March 10, 2026, 05:23:46 05:23
Author Topic: cmps03 digital compass and tft mikroC-testcode  (Read 6180 times)
TucoRamirez
-Given: 257
-Receive: 115
« on: January 22, 2013, 05:39:02 05:39 »
I did my code on mikroC because i dont like the weird way cubloc is ^^...
anyway:
original version:
http://www.lextronic.fr/P1773-module-boussole-cmps03.html
this test code basically draws a circle on the center of the screen, then changes its color and another circles tracks your angular movements...
nothing complicated
/**  PIC16F88  *  Clock: 8.0MHz ???????
* Device Flags:
#include "bit.h"
// module connections
#define I2C_PORT    PORTB   // User defined
#define I2C_PIN_SDA 1       // User defined
#define I2C_PIN_SCL 0       // User defined
#define I2C_TRIS    TRISB   // User defined
// Software I2C connections
sbit Soft_I2C_Scl           at RB0_bit;
sbit Soft_I2C_Sda           at RB1_bit;
sbit Soft_I2C_Scl_Direction at TRISB0_bit;
sbit Soft_I2C_Sda_Direction at TRISB1_bit;
// End Software I2C connections
// Internal macros
#define I2C_SDA_0  resBit(I2C_TRIS, I2C_PIN_SDA) //Port = o/p (Drive low).
#define I2C_SCL_0  resBit(I2C_TRIS, I2C_PIN_SCL) //Port = o/p (Drive low).
#define I2C_SDA_1  setBit(I2C_TRIS, I2C_PIN_SDA) //Port = i/p (Res pulls high).
#define I2C_SCL_1  setBit(I2C_TRIS, I2C_PIN_SCL) //Port = i/p (Res pulls high).
#define I2C_SDA_IN testBit(I2C_PORT, I2C_PIN_SDA)
#define I2C_SCL_IN testBit(I2C_PORT, I2C_PIN_SCL)
// End module connections
char i,j,k,k1,k2,rgbh,rgbl,temp,tmp,xt,yt;
unsigned char errorcom,angleH,angleL;
unsigned int xm,ym,angle;
char x,y;
char txt[15];
void Soft_I2C1_Init(unsigned long speed) {
   // must do following in one go else port takes time to do it so R-M-F stops it.
   I2C_PORT &= ~( (1<<I2C_PIN_SDA) | (1<<I2C_PIN_SCL) );
   I2C_SDA_1; // release data  (high).
   I2C_SCL_1; // release clock (high).
// 100kHz set here (very approximate). Will be slower  than 100kHz.
static void I2C_delay(void) {
   Delay_us(2);  // 1us
// Start command
// SDA 1-0-0
// SCL 1-1-0
// Asumptions : coming from bus free state (d=1,ck=1)
void Soft_I2C1_Start(void) {
   I2C_SDA_1;
   I2C_SCL_1;
   I2C_delay();
   I2C_SDA_0;
   I2C_delay();
   I2C_SCL_0;
   I2C_delay();
// Stop command
// SDA 0-0-1
// SCL 0-1-1
void Soft_I2C1_Stop(void) {
   I2C_SCL_0;   // Force to zero as can be sent at any time.
   I2C_SDA_0;   // Clock 1st so do not make a command.
   I2C_delay();
   I2C_SCL_1;
   I2C_delay();
   I2C_SDA_1;
   I2C_delay();
unsigned short Soft_I2C1_Read(unsigned short ack) {
unsigned short i;
char ddata;
   I2C_SDA_1;  // Release the data pin
   // grab the data
   for(i=0;i<8;i++) {
      ddata <<=1;
      I2C_SCL_0;
      I2C_delay();  // Clock is low
      I2C_SCL_1;    // Clock released to high.
      while (I2C_SCL_IN==0) {;} // Wait here if clock is pulled low by slave
      if (I2C_SDA_IN) {ddata |= 1;} // Sample the data
      I2C_delay();  // Clock is high
   // Send ACK or NACK
   I2C_SCL_0;
   if (ack) I2C_SDA_0;  // ACK
       else I2C_SDA_1;  // NACK
   I2C_delay();  // low T/w.
   I2C_SCL_1;
   I2C_delay();  // high T/2.
   I2C_SCL_0;    // Return clock to safe state.
   return ddata;
// Returns 0 for no errors = the ACK bit from the slave
unsigned short Soft_I2C1_Write(unsigned short xdata) {
unsigned short ret=0,i;
   // grab the data
   for(i=0;i<8;i++) {
      I2C_SCL_0; // Clock low
      if (xdata & 0x80) I2C_SDA_1; else I2C_SDA_0; // Data output
      xdata <<= 1;   // Next data bit.
      I2C_delay();  // low T/2.
