November 28, 2024, 06:49:39 18:49
Pages: [1] 2  All
Author Topic: Can we make SD Card reader using PIC18F2550??  (Read 17022 times)
xpress_embedo
-Given: 122
-Receive: 254
« on: April 10, 2013, 02:39:07 02:39 »
Hello!! Everyone.
In proteus samples section, i had seen one mass storage device example using PIC18F4550.
But now the Microchip Application Libraries doesn't support this project.
So can we make a Mass Storage Device SD card Reader using PIC18F4550 or PIC18F2550.
As i saw one project in Microchip Application Library USB Section, which shows MSD but for internal flash of PIC18F4550.
But i need to do it for SD Card.
Is it possible??
If yes then suggest me how can i do this.
-Given: 496
« Reply #1 on: April 10, 2013, 03:14:33 03:14 »
I believe PIC18 starter kit would include such example.
You should be able to download the codes and schematic from Microchip.
happylex
« Reply #2 on: April 10, 2013, 09:32:28 09:32 »
They give examples, and it is easy to adapt. Just download the library or framework:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2680&dDocName=en547784
I adapted  a project for PIC18F4550 to a PIC24FJ256GB106 within one hour. This was my first USB C code for PIC.
flo0319
« Reply #3 on: April 10, 2013, 05:57:09 17:57 »
 You need to download first Microchip Application Library from link give by happylex.
After you have installed it, you need to go in the [installed folder \ USB \ Device - Mass Storage - SD Card reader] there is a project for 18F46J50, you can adapt it for 18F2550 easy
motox
-Given: 257
-Receive: 322
« Reply #4 on: April 10, 2013, 07:29:32 19:29 »
- Use this project: “C:\Microchip Solutions v2013-02-15\PIC18F Starter Kit 1\Demos\USB Device - Mass Storage - SD Card reader\MSD - SD Card Reader - Firmware”.
- Change the file ‘HardwareProfile - PIC18F Starter Kit.h’ according to your board. Include in this file the following definition: ‘#define PICDEM_FS_USB”. This will set the correct configuration bits in code.
- Create the linker file according to application note AN1003.
- Check the function ‘static void InitializeSystem(void)’ for any necessary code change.
If I don’t miss anything this should be enough.
Remember that if you don’t use the LF version then you need to add some voltage translators in your circuit.
xpress_embedo
-Given: 122
-Receive: 254
« Reply #5 on: April 11, 2013, 05:45:48 17:45 »
Thanks for your replies.
I modified the PIC18F47J53 SD Card Reader Project.
Right now i am changing it for PIC18F4550, after so many errors, i am getting one last error.
And it is associated with Linker.
MPLINK 4.40, Linker
Device Database Version 1.3
Copyright (c) 1998-2011 Microchip Technology Inc.
Error - could not find definition of symbol 'GetInstructionClock' in file 'Objects\47J53_PIM\SD-SPI.o'.
Errors    : 1
I am also getting one warning while compiling
Call of function without prototype and it is associated with this function
void Delayms(BYTE milliseconds)
    BYTE    ms;
    DWORD   count;
    ms = milliseconds;
    while (ms--)
        count = MILLISECDELAY;
        while (count--);
    Nop();
    return;
I am not getting what is the problem, it is related with instruction cycle, but i am not getting how to solve this
motox
-Given: 257
-Receive: 322
« Reply #6 on: April 11, 2013, 05:50:52 17:50 »
Put here a zip file with the project. I can correct the errors.
xpress_embedo
-Given: 122
-Receive: 254
« Reply #7 on: April 12, 2013, 01:57:03 01:57 »
I am uploading my project in zip folder pls have a look at it.
And correct the errors i am getting in this.
The project file is located here
"\SD_Card Reader PIC18F2550\Microchip Solutions v2011-12-05\USB\Device - Mass Storage - SD Card reader\Firmware"
In this project, at some places it is written pic18f2550, but it is for pic18f4550 at the moment.
Please don't confuse with that.
motox
-Given: 257
-Receive: 322
« Reply #8 on: April 12, 2013, 09:56:43 09:56 »
It’s done.
Just add the GetSystemClock() and GetInstructionClock() definitions in the file ‘HardwareProfile - PIC18F2550.h’<line 158>:
#define GetSystemClock() CLOCK_FREQ
#define GetInstructionClock() (GetSystemClock() / 4)
« Last Edit: April 12, 2013, 10:03:07 10:03 by motox » Logged
xpress_embedo
-Given: 122
-Receive: 254
« Reply #9 on: April 12, 2013, 05:12:59 17:12 »
Hello!!
Thanks that works..
When i simulate the Project in Proteus, the MSD is detected by PC but no pen drive is detected.
What is the reason behind this
I am getting some driver issue.
