January 11, 2025, 08:09:25 20:09
Author Topic: (help) push button not working  (Read 6443 times)
yugal
 Warned
-Given: 919
-Receive: 73
« on: April 21, 2013, 07:20:03 19:20 »
hi
am new to micro controller programming
this is my first code but pbup pbdn not working . please help to correct this
'* Notes : Ic pic16F676 COMPILIER PBP2.60
@ DEVICE pic16F676
@ DEVICE pic16F676, WDT_OFF
@ DEVICE pic16F676, PWRT_ON
@ DEVICE pic16F676, PROTECT_ON
@ DEVICE pic16F676, MCLR_OFF
@ DEVICE pic16F676, INTRC_OSC_NOCLKOUT
TRISA = %011000
TRISC = %000000
SEQ VAR BYTE
LED1 VAR PORTC.0
LED2 VAR PORTC.1
LED3 VAR PORTC.2
LED4 VAR PORTC.3
LED5 VAR PORTC.4
LED6 VAR PORTC.5
LED7 VAR PORTA.0
LED8 VAR PORTA.1
LED9 VAR PORTA.2
LED10 VAR PORTA.5
PBUP VAR PORTA.3
PBDN VAR PORTA.4
SEQ = 4
PORTC = 0
PORTA = 0
CMCON = 7
ANSEL = 0
LOOP:
IF PBUP = 0 THEN UPP
IF PBDN = 0 THEN DNN
PAUSE 50
GOSUB ACTIONS:
GOTO LOOP
UPP:
IF SEQ = 1 THEN RRT
SEQ = SEQ + 1
PAUSE 50
GOTO RRT
DNN:
IF SEQ = 7 THEN RRT
SEQ = SEQ - 1
PAUSE 50
RRT : RETURN
ACTIONS:
IF SEQ = 1 THEN
LED1 = 1 :LED2 = 0 :LED3 = 0 :LED4 = 0 :LED5 = 0 :LED6 = 0 :
LED7 = 0 :LED8 = 0 :LED9 = 1 :LED10 = 1 :
ENDIF
IF SEQ = 2 THEN
LED1 = 0 :LED2 = 1 :LED3 = 0 :LED4 = 0 :LED5 = 0 :LED6 = 0 :
LED7 = 0 :LED8 = 1 :LED9 = 0 :LED10 = 1 :
ENDIF
IF SEQ = 3 THEN
LED1 = 0 :LED2 = 0 :LED3 = 1 :LED4 = 0 :LED5 = 0 :LED6 = 0 :
LED7 = 0 :LED8 = 1 :LED9 = 1 :LED10 = 0 :
ENDIF
IF SEQ = 4 THEN
LED1 = 0 :LED2 = 0 :LED3 = 0 :LED4 = 1 :LED5 = 0 :LED6 = 0 :
ENDIF
IF SEQ = 5 THEN
LED1 = 0 :LED2 = 0 :LED3 = 0 :LED4 = 0 :LED5 = 1 :LED6 = 0 :
ENDIF
IF SEQ = 6 THEN
LED1 = 0: LED2 = 0:LED3 = 0 :LED4 = 0 :LED5 = 0 :LED6 = 1 :
ENDIF
IF SEQ = 7 THEN
LED1 = 0 :LED2 = 0 :LED3 = 0 :LED4 = 0 :LED5 = 0 :LED6 = 0 :
LED7 = 1 :LED8 = 0 :LED9 = 1 :LED10 = 1 :
ENDIF
PAUSE 50
RETURN
 please correct
                  yugal
Catcatcat
-Given: 285
-Receive: 1673
« Reply #1 on: April 21, 2013, 07:45:08 19:45 »
Here are some examples of work with buttons connected directly to the port. http://catcatcat.d-lan.dp.ua/en/skachat/primeryi-postroeniya-koda-programm-dlya-pic-kontrollerov/tsifrovoy-vvod-dannyih/ in an attachment to the project site.
