MikroC + USB + some more stuff - Sonsivri
May 14, 2026, 12:14:48 00:14
Author Topic: MikroC + USB + some more stuff  (Read 12761 times)
Bobbla
-Receive: 16
« on: April 29, 2013, 01:39:58 01:39 »
Hallo again, I'm working on a small project in where I am building a small device(for sampling ADC) and a windows application(for viewing samples and stuff). But at the moment I'm looking for help.
The device is a small PIC18F24J50, a MCP1802 (3.3V) LDO and some other components(crystal,resistor,capacitor). Hopefully it will be powered by the USB when its done.
Problem: At the moment I'm having problems making the USB work in proteus. (I'm using mikroC PRO for Pic 6.0.0 and proteus 7.10 (but think its with some 7.11 stuff attached..))
The simulation log shows some messages, among other these:
[PIC18 USB] PC=0x167A. SETUP when BD is not owned by SIR
USB device initialization failed.
The simulation also crashes sometimes...... not sure what that is about.
I've looked for a solution, but found none.
So I'll attach some code and schematics now.
And hope that a solution will be found.
Hope thats enough info..  Thanks
-Receive: 4459
« Reply #1 on: April 29, 2013, 02:27:19 02:27 »
for error "USB device initialization failed.
did you install virtual usb driver?
« Last Edit: April 29, 2013, 02:34:10 02:34 by pickit2 » Logged
Bobbla
-Receive: 16
« Reply #2 on: April 29, 2013, 03:32:15 03:32 »
As far as I can tell I've installed it... :/  I tested some of the proteus samples and they worked. Is there any way to check for sure?
(Also, attached an image of my somewhat different USB analyzer..)
btw, 3000 posts... you've been busy!
-Given: 405
-Receive: 545
« Reply #3 on: April 29, 2013, 05:12:17 05:12 »
 Shocked  1/2 of those were mutes  Grin
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #4 on: April 29, 2013, 03:40:22 15:40 »
Bobbla,
can you post the source that generated the object code in the problem area 167A
Ignore the message about D+ and D-.
I guess BD is buffer descriptor and maybe SIR is a typo and should be SIE - USB Serial Interface Engine
Have you successfully ran any of the Proteus USB demos?
Rgds George
« Last Edit: April 29, 2013, 03:44:31 15:44 by towlerg » Logged
Win 7 Ult x64 SP1 on HP2570p
Bobbla
-Receive: 16
« Reply #5 on: April 30, 2013, 03:29:05 03:29 »
Code and schematics is inside the Derp.zip file which you can find in the first post.
sure about "typo".. I use a function that comes with mikroC..
I've successfully ran both the MSD and HID samples/demos that are found in PICDEM FS USB folder.
btw pickit2, I'm under the impression that you got this working no problem... so what did you do??? Did you extract the schematics, run the simulation and use the hex as was, or did you recompile? what?
also, I'm using windows server 2008 R2 standard which is a 64 bit OS... I know there used to be a problem with 64 bit OS's and the virtual USB, but I think that was solved and I've successfully ran some USB samples as stated previously....  Huh
-Receive: 4459
« Reply #6 on: April 30, 2013, 03:56:57 03:56 »
Have you tried a later version of proteus usb 64bit drivers from labcenter,
No I just ran your files without usb drivers installed, even with drivers it failed getting descriptor. (Only have a party patched proteus 8, I don't have a fully working proteus here)
USB device initialization failed, it looks like it don't get a valid value.
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #7 on: April 30, 2013, 06:21:41 06:21 »
Sorry, didn't see that.
If it is a typo, then it's in Proteus. Just a guess mind.
I ran your HEX on Win 7 x86 and Proteus 7.10 and it ran.
A USB Input Device was created in the HID section.
Rgds  George
« Last Edit: April 30, 2013, 06:24:26 06:24 by towlerg » Logged
Bobbla
-Receive: 16
« Reply #8 on: April 30, 2013, 08:02:11 20:02 »
SO I guess we can conclude that the code is working then... leaving proteus as the most likely fault. Could you tell me where you got your Proteus from? I've got 7.10SP0 (Build 12325) with advanced simulation according to the About window. Wonder if there is something wrong with the medicine... or me.
Edit: not sure what a "party" version is.. but everyone here seems to have made it further then me. And yes I've tried to install the newest/one virtual usb install file I found on labcenters webpage.. not much happened.
« Last Edit: April 30, 2013, 08:06:45 20:06 by Bobbla » Logged
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #9 on: May 01, 2013, 06:00:56 06:00 »
Wow, I wouldn't go that far.
The sticky in the "Proteus 7.9sp1 - 7.1x (Work in Progress) Nemo patch" thread. Plus pickit2's reply #104 and LithiumOverdosE's reply #133, all from the same thread. Note that I am running Win 7 x86 ult not virtualised.
I don't know either, maybe partly?
Rgds George