Pls have a look at the image.
Posted on: April 12, 2013, 06:10:50 18:10 - Automerged
If possible, pls run the simulation on your pc and checks whether it is running or not.
motox
-Given: 257
-Receive: 322
« Reply #10 on: April 12, 2013, 05:20:33 17:20 »
Run the attached program, select the USB device and post the resulting print screen.
xpress_embedo
-Given: 122
-Receive: 254
« Reply #11 on: April 12, 2013, 05:36:08 17:36 »
I am running the proteus simulation and nothing happens this time also.
And nothing appear in the application you give to me.
Here are the snapshot.
motox
-Given: 257
-Receive: 322
« Reply #12 on: April 12, 2013, 06:31:15 18:31 »
I never used Proteus and I don’t trust it.  Roll Eyes
Try to debug the problem. Start to check the value of the variable ‘USBDeviceState’. It’s like a state machine that tells you the USB connection status.
flo0319
« Reply #13 on: April 12, 2013, 08:02:19 20:02 »
In proteus is implemented a MMC card and not a SD card, it's a difference between commands(initialization and addressing data) for manage these type of cards.
#tester
-Receive: 15
« Reply #14 on: April 12, 2013, 10:30:04 22:30 »
and where is the data file for your formatted SD Card, virtual or real.
without a formatted card you can't read/or/write..
xpress_embedo
-Given: 122
-Receive: 254
« Reply #15 on: April 13, 2013, 03:26:06 03:26 »
Ok i will check that, and will also run the code on real hardware, but after two days, as i am not having that board right now.
Proteus has a mmc card not sd card, but the code will work for both card, as i had tested that earlier when experimenting with MDD Library and PIC18F8722 Project Example, it successfully create file in the card.
There is a Software WinImage, by the help of which i create Memory Card image of 2MB for my MMC Card in Proteus.
It is not working with this project, but had worked in proteus earlier when i experiment with MDD Library project.
Posted on: April 13, 2013, 03:59:12 03:59 - Automerged
One strange thing.
 Sad
When i run the PIC18F47J53 SD Card Reader Project in Proteus it working fine, but the one with PIC18F2550
Even i changed nothing in this.
happylex
« Reply #16 on: April 21, 2013, 03:05:42 15:05 »
You can try to debug in the simulation. I have seen it is possible for AVR and even Arduino code when using the .elf file, and it looked like a debugger with all the possible options the hardware debuggers also have.
xpress_embedo
-Given: 122
-Receive: 254
« Reply #17 on: April 21, 2013, 04:43:50 16:43 »
What should i debug, means what should i do, so that i can get to know where is the problem.
And i am making a real hardware and will try to implement it on that and will check the transaction in usblyzer software.
xpress_embedo
-Given: 122
-Receive: 254
« Reply #18 on: April 22, 2013, 05:32:32 17:32 »
Finally i tested my code on real hardware.
What i found is Microchip Mass Storage Device detected successfully but nothing happens means i am not able to view the Removable Disk Drive as supposed to be.
Posted on: April 22, 2013, 06:31:16 18:31 - Automerged
No Disk Drive appears, :-(
What should i do now.
I am also attaching UVC View Software Snapshot when this device is connected.
xpress_embedo
-Given: 122
-Receive: 254
« Reply #19 on: April 23, 2013, 03:22:00 03:22 »
Have a look at this, it is showing I drive means some thing is there, but nothing appears in windows explorer
avrlover
-Given: 50
-Receive: 219
« Reply #20 on: April 23, 2013, 07:10:19 07:10 »
here is application note from microchip might help u
xpress_embedo
-Given: 122
-Receive: 254
« Reply #21 on: April 23, 2013, 07:18:10 07:18 »
I had read that application note.
But not able to solve my problem.
I dont know why this happen.
As device manager us showing microchip mass storage device but not showing the drive.
 Sad
avrlover
-Given: 50
-Receive: 219
« Reply #22 on: April 23, 2013, 07:40:45 07:40 »
I have use code an1003 in Proteus it shows drive letter but drive is not accessible  try your this code in Proteus i am using windwos xp sp3
xpress_embedo
-Given: 122
-Receive: 254
« Reply #23 on: April 23, 2013, 10:47:11 10:47 »
When i remove the memory card.
It is showing the drive in windows explorer .
When memory card is inserted nothing appears in windows explorer.
I am not getting what is tge problem.
Can anyone check my linker file fir pic18f4550.
Posted on: April 23, 2013, 11:46:01 11:46 - Automerged
My code is not working in priteus as i had stated in my earlier post
avrlover
-Given: 50
-Receive: 219
« Reply #24 on: April 23, 2013, 11:18:10 11:18 »
so u can use code supplied by microchip an1003
Pages: [1] 2  All