« Reply #2 on: April 21, 2013, 08:24:14 20:24 »
I'm not a code jockey, but it looks to me like you are reading a different port A bit for up vs down....
PBUP VAR PORTA.3
PBDN VAR PORTA.4
If you indeed have two buttons, then it's fine. But shouldn't these be changed from
to
IF PBUP = 0 THEN GOSUB UPP
IF PBDN = 0 THEN GOSUB DNN
-Given: 496
« Reply #3 on: April 22, 2013, 05:15:57 05:15 »
Did you put a couple of pullup resistors on the buttons?
I believe PORTA does not have internal pullups.
robotai
-Given: 27
-Receive: 23
« Reply #4 on: April 22, 2013, 09:08:27 09:08 »
I supposed you have two buttons, one for up action and another for down action.
The code here seems not correct because it just "Jump", not calling routine.
LOOP:
PAUSE 50
GOSUB ACTIONS:
GOTO LOOP
I supposed what you want may be this.
LOOP:
PAUSE 50
GOSUB ACTIONS:
GOTO LOOP
UPP:
IF SEQ >= 7 THEN RRT
SEQ = SEQ + 1
PAUSE 50
GOTO RRT
DNN:
IF SEQ <= 1 THEN RRT
SEQ = SEQ - 1
PAUSE 50
RRT : RETURN
1. Without the "GOSUB", your code won't return properly.
2. Seems you are doing actions based on SEQ from 1 to 7, the original "UPP" and "DNN" actions may be wrong.
Do you confirm your code writing into chip and running?
« Last Edit: April 22, 2013, 09:21:48 09:21 by robotai » Logged
gan_canny
-Given: 101
-Receive: 26
« Reply #5 on: April 22, 2013, 12:32:08 12:32 »
Well nearly all buttons ( switches) are mechanical so they will bounce. Code must be crafted to allow for the bounce. The bounce in momentary but the CPU can read an input fast enough to experience bouncing. Often a delay is introduced after the input first sees the button pressed and a reread after the delay that spans the bounce to confirm it is truly pressed. Proteus simulations since they are no more than an artists sketch of the real world will often have ideal buttons and switches that don't oscillate ( bounce) before settling into the final state. Since you are utilizing both states of the button (up and down) a bounce during a down will be seen as an up etc.
« Last Edit: April 22, 2013, 12:34:40 12:34 by gan_canny » Logged
« Reply #6 on: April 22, 2013, 03:56:34 15:56 »
gan_canny: the delay is there, inside the switch state scanning loop, for debounce:
LOOP:
PAUSE 50
GOSUB ACTIONS:
GOTO LOOP
While he may need to tune the value of 50, the code is fine there.
yugal
 Warned
-Given: 919
-Receive: 73
« Reply #7 on: April 22, 2013, 05:46:53 17:46 »
Hi, now  real hardware push button is active. this is my mistake , i am not using gosub  command.
 many thanks to solutions,Parmin,robotai,catcatcat and gen_canny for help.permin yes i am using pullup resistors on the buttons
        yugal
Checksum8
-Given: 124
-Receive: 102
« Reply #8 on: April 25, 2013, 04:11:28 16:11 »
Try using the "Button" command. It debounces the switch and allows for other options
See their web page for the online manual.
BUTTON Pin, Down, Delay, Rate, Var, Action, Label
Performs debounce and auto-repeat on Pin:
Pin  Pin number (0..7).
Down  State of pin when button is pressed (0..1).
Delay  Cycle count before auto-repeat starts (0..255). If 0, no debounce or auto-repeat is performed. If 255, debounce, but no auto-repeat, is performed.
Rate  Auto-repeat rate (0..255).
Var    Byte variable used for delay/repeat countdown. Should be initialized to 0 prior to use.
Action  State of button to perform GOTO (0 if not pressed, 1 if pressed).
Label  Execution resumes at this label if Action is true.
hondadave
-Given: 11
« Reply #9 on: May 25, 2013, 03:10:53 15:10 »
Just installed mine works perfect many thanks!