   // get ACK or NACK
   I2C_SCL_0;
   I2C_SDA_1;    // Release the  data line
   I2C_SCL_1;
   // Sample the ACK
   ret = I2C_SDA_IN;
   return ret;
/*unsigned int Read_temp(unsigned char com)
  unsigned int SensorRaw;
  Soft_I2C1_Start();// issue I2C start signal
  Soft_I2C1_Write(0x00);// send address (device address + W)
  Soft_I2C1_Write(com);// send command
  Soft_I2C1_Start();// issue I2C signal repeated start
  Soft_I2C1_Write(0x01);// send address (device address + R)
  SensorLow = Soft_I2C1_Read(1);// Read temp. low byte (acknowledge)
  SensorHigh = Soft_I2C1_Read(1);// Read temp. high byte (acknowledge)
  PEC = Soft_I2C1_Read(1);// Read PEC (not used) (acknowledge)
  Soft_I2C1_Stop();// issue I2C stop signal
  SensorRaw = SensorLow + (SensorHigh << 8);// Build temp. word
  return SensorRaw;
void main() {
     OSCCON = 0x70; // 0b0110 0000 = 4MHz
     ANSEL=0;     // all digital
     CMCON=0X07;  // comparators off
     PORTA=0;
     TRISA=0;     // ports setup
     TRISB=0b00000100;
     PORTB=0b00100100;
     rgbh=0;rgbl=0;temp=0;k=0;k1=0;k2=0;
//interrupt config
     Delay_ms(1500);
     // Initialize hardware UART1 and establish communication at 9600 bps
     UART1_Init(19200);
     Delay_ms(100);
     UART1_Write_Text("U");
     Delay_ms(200);
     UART1_Write_Text("E");
     Delay_ms(200);
     UART1_Write_Text("p");
     UART1_Write(0x01);
     Delay_ms(1);
     UART1_Write_Text("C");
     UART1_Write(64);
     UART1_Write(64);
     UART1_Write(63);
     UART1_Write(0b00010000);
     UART1_Write(0b01000010);
     Delay_ms(100);
//   write a word ^^
     UART1_Write_Text("s");
     UART1_Write(0x01);
     Delay_ms(1);
     UART1_Write(0x08);
     UART1_Write(0x00);
     UART1_Write(0x4E);
     UART1_Write(0x7E);
     UART1_Write_Text("Ouest");
     UART1_Write(0x00);
     Delay_ms(100);
//   write a word ^^
     UART1_Write(0x09);
     Delay_ms(1);
     UART1_Write(0x01);
     UART1_Write(0x00);
     UART1_Write(0x4E);
     UART1_Write(0x7E);
     UART1_Write_Text("Nord");
     UART1_Write(0x00);
     Delay_ms(100);
//   write a word ^^
     UART1_Write(0x12);
     Delay_ms(1);
     UART1_Write(0x08);
     UART1_Write(0x00);
     UART1_Write(0x4E);
     UART1_Write(0x7E);
     UART1_Write_Text("Est");
     UART1_Write(0x00);
     Delay_ms(100);
//   write a word ^^
     UART1_Write(0x09);
     Delay_ms(1);
     UART1_Write(0x0E);
     UART1_Write(0x00);
     UART1_Write(0x4E);
     UART1_Write(0x7E);
     UART1_Write_Text("Sud");
     UART1_Write(0x00);
     Delay_ms(100);
//   i2C sensor
     //xm=0;ym=0;
while(1) {
/*         k+=8;
         if (k==32) {k=0;
           k1+=8;
           if (k1==64) {
               k1=0;
               k2+=8;
               if (k2==32) { k2=0;};
           temp=(k1<<5)&0b11100000;
           tmp=k2&0b00011111;
           rgbl=temp|tmp;
           temp=(k1 >> 3)&0b00000111;
           tmp= (k << 3)&0b11111000;
           rgbh= temp | tmp;
           i=20;
           UART1_Write(0x00); // 1 for line 0 for solid
           Delay_ms(1);
           UART1_Write(64); // x
           UART1_Write(64); // y   //64 64 63  00  1f
           UART1_Write(i);  // radius
           UART1_Write(rgbh);  // rgbh
           UART1_Write(rgbl);  // rgbl
           Delay_ms(1000);
//                 UART1_Write_Text("E");
//           Delay_ms(50);
     Soft_I2C1_Init(100000);
     Soft_I2C1_Start();
     Soft_I2C1_Write(0xC0); //Adresse du module CMPS03
     Soft_I2C1_Write(0);    //Selectionne adresse registre a lire
     Soft_I2C1_Start();//Condition Start I2C
     Soft_I2C1_Write(0xC1);// Selectionne condition de lecture I2C
     tmp = Soft_I2C1_Read(1);//Lecture N° revision module CMPS03
     Delay_ms(5);
     tmp = Soft_I2C1_Read(1); //lecture valeur angle (0 - 255)
     Delay_ms(5);
     angleH=Soft_I2C1_Read(1);// Recupere octet poids fort angle
     Delay_ms(5);
     angleL=Soft_I2C1_Read(0);//Recupere octet poids faible angle
     Soft_I2C1_Stop();
     angle=angleH;
     angle=(angle<<8)+angleL;
     angle=angle/10;
// ####### Dessine aiguille boussole ##############
x = (cosE3(angle) * 32/1000) ;
y = (sinE3(angle) * 32/1000) ;
  UART1_Write_Text("L");
  UART1_Write(x);
  UART1_Write(y);
  UART1_Write(127-x);
  UART1_Write(127-y);
  UART1_Write(0xFF);//         ' efface rond
  UART1_Write(0xFF);
  Delay_ms(200);
  UART1_Write(127-x);
  UART1_Write(127-y);
  UART1_Write(4);//         ' efface rond
  UART1_Write(0xf4);//         ' efface rond
  UART1_Write(0xe0);
  Delay_ms(200);
