November 29, 2024, 10:55:20 22:55
Author Topic: Interfacing MMC card with micrcontroller  (Read 7700 times)
yasir9909
-Receive: 107
« on: September 03, 2007, 05:32:57 05:32 »
I am trying to design a voice recorder which uses AVR 8535 microcontroller,which compresses the voice data after A/D conversion,i have implemented speech compression ( ADPCM speech compression & Decompression ) with AVR however i am finding it difficult to interface MMC card
 Has any one interface MMC card with micrcontroller in spi mode
m.yasir
otter
-Given: 200
« Reply #1 on: September 04, 2007, 12:03:43 00:03 »
Yes, we used a small ARM, but it should work on an AVR just as well. I don't remember there being any problems, but it was a while ago. What problems are you having?
Otter
freddy
« Reply #2 on: September 04, 2007, 06:26:47 06:26 »
You can found an application here: http://butterflymp3.sourceforge.net/
FaithNoMore
Translator
-Given: 16
-Receive: 91
« Reply #3 on: September 04, 2007, 07:49:49 07:49 »
Yasir, I posted SD/MMC and CFlash 12/16 FAT File-System for AVR (CV, IAR, ICC)
here@ http://www.sonsivri.com/forum/index.php?topic=4226.0
yasir9909
-Receive: 107
« Reply #4 on: September 06, 2007, 05:36:28 05:36 »
i have implemented ADPCM successfully,the problem i am having with MMC card interfacing is that
when i try to record compressed voice data on MMC card,the voice upon retrieval from the card at PC end gives a jerk after 2-3 seconds of voice play back
may be this jerk is due to sector change ,every sector comprises 512 bytes
What i am trying to design is, the ATmega8535 takes analog input data ,performs A/D conversion ,which generates 10-bit data samples at rate of 8KHz ,these data samples are then subjected to ADPCM speech compression which generates 4 bit compressed data sample from 16-bit data sample ,then it takes other uncompressed data sample and compresses it to 4-bit ADPCM compressed data sample
These two data samples are then packed in a single byte,this byte containing two ADPCM data sample is then
written to MMC card.This is recording process
once we are done with recording ,we need to retrieve the data , For retrieval the Micrcontroller reads compressed voice data from MMC sector by sector and transmits it to PC through serial port
which is recorded on pc in binary file
this binary file is decompressed using Turbo C and then decompressed and converted to wave file through VC++ code
m.yasir
yasir9909
-Receive: 107
« Reply #5 on: September 26, 2007, 04:41:01 04:41 »
i have done it,there problem was due integrating speech compression algorithm in mmc read and write routine
i have implemented it without speech compression now and it is working fine
i would integrate speech compression algorithm in it
thanks to all for referring to links
m.yasir
FaithNoMore
Translator
-Given: 16
-Receive: 91
« Reply #6 on: September 26, 2007, 01:51:45 13:51 »
Glad you've found the problem yasir.
If you have time could you post your project here, I think many of us are interested.  Wink
yasir9909
-Receive: 107
« Reply #7 on: September 28, 2007, 07:25:23 07:25 »
ok i would
for reminder my email address is :
[email protected]
m.yasir
yasir9909
-Receive: 107
« Reply #8 on: September 29, 2007, 04:16:00 16:16 »
here is the code for writing and reading a single sector
