April 05, 2025, 05:53:10 05:53
Author Topic: FED WIZ-C compiler 12.02m1 Professional with keygen  (Read 13399 times)
Thiru09
-Given: 398
-Receive: 1188
« on: September 02, 2007, 01:11:14 13:11 »
Dear friends,
I am glad to provide you the Wiz-C compiler from FED.
This is my first post on Sonsivri.
Release Name
FED WIZ-C 12.02m1 Pro
Screenshots:
Link
http://mihd.net/1j8klf
Password
/*Release1ForSonsivri*/
Program Info:
   WIZ-C includes the full functionality of the FED PIC C Compiler, and PICDESIM - the FED development and
   simulation environment.
   WIZ-C can be configured not to use the application designer in which case it behaves exactly like the
   FED PIC C Compiler.
   WIZ-C can also load FED PIC C Compiler projects and handles them identically to the compiler.
General Info:
   I have NOT included the documents setup files in this release to decrease the file size.
   You can download them directly form the website (follow the following link).
http://www.fored.co.uk/html/PIXDMMN.zip
   The keygen is developed by me for the 11.00 version and the same can be used to unlock the 12 version.
   According to the FED website, the latest DOWNLOADABLE version is 14. But the link provided there is for 12.02m1
   version.   Angry If anybody have the 14 version, they are requested to upload that, so that it can be reversed.
   Using this keygen, you can update the program either as PROFESSIONAL or NORMAL version.
   Please keep the keygen with you, it will help you when you re-install the program.
   The same keygen can be used for AVR compiler also, any way I will post that in next thread.
   If you encounter any problems with keygen, please let me know (don't criticise me). I will return with positive
   answer as fast as I can.
   This is my first release on sonsivri. And I want to here you from you (especially from REGO).
   Thank you REGO for your Proteus 7.1.   Smiley
   Bye, see you in next post.
   -Thiru
Thiru09
-Given: 398
-Receive: 1188
« Reply #1 on: September 02, 2007, 02:10:30 14:10 »
Friends,
Use "Thank You" button instead of posting a reply with thanks
otherwise you will be banned
Be careful
mona
-Given: 90
« Reply #2 on: September 02, 2007, 02:37:42 14:37 »
hi and welcome thiru09,,
This is very good work.also for AVR..
It was very hard to find this soft with keygen.,best wishes.. Smiley
forter
-Given: 1100
-Receive: 28
« Reply #3 on: September 02, 2007, 04:01:38 16:01 »
I remember, the similar compiler work under DOS, is it right, thiru09?
Nakla
« Reply #4 on: September 02, 2007, 07:41:00 19:41 »
Password
Password does not work
narc60
-Given: 12
« Reply #5 on: September 02, 2007, 08:08:46 20:08 »
Password works. Copy all characters including slashes.
cyber_drifter
-Given: 167
-Receive: 32
« Reply #6 on: September 02, 2007, 08:40:57 20:40 »
Password doesn't work for me either. Tried with and without /* */
Ret12_12
-Given: 104
-Receive: 32
« Reply #7 on: September 02, 2007, 11:26:43 23:26 »
personal i had the same problem, if i am not mistake this post it is two times anyway the correct code for me it is /*Release1ForSonsivri*/
the wrong it was the /*Release2ForSonsivri*/
Thiru09
-Given: 398
-Receive: 1188
« Reply #8 on: September 03, 2007, 06:15:06 06:15 »
Dear Ret12_12,
Let me clarify your doubt first. Even though I made keygen for both products, I posted the FED WIZ-C PIC compiler in PIC C sub forum and AVR compiler in Softwares and tools section.
Because, if anybody interested in AVR related things, he may overlook PIC C section and he may miss the compiler. I think there is no wrong in this. Anyway if I hurt anybody, sorry for that.
Come to passwords.
Both passwords are working perfectly. I have used Winrar 3.70.
For my next posts, I will remove passwords.
If you still encounter the same problem, please let me know that. I will reupload the both compilers without passwords.
Thank you.
Bye
-Thiru
sonsivritwchen
-Receive: 15
« Reply #9 on: September 19, 2007, 03:48:37 03:48 »
Wiz-C v.14 demo is available now. http://www.fored.co.uk/html/wiz-c_download.html
baggs
« Reply #10 on: September 20, 2007, 01:13:43 01:13 »
The newest version is out, 14.01A. I downloaded it, installed it, then ran it when prompted at installer's close. Once it started up I went to the Register spot & used this poster's keygen. Nice & Simple. You copy thier SN to the keygen hit the keygen's GENERATE button & all the needed data is created for you. I was able to get both newest versions to work PIC & AVR using the keygen. But once you creat the needed code from hitting the GENERATE button you just click on the COPY button next to the needed data then go back to the open program & paste in the data. Then click OK & you are done. I myself closed both software packages then re opened them & under the help button was able to verify that both were running in the Prefesional mode plus the REGISTER button now says REGISTERED!.
I will now start to read the manuals, they are in pdf format so they are EZ to read but as this SOFTWARE is NOT just a compiler it is A LOT MORE thus reading the manual is a must. Both packages look like they would be great as long as they work. As I have many files which error in CCS PCWH 4.049 I will see if this program will catch the same problems or will it allow them to pass. I have the valid ones & the buggy ones marked as such so only time will tell.
As for the password I just copied & pasted it into the newest version of winzip & it opened just fine but as I used the keygen on the 2 newest releases I can not say how the keygen works on this version, just that it worked fine on the 2 newest ones but the posted password worked just fine.
ahmed
-Given: 101
-Receive: 605
« Reply #11 on: September 20, 2007, 04:54:17 04:54 »
Hi to all;
Download v14 from
 if u have already instal v12 instal v14 on it start programe if not work uninstal it by using add remove programme and again instal v14 it will be pro virsion and fully functional.
Unhappy
-Given: 1006
-Receive: 101
« Reply #12 on: December 08, 2008, 07:10:53 07:10 »
I think I was late Thiru or anyone having this keygen please upload again as I have been told it is easy to learn WIZ-C and I wish to try and learn how to write programs for PIC microcontrollers
savnik20
-Given: 37
-Receive: 401
« Reply #13 on: December 08, 2008, 07:41:16 07:41 »
The link still work.
msamar
« Reply #14 on: December 10, 2008, 07:39:37 07:39 »
hello
thanks for WIZ-C very good compiler
professional tools for PIC thanks again , i was thinking of buying this tools but now its available here . i don't know how can i help you.
regards engineer amar
