(r) microcontrollers has been released. The new version is: 5.048
Recent changes include: 5.048 Compiler now does type checking on EXTERNs 5.048 A compiler IDE hang problem with some complex structures is fixed
duende_azul
-Given: 117
-Receive: 1262
« Reply #132 on: June 28, 2015, 02:54:12 14:54 » |
Version 5.048
« Last Edit: July 22, 2015, 11:31:58 23:31 by duende_azul »
voltas5
-Given: 103
-Receive: 83
« Reply #133 on: September 09, 2015, 06:16:27 06:16 » |
CURRENT SOFTWARE VERSIONS
Version 5.049 RECENT CHANGES
5.049 Added support for the new and different 24 bit GS chips and the 16F183xx chips 5.049 A problem with PIC24 function pointers inside a structure in large memory spaces is fixed 5.049 Debugger issue with some floating point numbers is fixed 5.049 Fixed a bug involving signed ints in a switch statement 5.049 An inline assembly error when using an indirect goto is fixed 5.049 Debugger now shows a full 32 bit enum as it should
Updated: PIC12F1840 Updated: PIC12LF1840T39A Updated: PIC12LF1840T48A Updated: PIC16F1619 New: PIC16F18313 New: PIC16F18323 New: PIC16F18324 New: PIC16F18325 New: PIC16F18344 New: PIC16F18345 Updated: PIC18F85J94
« Last Edit: September 09, 2015, 08:26:51 08:26 by voltas5 »
younder
« Reply #134 on: September 13, 2015, 03:10:43 15:10 » |
Can anyone share the link for 5.049?
duende_azul
-Given: 117
-Receive: 1262
« Reply #135 on: September 21, 2015, 09:27:22 21:27 » |
Last version: 5.049
voltas5
-Given: 103
-Receive: 83
« Reply #136 on: October 02, 2015, 06:18:53 06:18 » |
Version 5.050 RECENT CHANGES
5.050 Support for the new 4x chips is in 5.050 An incorrect warning concerning enum assignments is removed 5.050 A linker bug that sometimes combined global variables with the same name is fixed 5.050 Added USB and TCP/IP wizards for 24 bit parts 5.050 Fixed a bug in #USE PWM for parts with more than 6 remappable OC pins 5.050 Added a PLL_WAIT option to #use delay to wait for the PLL to start up 5.050 Fixed a bug in tx_buffer_available() where the wrong count was returned 5.050 Fixed a bug when negative number were used with %W on 24 bit parts 5.050 Added a feature to use OSCTUNE on 24 bit parts to get the requested clock speed
Updated: PIC16F1705 Updated: PIC16F1782 Updated: PIC16F1783
« Last Edit: October 03, 2015, 06:30:51 06:30 by voltas5 »
duende_azul
-Given: 117
-Receive: 1262
« Reply #137 on: October 05, 2015, 05:50:24 17:50 » |
last version...
voltas5
-Given: 103
-Receive: 83
« Reply #138 on: October 23, 2015, 06:05:29 06:05 » |
Version 5.051 RECENT CHANGES A new release of the CCS C compiler for PICmicro(r) microcontrollers has been released. The new version is: 5.051
Recent changes include: 5.051 A linker bug affecting multiple compilation unit builds is fixed 5.051 A segmentation fault for some Linux compiles is fixed 5.051 An optimization error involving << with mixed byte and dword operands is fixed 5.051 Fixed a syntax error with spi_write4() and spi_read4() functions for 24 bit parts 5.051 Fixed a syntax error with #pin_select for some PIC18 devices 5.051 Fixed a bug when #opt compress is used on some programs 5.051 Fixed an issue with #use pwm and MCP1911x devices 5.051 The 24 bit Wizard now has a MODBUS configuration page
Updated: PIC16F1503
duende_azul
-Given: 117
-Receive: 1262
« Reply #139 on: November 09, 2015, 09:20:16 21:20 » |
Finally... new last versión... 5.051
voltas5
-Given: 103
-Receive: 83
« Reply #140 on: December 24, 2015, 05:13:11 05:13 » |
A new release of the CCS C compiler for PICmicro(r) microcontrollers has been released. The new version is: 5.052
Recent changes include: 5.052 Variable length argument functions now allow a single parameter 5.052 A bug with some 16 bit additions done in a call to spi_write() has been fixed 5.052 A problem with the bit order in lcd_symbol() when used with 16 bit segments is fixed
Updated: PIC16F505 Updated: PIC16F1829 Updated: PIC18F25K80 Updated: PIC18F26K80 Updated: PIC18F45K80 Updated: PIC18F46K80 Updated: PIC18F65K80 Updated: PIC18F65J94 Updated: PIC18F66K80 Updated: PIC18F66J94 Updated: PIC18F66J99 Updated: PIC18F67J94 Updated: PIC18F85J94 Updated: PIC18F86J94 Updated: PIC18F86J99 Updated: PIC18F87J94 Updated: PIC18F95J94 Updated: PIC18F96J94 Updated: PIC18F96J99 Updated: PIC18F97J94 Updated: PIC16F1773 Updated: PIC16F1776
CHJAY
-Given: 483
-Receive: 155
« Reply #141 on: January 04, 2016, 12:55:15 12:55 » |
A new release of the CCS C compiler for PICmicro(r) microcontrollers has been released. The new version is: 5.052 <- should be 5.053?
Recent changes include: 5.053 A corrupted device database in the V5.052 release is fixed
duende_azul
-Given: 117
-Receive: 1262
« Reply #143 on: January 07, 2016, 02:50:42 02:50 » |
New year, new version... 5.053
voltas5
-Given: 103
-Receive: 83
« Reply #144 on: January 22, 2016, 05:00:13 05:00 » |
« Last Edit: February 04, 2016, 06:51:18 06:51 by voltas5 »
voltas5
-Given: 103
-Receive: 83
« Reply #145 on: February 04, 2016, 06:51:39 06:51 » |
voltas5
-Given: 103
-Receive: 83
« Reply #146 on: March 02, 2016, 10:00:00 10:00 » |
cjack
-Given: 100
-Receive: 1523
« Reply #147 on: March 14, 2016, 06:01:31 18:01 » |
Version 5.056
Old_but_Alive
-Given: 744
-Receive: 120
« Reply #148 on: March 14, 2016, 06:13:53 18:13 » |
anyone got a link that doesnt require login/signup/generalaccount rubbish
ratovarius
-Given: 1197
-Receive: 180
« Reply #149 on: March 15, 2016, 08:08:57 20:08 » |
same last file in mega, 5.056
