April 01, 2025, 11:01:15 23:01
Author Topic: ProfiCAD - All versions  (Read 15645 times)
acat_lm
-Given: 73
-Receive: 128
« on: January 29, 2010, 10:52:38 10:52 »
New version: v.5.6.3
Link:
http://depositfiles.com/files/pifdqx955
Password: sonsivri
« Last Edit: October 21, 2013, 07:51:18 19:51 by pickit2 » Logged
egstudio
-Given: 1262
-Receive: 12224
« Reply #1 on: April 16, 2013, 09:45:00 21:45 »
Proficad 7.5
ProfiCAD is the quickest and easiest way to create electrical documentation and schematic diagrams. Although it is very easy to learn and use, it is a professional tool used by a wide range of customers.
Features of ProfiCAD - electrical diagrams editor
• easy to learn and use - just drag symbols onto the drawing
• low system requirements - runs on any PC with Windows 2000 and higher
• supports Unicode - can use any language, any technical symbol
• ships with cca 700 symbols - new symbols can be easily created
• downloads quickly, installs quickly, starts quickly, takes 5MB on hard drive and can be run from a flash drive
• automatic update - always have the latest version
• continuous numbering of symbols
• intelligent renumbering of symbols when copying
• automatic save - saves your documents automatically
• generates netlist and bill of material
• generates list of wires and calculates total of lengths
• title blocks editor - create your owns for easy reuse
OneZero
-Given: 183
« Reply #2 on: April 18, 2013, 09:09:45 09:09 »
Tested on Win XP SP3 ---> OK
Tested on Win 7 x 32 ---> not working
you've tried it on windows 7?
Magnox
-Given: 990
-Receive: 285
Oink!
« Reply #3 on: April 18, 2013, 07:09:42 19:09 »
Doesn't run on Windows 7 x64 (no error, just doesn't run), and I'm not sure it works properly on Windows XP SP3.
On XP, the app starts with an error 'the application failed to initialise properly'. Apparently it is caused by proficad chaining 'profiaux.exe' in the lib subdirectory. That file can be renamed to stop the error.
Also, the patch leaves an executable proficad of only about 2MB, when the original is over 5MB. Seems a bit unusual.
egstudio
-Given: 1262
-Receive: 12224
« Reply #4 on: September 14, 2014, 11:32:03 23:32 »
Proficad 8.1.1 + crack
biko4710
-Given: 45
-Receive: 40
« Reply #5 on: September 16, 2014, 05:29:33 17:29 »
This version doesn't run on Win7x64 either.
Original version runs, but medicined version starts and ends without any notification.
VirusTotal says: Detection ratio:    3 / 55 : Packed/PECompact
Further investigation shows that the medicined version starts WerFault.exe, which is part of the Windows Error Reporting to track down errors relating to the operating system.
I tried starting it with different compatibility modes, but no luck.
It's bad medicine.
« Last Edit: September 16, 2014, 11:47:27 23:47 by biko4710 » Logged
egstudio
-Given: 1262
-Receive: 12224
« Reply #6 on: May 18, 2019, 11:43:00 11:43 »
ProfiCAD 10.3 Multilingual
- 05-2019
https://www.proficad.com/news.aspx
egstudio
-Given: 1262
-Receive: 12224
« Reply #7 on: September 22, 2019, 01:48:07 01:48 »
ProfiCAD 10.3.2 Multilingual - 09-2019
What's new:
egstudio
-Given: 1262
-Receive: 12224
« Reply #8 on: October 05, 2019, 03:44:08 03:44 »
ProfiCAD 10.3.4 Multilingual - 10-2019
What's new:
alm555
-Receive: 117
« Reply #9 on: April 10, 2021, 10:12:58 10:12 »
ProfiCAD 11 Multilingual
