May 23, 2026, 05:09:21 05:09
Author Topic: HELP - Can't mange to setup dsPIC33 clock with CCS v4.140  (Read 8635 times)
cerebronico
-Given: 265
-Receive: 27
« on: January 06, 2013, 10:16:57 10:16 »
I was trying con figure out how to configure the clock in the dsPIC33fj128MC204 with CCS compiler but I fail again and again
I have a 10MHz xtal and I want it run to 40MHz as says in several examples, this is my header file:
#FUSES WPRES32                  //Watch Dog Timer PreScalar 1:32
#FUSES WPOSTS1                  //Watch Dog Timer PostScalar 1:1
#FUSES PROTECT_HIGH             //General Segment Code Protect High Security
#FUSES PR_PLL                   //Primary Oscillator with PLL
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOJTAG                   //JTAG disabled
#FUSES DEBUG                    //Debug mode for use with ICD
#pin_select INT1=PIN_C9
#pin_select CMP1=PIN_B3         // OC sobre intensidad
#pin_select CMP2=PIN_B1         // OV sobre tension
#pin_select OC1=PIN_B12         // pulso a los SCRs
#pin_select U1TX=PIN_B14
#pin_select U1RX=PIN_B15
#use delay(clock=80MHz,RESTART_WDT)
//#use rtos(timer=3,minor_cycle=5ms)
#use rs232(UART1,baud=9600,parity=N,bits=8,restart_wdt)
I only get it work at 15.625MHz
any ideas will be greatly appreciated
c.
gan_canny
-Given: 101
-Receive: 26
« Reply #1 on: January 06, 2013, 10:38:22 22:38 »
The code snippet below is for the new oscillator arrangement in some of the latest PIC chips
The snippet is specifically for a 24EP512GU810 which can run internally at 140Mhz from in my case a 8Mhz external Xtal
You should modify the PLL_N1 PLL_M PLL_N2 PLL_XTAL values to your specific needs
Look at the microchip osc setup specs to see the limitations of your chip
Note I suspect CCS hasn't yet written code to allow #use delay(clock=xxMHz,xtal=yyMhz) to autoset up the newer chips.
#fuses XT,PR_PLL,PLLWAIT,ICSP1,PUT128,IESO,NOJTAG
#define PLL_N1 2
#define PLL_M 70
#define PLL_N2 2
#define PLL_XTAL 8
/// setup_pll(N1,M,N2) xtal 8Mhz is ((8/2)*70)/2=140Mhz
#use delay(clock=140Mhz) // have to let the compiler know we're running at 140MHz
                        // the switch t0 140 Mhzoccurs at the very top of main
                      // but the compiler needs this at compile time
#use rs232(debugger) //// monitor output on b3
////// busy low level code to get osc set up
///   since use delay(clock=140Mhz,osc=8Mhz) isn't working
///  instead we use setup_pll(PLL_N1,PLL_M,PLL_N2);
//// called in main()
#word CLKDIV = getenv("sfr:CLKDIV")
#bit PLLPOST0 = CLKDIV.6
#bit PLLPOST1 = CLKDIV.7
#word PLLFBD = getenv("sfr:PLLFBD")
struct struct_MIDDIV_M
   int M;    //0-7
   int unused1;  //8-15
struct struct_MIDDIV_M MIDDIV ;
#word MIDDIV=getenv("sfr:PLLFBD")
struct struct_DIV_N1andN2
   int N1:5;    //0-4
   int1 unused1; // 5
   int N2:2;  //6-7
   int unused2;  //15
struct struct_DIV_N1andN2 DIV_N1andN2;
#word DIV_N1andN2=getenv("sfr:CLKDIV")
struct struct_OSCCON
   int1 oswen;    //0      // oscillator switch enable
   int1 lposcen;  //1      // secondary (LP) oscillator enable
   int1 unused1;  //2
   int1 cf;       //3      // clock fail detect bit
   int1 unused2;  //4
   int1 lock;     //5      // PLL lock status
   int1 unused3;  //6
   int1 clklock;  //7      // clock lock enable
   int nosc:3;    //8-10   // new oscillator selection
   int1 unused4;  //11
   int cosc:3;    //12-14  // current oscillator selection
   int1 unused5;  //15
struct struct_OSCCON OSCCON;
#word OSCCON = getenv("sfr:OSCCON")
#byte OSCCONL = OSCCON
#byte OSCCONH = OSCCON+1
//#byte OSCCONL = 0x0742
//#byte OSCCONH = 0x0743
void setup_pll(int8 N1,int8 M,int8 N2)
   // This function is required because the 24HJ cannot startup with a 8MHz xtal
   // from powerup (not reliably, anyway). Must start the PIC using the internal
   // RC oscillator, then switch over to the external xtal with PLL. This also
   // requires a very time sensitive unlock sequence to directly access the
   // necessary registers to perform this task. #asm taken directly from
   // a microchip app note.
   // 8MHz xtal -> PLLPRE divider (N1) -> multiplier -> VCO -> PLLPOST divider (N2) -> Fosc
   //                                          |------PLLDIV (M)
   // 8MHz / 2 = 4MHz x 40 = 160MHz / 2 = 80MHz
   //         N1         M             N2
   // M = 38 (40 - 2), N1 = 1 (3 - 2), N2 = 0 (2)
   // N1
   CLKDIV = N1-2; // PLLPRE
   // N2
   //11 = Output/8
   //10 = Reserved
   //01 = Output/4 (default)
   //00 = Output/2
   if (n2==2)
   PLLPOST0 = 0;
   PLLPOST1 = 0;
   if (n2==4)
   PLLPOST0 = 1;
   PLLPOST1 = 0;
   if (n2==8)
   PLLPOST0 = 1;
   PLLPOST1 = 1;
   // M
   PLLFBD = M-2;
   #asm
   MOV #0x03, w0
   MOV OSCCONH, w1
   MOV #0x78, w2
   MOV #0x9A, w3
   MOV.B w2, [w1]
   MOV.B w3, [w1]
   MOV.B w0, [w1]
   MOV #0x01, w0
   MOV OSCCONL, w1
   MOV #0x46, w2
   MOV #0x57, w3
   MOV.B w2, [w1]
   MOV.B w3, [w1]
   MOV.B w0, [w1]
   #endasm
   while(OSCCON.cosc != 3); // wait for switchover to occur
   while (!OSCCON.lock); // wait for PLL to lock
   OSCCON.clklock = 1;
///and in main call
 setup_pll(PLL_N1,PLL_M,PLL_N2); /// setup_pll(N1,M,N2) xtal 8Mhz is ((8/2)*70)/2=140Mhz
The 15.xxMhz you are getting is very likely the 16Mhz internal RC oscillator freq
« Last Edit: January 06, 2013, 10:47:42 22:47 by gan_canny » Logged
