December 21, 2024, 02:02:41 14:02
Author Topic: Indexer 3.x plus serial  (Read 4652 times)
-Given: 835
-Receive: 4330
« on: April 11, 2013, 11:48:48 11:48 »
Timing Pulleys Made Easy
With this New Version 3.1.0  Low Cost software you can create a Gcode file to.
http://www.cad2gcode.com/pulley/
Note: Program does not cut the Profile.
•Cut these popular Timing Pulleys from the Top using an Endmill or Fly cut from the Side with a form tool.
•.080MXL  .200XL  .375L  3mmHTD  5mmHTD  5mmT 10mmT  T2.5mm
•Cut shapes like Hex ,Square, etc.
•Drill any # of Holes around the Diameter.
•Calculate the Belt Length and Teeth required for the Pulley's Center used.
•Calculate the # of Teeth for the Ratio you want.
•Saves your last Mill settings to a File.
•Calculate 4th Axis Motor Tuning Steps for Mach3 Mill.
•Save on the cost of buying special Timing Pulleys.
•Runs in Windows 2000, XP, Vista and Windows 7
What is needed?
A CNC 4th Axis Rotary table and Cutting tools.
If you don't have a 4th Axis on your Mill or Router.
Get some ideas on how to make one at.
http://www.cad2gcode.com/cncprojects
Download link & serial in readme.txt