CODE for ATmega8535
#include <iom8535v.h>
#include <macros.h>
#define SPIDDR     DDRB
#define SPIPORT   PORTB
#define SPIPIN      PINB
#define CS           0x10
#define BinToASCII(t)((t<=9) ? (t|0x30):(t+55))
#define ASCIIToBin(t) ((t>='A'&& t<='F')?t-55:((t>='0' && t<='9') ? t-'0':0))
#define BYTELOW(v)  (*((unsigned char *) (&v)))
#define BYTEHIGH(v)   (*(((unsigned char *) (&v) + 1)))
#define BLOCK_SIZE   512
const unsigned char   CMD0_RST_IDLE[]  ={0x40,0x00,0x00,0x00,0x00,0x95};
                                     //command 0 reset all card to idle state
const unsigned char   CMD1_SND_OPCND[]={0x41,0x00,0x00,0x00,0x00,0xFF};
                                    //command 1 for read OPERATION CONDITION register  const unsigned char CMD16_SET_BLOCKLEN[]={0x50,0x00,0x00,0x02,0x00,0xFF};
                                 //command 16 TO SET BLOCK LENGHT=512 BYTE TO READ & WRITE
                                             //0x000200=512 & 0x00000010=16
const unsigned char   MSGF[]   ={"\rMMC CARD INTERFACE \r"};
const unsigned char   MSG0[]   ={"\rMMC CARD COMMAND 0 \r"};
const unsigned char   MSG1[]   ={"\rMMC CARD COMMAND 1 \r"};
const unsigned char   MSGB[]   ={"\rMMC CARD COMMAND BLOCK=512 \r"};
const unsigned char   MSGW[]   ={"\rMMC CARD SECTOR WRITE     \r"};
const unsigned char   MSGR[]   ={"\rMMC CARD SECTOR READ     \r"};
const unsigned char   MSG[]   ={"\nMMC CARD IS INITIALIZED SPI MODE  \n"};
const unsigned char   CSD[]   ={"\rCSD INFORMATION: \r"};
const unsigned char   CID[]   ={"\rCID INFORMATION: \r"};
const unsigned char   WACK[]   ={"\rWRITE ACKNOLEDGE: \r"};
const unsigned char   WNFSH[]   ={"\rWRITE NOT FINISH: \r"};
unsigned char TEMP;
unsigned int iSIZE;
unsigned int iSIZE1;
unsigned char BUFFER[128];
//ICC-AVR application builder : 29/09/2005 16:23:49
// Target : M32  Crystal: 11.0592Mhz
void port_init(void)
  PORTA = 0x00;
  DDRA  = 0x00;
  PORTB = 0xFF;
  DDRB  = 0xFF;
  PORTC = 0x00;
  DDRC  = 0x00;
  PORTD = 0x00;
  DDRD  = 0x02;
//UART0 initialize
// desired baud rate: 57600
  In the ATmega32, the UBRRL & UBRRH registers must be written separately.
  It is not possible to use the following construct:
  UBRR = BAUD_RATE_REGISTER_VALUE;
  as UBRRL & UBRRH are not in adjacent locations. See ATmega32 data sheet.
void uart0_init(void)
 UCSRB = 0x00; //disable while setting baud rate
 UCSRA = 0x00;
 UCSRC = BIT(URSEL) | 0x06;
// UBRRL = 7; //set baud rate lo @ 11.0592 MHZ
 UBRRL = 11; //set baud rate lo @ 14.7456 MHZ
 UBRRH = 0x00; //set baud rate hi
 UCSRB = 0x18;
//call this routine to initialize all peripherals
void init_devices(void)
  port_init();
  uart0_init();
  MCUCR = 0x00;
  GICR  = 0x00;
  TIMSK = 0x00;
unsigned char ReceiveByte(void)
  while(!(UCSRA & BIT(RXC)))   ;
    return UDR;
void SEND_CHAR_UART(char ch)
  while(!(UCSRA & BIT(UDRE))) ;
  UDR = ch;
void SendStr(const char *ch)
{     while(*ch != 0x00) SEND_CHAR_UART(*ch++);}
void PRINT_ASCII (unsigned char PRNT)
   unsigned char PRN=0;
      PRN=PRNT>>4;
      SEND_CHAR_UART(BinToASCII(PRN));
      PRN=PRNT&0x0F;
void SpiInit()
    DDRB  |= 0xB0;  // Set SCK, MOSI & SS as outputs
    PORTB &= 0x5F;  // clear bits MOSI, & SCK
    SPCR = 0x53;
/***  SpiWriteByte() writes a byte to the SPI and waits until  it has been transmitted.
