December 21, 2024, 01:56:23 13:56
Author Topic: CutViewer Mill 3.2 & CutViewer Turn 3.2  (Read 8388 times)
gmua
-Receive: 88
« on: April 15, 2013, 09:58:02 21:58 »
CutViewer is an easy-to-use program that simulates 2, 2-1/2 and 3 axis CNC Machines removing material from Stock in true Solid modeling. Using CutViewer will increase your productivity, all but eliminate programming errors, and prevent machine down time while debugging. Powerful, easy-to-use tools allow you to debug errors in the toolpath, detect collision of the tool with material stock while rapiding, and estimate machining time. CutViewer can be customized to support a wide variety of machines.
hosmis
-Given: 335
-Receive: 243
« Reply #1 on: April 15, 2013, 11:46:40 23:46 »
Thank you .
I would recommend , cimco edit 6
http://www.cimco.com/product_edit_screenshots.php3
gmua
-Receive: 88
« Reply #2 on: April 16, 2013, 03:05:29 03:05 »
I tried CutViewer Mill 3.2 in a 32 bit Windows XP installation (My CNC Computer) and the medicine work fined, but I am having no luck with Windows 7 64 bit (My Main Computer).
Sorry about that...  Sad
Let me know if it works for any of you.
UPDATE: Read Reply #4 from pickit2, it worked perfectly.
« Last Edit: April 16, 2013, 05:23:00 17:23 by gmua » Logged
-Given: 835
-Receive: 4330
« Reply #3 on: April 16, 2013, 08:12:33 08:12 »
@ jmua use compatibility mode for windowsXP (also set to use in admin mode)
@ Jum password is ok, cut&paste it
gmua
-Receive: 88
« Reply #4 on: July 09, 2013, 06:51:19 18:51 »
Thanks for the recommendation hosmis, I finally had the time to try out CIMCO Edit 6, and let me tell you that I liked it a lot (I am probably going to stop using CutViewer).
For anyone interested, check it out here.
