January 02, 2025, 07:36:38 19:36
Author Topic: How to put a BMP in EEPROM 24lcXX  (Read 5733 times)
jose
-Given: 342
-Receive: 12
« on: January 21, 2013, 03:27:12 15:27 »
Hello for alls.
I will like to work with GLCD.
I working with the program bitmap2LCD and others, and this generate table of chars for the compilers CCs...
How can i to converter this  format file(chars)  to binari format (bin) , for  load to eeprom 24lcxx ?
Thanks and sorry for me bad Enghish.
flo0319
« Reply #1 on: January 21, 2013, 04:05:21 16:05 »
For first you need to understand what is a BMP file and what you need to put in EEPROM
A BMP file has a complex structure where are defined a lot of extra information about picture,
Your GLCD is monocolor or is RGB?
for monocolor you need to save just "0"/"1" information for each pixel, so, at any location you can save in your eeprom information about 8 pixels
for RGB you need to save 24 bits for each pixel so, you need to use 3 locations for your picture where any location tell you the value for R / G / B color
if you are familiar with matlab you can write a program(script) what can convert any picture in raw format
the eeprom memory is viewed like a unidimensional but your picture is bidimensionl, if you know rows and cols number you can save your picture line after line where pixel[5][6] form a picture 30X50 is eeprom[start_addres+5*50+6]
gan_canny
-Given: 101
-Receive: 26
« Reply #2 on: January 21, 2013, 10:12:44 22:12 »
Assuming the issue is the storing of the a character image in eeprom. There are programs that will take an font with all its representations of characters into an array. Now a glcd has an aspect ratio pixels may not be square further a character within a font can have different sizes. Suppose a font was chosen so that a char occupies a block 8x8 pixels. Typically this is stored in the eeprom using 8 bytes with the font having extra to create a space between characters. Next an indexing scheme is required. Typically if the character encoding is ASCII then the ASCII value is used as an index and since each char now takes up 8 bytes a multiplication by 8 of the ASCII value would point to the starting address. EX 'A" is ascii base10(65) and the position 'A is to appear in the glcd is row y col x... then the eeprom is accessed at address 65x8 8 rows are written at col x.
Now the graphical representation of a character can vary greatly but for a small sized GLCD the controller is relatively simple compared to a Graphics processor so fonts sizes are often just multiples of a base font stored in the eeprom.
cranor
« Reply #3 on: February 06, 2013, 08:49:51 20:49 »
Use 010Editor, copy the tab code, then in a new file, go to edit, paste from, paste from source code.
Enjoy