This function doesn't  return any value back.**/
unsigned char CHAR_SPI(unsigned char byte)
    SPDR = byte;
    while (!(SPSR & 0x80));
    byte = SPDR;
return byte;
// void Delay_1ms(void)
void Delay_1ms(int Del)
int i;
while (Del--)
     {     for (i=0;i<200;i++) WDR();     }
//      MMC GET RESPONSE
unsigned char MMC_RESPONCE(unsigned char RESPONSE )
      unsigned int COUNT=0xFFFF;
       unsigned  char  RESULT;
      while(COUNT!=0)
            RESULT = CHAR_SPI(0xFF);
   // PRINT_ASCII (RESULT);    SEND_CHAR_UART('\r');   //debug
          if(RESULT==RESPONSE)
            {    break;}
          COUNT--;
      if(COUNT==0)return 1;
           else
       return 0;
unsigned char MMC_WAIT_FOR_WRITE_FINISH( void )
         unsigned char LPCNT=0xFF;
       unsigned char  RESULT = 0;
       /* The delay is set to maximum considering the longest data block length to handle */
         while( (RESULT == 0) && LPCNT )
              { RESULT = CHAR_SPI( 0XFF);
               LPCNT--;
         if (LPCNT== 0 )
              return 1;                    /* Failure, loop was exited due to timeout */
           else return 0;         /* Normal, loop was exited before timeout */
unsigned char  MMC_INIT()
//unsigned int i;
unsigned char LPCNT=0;
       /* start off with 80 bits of high data with card deselected */
      SPIPORT |=CS;
       for(LPCNT=0;LPCNT<10; LPCNT++)
       CHAR_SPI(0xff);
/*-----------------------------------------CMD 0------------------------------------------------*/
       SPIPORT &= ~CS;        /* select card */
       CHAR_SPI( 0X40);   CHAR_SPI( 0X00);     CHAR_SPI( 0X00);
       CHAR_SPI( 0X00);   CHAR_SPI( 0X00);     CHAR_SPI( 0X95);
           if( (MMC_RESPONCE(0x01)) == 1 )
                        SPIPORT |=CS;
                              return 1;
SendStr( MSG0);
     SPIPORT |= CS;
    CHAR_SPI(0xFF);
/*-------------------------------------CMD1---------------------------------------------------------*/
     SPIPORT &= ~CS;
     LPCNT=0xFF;
      do
          CHAR_SPI( 0X41);   CHAR_SPI( 0X00);     CHAR_SPI( 0X00);
           CHAR_SPI( 0X00);   CHAR_SPI( 0X00);     CHAR_SPI( 0XFF);
      LPCNT--;
      } while ( (MMC_RESPONCE(0x00) != 0) && (LPCNT>0) );
      if(LPCNT==0)
        {     SPIPORT |= CS;       return 1;   }
SendStr( MSG1);
     SPIPORT |= CS;
    CHAR_SPI(0xFF);
/*---------------------------------------CMD16  SET BLOCK LENGTH--------------------------*/
       CHAR_SPI( 0X50);   CHAR_SPI( 0X00);     CHAR_SPI( 0X00);
       CHAR_SPI( 0X02);   CHAR_SPI( 0X00);     CHAR_SPI( 0XFF);
           if( (MMC_RESPONCE(0x00)) == 1 )
                        SPIPORT |=CS;
                              return 1;
SendStr( MSGB);
SPIPORT |= CS;
 CHAR_SPI(0xFF);
return 0;
//unsigned char  MMC_WRITE_BLOCK( unsigned  long SECTOR)
void GET_CSD()
 SPIPORT &= ~CS;
       CHAR_SPI( 0x49);   CHAR_SPI( 0x00);     CHAR_SPI( 0X00);
       CHAR_SPI( 0x00);   CHAR_SPI( 0x00);     CHAR_SPI( 0XFF);
       while ((MMC_RESPONCE(0x00)) == 1);
       while( (MMC_RESPONCE(0xFE)) == 1 );
      for(TEMP=0;TEMP<=35;TEMP++)
           BUFFER[TEMP]=CHAR_SPI(0xFF);
SendStr(CSD);
      for(TEMP=0;TEMP<=15;TEMP++)
          PRINT_ASCII(BUFFER[TEMP]);
SEND_CHAR_UART('\n');
SPIPORT |= CS;       // Deselect card
//void GET_CID()
void GET_CID()
SPIPORT &= ~CS;       // select card
