November 23, 2024, 07:42:58 19:42
Author Topic: Boffins use DVD burner to scale graphene supercapacitors  (Read 3406 times)
PaulC
-Given: 3935
« on: February 26, 2013, 12:42:52 00:42 »
LightScribe becomes capacitor creator
By Richard Chirgwin • Get more from this author
Posted in Science, 21st February 2013 00:30 GMT
h**p:
http://www.theregister.co.uk/2013/02/21/ucla_dvd_burner_supercapacitor/
Free whitepaper – FuseSource Overview
One of the challenges in shrinking electronics is that some parts, like capacitors, stubbornly resist being minaturised. The charge-carrying capacity of a conventional capacitor is, after all, partly a function of the surface area of its plates.
Graphene is known to have properties that make it attractive as a “supercapacitor”, but it’s difficult to work with – a challenge the UCLA researchers claim to have cracked with a humble DVD burner.
Richard Kaner of the university’s NanoSystems Institute, working with graduate student Maher El-Kady, say they’ve used the DVD burner to fabricate supercapacitors made from a layer of graphitic carbon one atom thick. The big deal, they say, is the simplicity of manufacture, which would make their micro-supercapacitors manufacturing-ready.
The “consumer-grade” LightScribe DVD burner they used was able to build more than 100 of the supercapacitors on one DVD “in less than 30 minutes”.
UCLA DVD-printed supercapacitors
Burn, baby: UCLA's DVD-printed supercapacitors
Instead of trying to stack the graphene electrodes, the researchers printed them with an interleaved pattern, which maximised the surface area the electrodes present to each other (hence increasing the charge-carrying capacity).
The manufacturing technique, described here, is simple: a layer of plastic was glued onto the DVD, and coated with a layer of graphite oxide. The burner’s laser then creates the patterns that become the capacitor.
EDIT: do not code links
« Last Edit: February 27, 2013, 08:58:25 20:58 by pickit2 » Logged
-Receive: 904
« Reply #1 on: February 26, 2013, 04:32:59 04:32 »
“Laser Scribing of High-Performance and Flexible Graphene-Based ­Electrochemical Capacitors”
Richard B. Kaner et al.
Science 335: 1326–1330
Someone post the paper here and let's see if this is anything more than just some academic wanking
