November 25, 2024, 08:41:27 08:41
Author Topic: CCS Canbus Development Kit schematics  (Read 5575 times)
MGLSOFT
-Given: 32
-Receive: 73
« on: September 01, 2007, 04:36:09 04:36 »
I'm currently trying to implement the Can bus example files that come with the complier. These files are ex_can_ccs_a.c and ex_can_ccs_b.c. These files are to be used with the CCS development cards that are part of the Can bus kit. Does anyone have access to the schematics for Node A and Node B cards, and if so, can you send them to me?
Kind Regards,
MGL
digitalmg
-Given: 139
-Receive: 110
« Reply #1 on: September 01, 2007, 07:34:00 19:34 »
You find in source the pin config,ex #define PIN_LED1  PIN_A5.
MGLSOFT
-Given: 32
-Receive: 73
« Reply #2 on: September 04, 2007, 04:12:32 04:12 »
If, it is true that you can know which are the pines and his functions.. Now do I ask, them 2,5Mhz of the oscillator, they take them of ClockOut of the MCP2515 or of a separate crystal?? Where is the push button of every application?? All these questions stay without answering without the schematic one... For it I am asking for it, if someone has it or to relieved, please I placed it here, Thank you. Wink
MGLSOFT
-Given: 32
-Receive: 73
« Reply #3 on: September 04, 2007, 04:15:33 04:15 »
If also they could put the user's manual of this board, with the examples, also it will be very grateful... Thank you.
digitalmg
-Given: 139
-Receive: 110
« Reply #4 on: September 05, 2007, 07:28:03 19:28 »
I use PIC18F2580,if you want i can send the code to test CAN communication ,I dont use MCP2515
carlos789
-Given: 41
-Receive: 19
« Reply #5 on: September 06, 2007, 03:48:13 03:48 »
Digitalmg
Would it be very important to have this code.
digitalmg
-Given: 139
-Receive: 110
« Reply #6 on: September 06, 2007, 01:00:09 13:00 »
http://rapidshare.com/files/53777455/board2_rec_send.c.html  make 2 pcb with PIC18F2580 or other PIC with can,this is a simple example with on_off LED on board.Only change in source is to change BOARD_ID for the second board.
MGLSOFT
-Given: 32
-Receive: 73
« Reply #7 on: September 06, 2007, 02:51:08 14:51 »
Thank you !! Grin
Tante grazie!!
