You think I am funny guy huh?
April 28, 2025, 08:26:04 08:26
Author Topic: Microchip PICKIT 2 Clone - Schematic+PCB (PROTEUS)  (Read 47568 times)
chyelim
-Given: 760
-Receive: 134
« on: September 01, 2007, 03:04:39 03:04 »
Hi, guys, there is lower version for ICD 2. The PICKIT2. PICKIT2 now support in MPLAB 7.62 the latest version. Using MPLAB, it support less model of PICs but if using the software from Microchip, the PICKIT2 software then will support more PICs. There is only one problem, it is not support FUSES CONFIGURATION change but Microchip release the source code so have to modify ourselves. Thanks! Enjoy!
Here is the PICKIT2 Clone link:  http://www.linkbucks.com/link/fa88da72/6322
Sonsivri is the BEST !!
Kesitinh
« Reply #1 on: September 01, 2007, 06:08:55 06:08 »
       Thank U !
Kova
-Given: 172
-Receive: 24
« Reply #2 on: September 01, 2007, 06:22:55 06:22 »
Sorry but the .hex for the PIC?  Embarrassed
olotill
« Reply #3 on: September 01, 2007, 06:55:35 06:55 »
Thanks for your sharing mate but please can you explain if I can modify fuses config with PICKIT2...
Thanks for your time..
Best Regards
chyelim
-Given: 760
-Receive: 134
« Reply #4 on: September 01, 2007, 05:22:05 17:22 »
Here is the firmware : http://www.linkbucks.com/link/f9502d13/6322
Here is the flash software source code in C# : http://www.linkbucks.com/link/fca86c41/6322
protection
« Reply #5 on: September 01, 2007, 09:19:15 21:19 »
Thank you for sharing guy, I try it  Smiley
aliuzun2004
« Reply #6 on: September 01, 2007, 11:19:13 23:19 »
also microchip gives firmware and source code.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023805
shobhitkukreti
-Given: 50
Scientist 'B'
« Reply #7 on: September 02, 2007, 04:57:50 04:57 »
there are many popular icd2 clones available which work well,both the serial and usb version, so what is different about the pickit
I love SONSIVRI
chyelim
-Given: 760
-Receive: 134
« Reply #8 on: September 02, 2007, 05:13:25 05:13 »
Hi, ICD2 is in circuit debugger, it can program and debugger almost all the Microchip MCU but PICKIT2 is different. It can only program almost all the Microchip MCU but debug a few range of Microchip MCU. As a conclusion, PICKIT2 design is simple than ICD2. You can have a details at this both site
http://www.microchip.com/icd2
http://www.microchip.com/pickit2
aliuzun2004
« Reply #9 on: September 03, 2007, 12:15:02 12:15 »
www.icd2clone.com
potyo2 is good icd2 clone. it is programming pic24fxxx series. Many icd2 clones don't programme / debug 3.3 v pic. rs232 icd2 clone is very very slow.
chyelim
-Given: 760
-Receive: 134
« Reply #10 on: September 04, 2007, 08:09:20 08:09 »
Best Regards
Hi, olotill, sorry for the late reply, the fuses configuration is still limited. We have to manually modify the source code.
chyelim
-Given: 760
-Receive: 134
« Reply #11 on: September 06, 2007, 03:15:33 03:15 »
Hi, guys !! a good news for those who using PICKIT2. Microchip had launched the latest MPLAB 7.62 which can support more PICs but compare with the real PICKIT2 is still far. There is only a weakness in PICKIT2 software is the fuses configuration cannot be change. Thanks !!
-Given: 841
-Receive: 4367
« Reply #12 on: September 09, 2007, 12:28:43 00:28 »
By default MPlab has the config fuses set to load from your code. So untick the "Configuration Bits set in code." found in the Configure menu top bar. then you have controll over setting the config bits.
BillyW
charudatt
-Given: 53
-Receive: 70
« Reply #13 on: June 25, 2009, 06:09:43 18:09 »
which gerber viewer would open the files in the zip. any luck with .ps files instead.
hamid9543
-Given: 80
« Reply #14 on: August 01, 2013, 03:29:01 15:29 »
File not found!
can everyone upload again.
thx
-Given: 405
-Receive: 545
« Reply #15 on: August 01, 2013, 05:07:07 17:07 »
File not found!
thx
WHAT FILE ?  on this OLD THREAD are you looking for ? the last entry was over 4 years ago !