       CHAR_SPI( 0x4A);   CHAR_SPI( 0x00);     CHAR_SPI( 0X00);
SendStr(CID);
void INSULATOR()
{ CHAR_SPI( 0xFF);CHAR_SPI( 0xFF);CHAR_SPI( 0xFF);CHAR_SPI( 0xFF);CHAR_SPI( 0xFF);
unsigned char  MMC_READ_BLOCK( unsigned   long SECTOR)
unsigned char LTMP=0;
unsigned long ADDRESS=0;
ADDRESS=SECTOR*BLOCK_SIZE;
/*-----------------------CMD17------------------------------------------------*/
       SPIPORT &= ~CS;
       CHAR_SPI( 0x51);
       CHAR_SPI (ADDRESS>>24);        CHAR_SPI (ADDRESS>>16);
       CHAR_SPI (ADDRESS>>Cool;         CHAR_SPI (ADDRESS>>0);
       CHAR_SPI( 0xFF);
                {  SPIPORT |= CS;
                  return 1;
                                SEND_CHAR_UART('r');
for(LTMP=0;LTMP<4;LTMP++)
      for(LPCNT=0;LPCNT<128; LPCNT++)
           BUFFER[LPCNT]=CHAR_SPI(0xFF);
         if((LPCNT%16)==0)SEND_CHAR_UART('\r');
         //PRINT_ASCII(BUFFER[LPCNT]);
         SEND_CHAR_UART(BUFFER[LPCNT]);
            CHAR_SPI(0xFF);  CHAR_SPI(0xFF);  //rwad CHKSUM
SendStr( MSGR);
 SPIPORT |= CS;
 CHAR_SPI(0xFF);
return 0;
unsigned char  MMC_WRITE_BLOCK( unsigned   int SECTOR,unsigned char WRT)
/*-----------------------CMD24------------------------------------------------*/
       SPIPORT &= ~CS;
       CHAR_SPI( 0x58);
       CHAR_SPI( 0xFF);
                        SPIPORT |=CS;
                              return 1;
         CHAR_SPI(0xFF);
         CHAR_SPI(0xFE);                //start of DATABLOCK
             for(LPCNT=0;LPCNT<128; LPCNT++)CHAR_SPI(WRT);
             for(LPCNT=0;LPCNT<128; LPCNT++)CHAR_SPI(WRT+1);
             for(LPCNT=0;LPCNT<128; LPCNT++)CHAR_SPI(WRT+2);
             for(LPCNT=0;LPCNT<128; LPCNT++)CHAR_SPI(WRT+3);
         CHAR_SPI(0xFF); CHAR_SPI(0xFF);   // dummy chksum
       LPCNT= CHAR_SPI(0xFF);
SendStr(WACK);   PRINT_ASCII(LPCNT);   PRINT_ASCII((LPCNT & 0x0F));
        if ( (LPCNT & 0x0F) != 0x05 )
                  SPIPORT |=CS;
                  return 1;
                   if( MMC_WAIT_FOR_WRITE_FINISH()==1)
               SendStr(WNFSH);
                                SPIPORT |=CS;
                              return 1;
SendStr( MSGW);
SPIPORT |= CS;
 CHAR_SPI(0xFF);
return 0;
  Function: 'main()'.
void main(void)
  init_devices();                      // set the baudrate to 19,200 bps using a 14.7456MHz crystal.
  SpiInit();
SendStr( MSGF);                         // Transmit welcome message.
while ( MMC_INIT() != 0)
SendStr( MSG);INSULATOR();
SPCR  = 0x50;SPSR  |=0x01;
GET_CSD();          INSULATOR();
GET_CID();        INSULATOR();
MMC_WRITE_BLOCK(101,0x45);INSULATOR();;
MMC_READ_BLOCK(101);INSULATOR();
MMC_WRITE_BLOCK(100,0x54);INSULATOR();
MMC_READ_BLOCK(100);INSULATOR();
 while (1)                            // Now do this forever.
     CHAR_SPI(0x55);;
m.yasir
yasir9909
-Receive: 107
« Reply #9 on: September 29, 2007, 04:18:49 16:18 »
This is a prototype code for writing and reading a single sector you can simulate and run this code in proteus
i would send you the other code later which i have used for mmc card based voice recording and play back system
m.yasir
Trishool
« Reply #10 on: September 29, 2007, 04:32:55 16:32 »
Hi, My 2 cents, If you could search 8052.com you will get loads of info on the subject.
Rgds
Ts
lory19
« Reply #11 on: December 17, 2007, 03:01:39 15:01 »
Hi !
