MAXPAYNE
-Given: 499
-Receive: 364
It's a little funny......
« on: March 18, 2013, 07:36:34 07:36 » |
I need to know some SMPS tx ferrite core model from Farnell UK/ Rs Online UK. I wanna use them for building 200W-700W DC power supply and 500W-4000W sine wave inverter.
Pls suggest me appropriate part no...
Faros
-Given: 141
-Receive: 178
« Reply #1 on: March 18, 2013, 02:40:10 14:40 » |
Go to CoilCraft Design Support Tools @ http://www.coilcraft.com/design_tools.cfmthen cross-match your findings with Farnell, they have recently raised their stock from CoilCraft to 6000+ parts.
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #2 on: March 18, 2013, 03:32:10 15:32 » |
They are for inductor and flyback trafo only ! I need core for push-pull, half-bridge and full bridge topology ...
Faros
-Given: 141
-Receive: 178
« Reply #3 on: March 18, 2013, 07:54:40 19:54 » |
I see, if I were in your shoes I would have searched in local suppliers (usually not on the web) or (for prototyping purposes) you can search an old SMPS transformer and extract its core, both ways you have to be geared for winding.
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #5 on: March 18, 2013, 09:26:28 21:26 » |
I normally do that for hobby purpose, scavenging them from old smps. I have a plan for going to commercial design. so, I have to r&d using known core parameter, which is not possible using scavenged core. Posted on: March 19, 2013, 01:24:10 am - Automerged
I want to know which material core and what size I have to choose, parameters while choosing core etc. Can you suggest from where should I start ?
« Reply #6 on: March 18, 2013, 10:16:43 22:16 » |
Try starting here: http://www.gotopower.net/article.asp?art_id=65http://www.irf.com/technical-info/appnotes/an-1024.pdfreally all I did was google "smps flyback transformer design" You need to pick a frequency, then you need to determine the maximum primary voltage on your transformer from this you can determine the max applied volt seconds applied to the transformer then you need to balance the max flux density vs the primary turns on your transformer there's more but that is the basic approach. the design of the transformer is somewhat iterative as you balance max flux, windings, cross sectional area, and winding area. You can't really go wrong with a BIG core to start with. I don't usually do flybacks so you'll have to do some reading. I think you need a decent air gap in a flyback for energy storage. So you will probably have to put a spacer in between the cores.
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #7 on: March 19, 2013, 05:40:39 05:40 » |
Try starting here: http://www.gotopower.net/article.asp?art_id=65http://www.irf.com/technical-info/appnotes/an-1024.pdfreally all I did was google "smps flyback transformer design" You need to pick a frequency, then you need to determine the maximum primary voltage on your transformer from this you can determine the max applied volt seconds applied to the transformer then you need to balance the max flux density vs the primary turns on your transformer there's more but that is the basic approach. the design of the transformer is somewhat iterative as you balance max flux, windings, cross sectional area, and winding area. You can't really go wrong with a BIG core to start with. I don't usually do flybacks so you'll have to do some reading. I think you need a decent air gap in a flyback for energy storage. So you will probably have to put a spacer in between the cores. I need to study about core selection not for flyback but for push-pull, half-bridge and full bridge topology ...
« Reply #8 on: March 19, 2013, 04:14:26 16:14 » |
« Last Edit: March 19, 2013, 04:18:59 16:18 by Gallymimu »
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #9 on: March 22, 2013, 11:24:33 11:24 » |
What is the best and cheapest place to buy ferrite smps core from UK ?
Tanuki
-Given: 19
« Reply #10 on: March 22, 2013, 05:55:40 17:55 » |
Ferrite cores are not carried by most electronics distributors. So buying them locally in prototype quantities is unlikely, regardless of where you're located.
There are several vendors on eBay that have pretty good selections.
BTW, Magnetic design is demanding, in your shoes I'd follow someone else's reference design. Otherwise you might have a bad experience.
« Reply #11 on: March 23, 2013, 03:17:42 03:17 » |
Buy from Farnell, I'm actually surprised that they carry what they do.
Posted on: March 23, 2013, 03:15:49 03:15 - Automerged
As far as demanding. I disagree. Unless you are trying to break records or really optimize your design you get usually make things work with a slightly oversized core and slightly larger than needed wire. As long as you are staying away from resonant converters that rely on goofy things like high leakage inductance as part of the resonant circuit... most thing's aren't that hard.