I ,m new here i have some interest I looking how write data in mmc card
from analog device 0-to 5v
but I don,t know nothing about C
Regards !
Lory
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #12 on: December 18, 2007, 08:58:24 08:58 »
MMC/SD Board
MMC/SD board scheme [30KB] http://www.mikroe.com/pdf/mmc-sd_board_schematic.pdf
Examples [1.21MB]  http://www.mikroe.com/zip/mmc-sd_board_examples.zip
or
Compact Flash Board
Compact Flash board scheme[50KB]  http://www.mikroe.com/pdf/cf_board_schematic.pdf
Examples [1.0MB]  http://www.mikroe.com/zip/cf_board_examples.zip
 Roll Eyes Nice time  Wink
yasir9909
-Receive: 107
« Reply #13 on: January 17, 2008, 04:25:48 04:25 »
what type of analog device you are interested in
i have implemented a voice recording system which takes data from mic and writes it to MMC card after converting it to digital format using analog to digital converter
what you have to do is to use an analog to digital converter ,which would take analog input data from your analog device like mic,temperature sensor etc.
this digital data is then tansferred to the microcontroller which would write it on MMC card which can be  subsequently read on user demand from  MMC using the same microcontroller
Posted on: January 14, 2008, 06:12:43 06:12 - Automerged
i don't know how to upload pic or image file on this post,other wise i would also post the schematic diagram of the circuit for the above code in Proteus
the above code is also implementable in Preteus
m.yasir
ABBOSE
-Receive: 21
« Reply #14 on: January 17, 2008, 06:09:18 06:09 »
To interface flash memory with PIC , please see the topics
http://www.sonsivri.com/forum/index.php?topic=5531.0
nine9
« Reply #15 on: January 21, 2008, 08:00:37 20:00 »
Here is a simple solution for connecting a MMC/SD for AVR:
http://translate.google.com/translate?u=http%3A%2F%2Fwww.ulrichradig.de%2Fhome%2Findex.php%2Favr%2Fmmc-sd&langpair=de%7Cen&hl=en&ie=UTF8
yasir9909
-Receive: 107
« Reply #16 on: January 25, 2008, 09:48:28 09:48 »
The schematic diagram of the above mentioned code,drawn and implemented in proteus,can be down loaded from the following link for rapidshare
Download-Link #1: http://rapidshare.com/files/86452033/mmc.bmp.html
replace the smiley symbol in the above mentioned code with 8
m.yasir
lacsicz
« Reply #17 on: January 25, 2008, 11:52:37 23:52 »
Just two quick questions to add here:
I've seen that most schematics use resistors for voltage dividing 1.8k and 3.3k. How safe is it for the sd/mmc shouldn't they be grater values?
How big could be a SD/MMC? is it safe to use 512MB or 1GB versions? and could they be formatted in a cardreader if something fails?
yasir9909
-Receive: 107
« Reply #18 on: February 01, 2008, 06:43:30 06:43 »
yup in most of the schematics you would see a voltage divider network of 6 resitors 3x1.8k and 3x3.3 k for finding answer to this particular question you need to consult data sheet of mmc i would reply you on this question later
well ,as far as my knowledge is concerned,so far i have seen  mmc and mciro sd cards of capacity upto 2GBs,what do you mean by safe here
both sd and mmc cards can be formated in your mobile as well as by your PC (by using mmc to usb converter )
m.yasir
Posted on: January 28, 2008, 05:30:38 05:30 - Automerged
m.yasir
fagari
-Receive: 41
« Reply #19 on: February 02, 2008, 11:35:37 11:35 »
look at another example
http://www.sonsivri.com/forum/index.php?topic=6658.0
neer4evr
« Reply #20 on: February 13, 2008, 02:12:55 14:12 »
hey did anyone checkout proteus 7.2 sp2 it has a sample design for MMC card as a USB mass storage device. It is quite cool.
billy48
« Reply #21 on: March 04, 2008, 04:32:18 04:32 »
Does anyone try to interface MMC with LPC2138?
supoj
« Reply #22 on: March 14, 2008, 12:37:21 12:37 »
http://www.mikroe.com/en/compilers/
mikroBasic for AVR  Work but support Fat16
