November 25, 2024, 02:32:50 02:32
Author Topic: ELECTRONICS PROJECTS  (Read 13732 times)
egealtay
-Receive: 78
« on: August 31, 2007, 02:43:11 14:43 »
LPT extender card project. Extend the capability of the old LPT printer parallel port (standard unidirectional type). Usually found on an PC/XT compatible I/O card. By adding this card, you can transfer or read 8-bits of data from LPT printer parallel port.
Download LPT port extender in zip file (12.912 Bytes).
Download LPT port extender schematic in gif format file (30.533 Bytes).
Download LPT port extender PCB layout in gif format file (11.309 Bytes).
Download LPT port extender PCB printout in pdf format file (54.003 Bytes).
Go directly to the LPT port extender-expander page.
 LPT expander card project. Expand the number of I/O port from your LPT printer parallel port (this must be bidirectional port type). Easily programming using PPI-8255. Support 3 programming mode. From simple I/O to handshaking modes. Include sample assembly source program for mode-0 (simple I/O).
Download LPT port expander in zip file (42.410 Bytes).
Download LPT port expander schematic in gif format file (33.715 Bytes).
Download LPT port expander PCB layout in gif format file (13.712 Bytes).
Download LPT port expander PCB printout in pdf format file (46.979 Bytes). for the newest one see decoder card project.
Download LPT port expander power supply PCB printout in pdf format file (15.468 Bytes).
 Vaccine card project. Protect your PC from any boot record virus (Gen-B virus). Using ISA slot. Include firmware assembly source program.
Download Vaccine card firmware source in zip file (12.496 Bytes).
Download Vaccine card schematic in ORCAD format file (1.636 Bytes).
Download Vaccine card PCB layout in ORCAD format file (5.356 Bytes).
Download Vaccine card schematic in jpg format file (33.120 Bytes).
Download Vaccine card PCB printout in jpg format file (49.543 Bytes).
 Go directly to the Vaccine card page.
 IPROM card project. 2 x 2 kByte EPROM emulator interface to computer PC/XT. Using ISA slot.
Download IPROM  schematic file in gif format file (20.147 Bytes).
Download IPROM PCB layout in gif format file (45.130 Bytes).
Download Interface card schematic in ORCAD format file (2.840 Bytes).
Download Interface card 1 PCB layout in ORCAD format file (12.924 Bytes).
Download Interface card 2 PCB layout in ORCAD format file (5.372 Bytes).
Download Interface card 3 PCB layout in ORCAD format file (7.642 Bytes).
Download Interface card schematic in jpg format file (51.384 Bytes).
Download Interface card double layer PCB printout in jpg format file (52.063 Bytes).
Download Interface card single layer PCB printout in jpg format file (24.891 Bytes).
Download Interface card single layer PCB printout in jpg format file (51.550 Bytes).
Go directly to IPROM card page.
 2764 EPROM programmer project using LPT parallel port interface. Simple and low cost programmer for 2764/2764-A type. Include executeable pascal program to run the hardware (Ver 2.25).
Download 2764 programmer in zip file (32.814 Bytes).
Download 2764 EPROM programmer editor in zip file (16.721 Bytes).
Download 2764 programmer schematic in gif format file (108.301 Bytes).
Download 2764 programmer PCB layout in gif format file (19.343 Bytes).
Download 2764 programmer PCB printout in pdf format file (50.705 Bytes).
Go directly to 2764 EPROM programmer page.
 EPROM eraser project. Using a sterilizer ultraviolet lamp. Complete with timer schematic with selectible time for 10 minutes, 20 minutes and 40 minutes period.
Download UV lamp circuit in gif format file (2.834 Bytes).
Download Timer schematic in gif format file (11.316 Bytes).
Go directly to the EPROM eraser page.
 36-Bits LED display driver project. For use to check logic state or any gadgets. Include executeable pascal program to run the display (Ver 1.11).
Download Led display in zip file (31.060 Bytes).
Download Led display schematic in gif format file (31.643 Bytes).
Download Led display PCB layout in gif format file (13.767 Bytes).
Download Led driver PCB layout in gif format file (10.897 Bytes).
Download Led display PCB printout in pdf format file (40.558 Bytes).
Download Led driver PCB printout in pdf format file (92.388 Bytes).
Go directly to LED display driver page.
 6-Digits 7-Segment LED display driver project. Input BCD type. Include executeable pascal program to run the display (Ver 1.01).
Download 7-segment led display in zip file (31.496 Bytes).
Download 7-segment led display schematic in gif format file (79.208 Bytes).
Download 7-segment led display PCB layout in gif format file (18.696 Bytes).
Download 7-segment led display PCB printout in pdf format file (125.193 Bytes).
Go directly to 7-segment LED display driver page.
 Another EPROM programMER project. Using LPT parallel port interface. Support many types of EPROM; 2716, 2732/2732-A, 2764/2764-A, 27128, 27256 and 27512. Include executeable assembly program to run it (Ver 3.11). But in Indonesian version for right now. Also a testing program to check the hardware for the first time point by point.
Download Eprommer in zip file (55.143 Bytes).
Download Eprommer schematic in gif format file (13.868 Bytes).
Download Eprommer PIE in gif format file (7.411 Bytes).
Download Eprommer PCB layout in gif format file (16.902 Bytes).
Download Eprommer power supply PCB layout in gif format file (7.746 Bytes).
Download Eprommer PIE printout in pdf format file (42.042 Bytes).
Download Eprommer PCB printout in pdf format file (94.452 Bytes).
Download Eprommer power supply PCB printout in pdf format file (31.425 Bytes).
Download Eprommer How To Use in pdf format file (304.118 Bytes).
Go directly to EPROMMER page.
 IC-Tester project. This is a parallel version of IC tester circuit that ever built by Paul Stenning (he has serial version). Using LPT parallel port interface. It can be used to check general type of TTL and CMOS IC as long as the sistem is digital. Self made library from data book truth table, create your own checking sequence. Include executeable pascal program to run it (now Ver 1.27). Also a hardware checking program step by step, pascal source available.
Download IC-Tester in zip file (70.599 Bytes).
Download IC-Tester schematic in gif format file (78.182 Bytes).
Download IC-Tester PCB layout in gif format file (35.800 Bytes).
Download IC-Tester PCB printout in pdf format file (191.457 Bytes).
Download IC adapter PCB printout in pdf format file (33.968 Bytes).
Download IC-Tester How To Use in pdf format file (177.900 Bytes).
Go directly to IC-Tester page.
 These are some types of IC-Tester library files, CMOS or TTL IC. Some checked while others not yet. You can make your own library!
Download My first TTL & CMOS libraries file (37.988 Bytes).
Second TTL & CMOS libraries file (72.996 Bytes).
 Decoder card project. Using ISA slot. Expanding the ability of LPT expander card, to use both from LPT parallel port interface, or directly from computer PC I/O bus (dual use). Sample assembly source program available.
Download Decoder card in zip file (20.426 Bytes).
Download Decoder card schematic in gif format file (59.513 Bytes).
Download Decoder card PCB layout in gif format file (14.225 Bytes).
Download modification for LPT port expander schematic in gif format file (39.298 Bytes).
Download modification for LPT port expander PCB layout in gif format file (14.664 Bytes).
Download Decoder card PCB printout in pdf format file (57.117 Bytes).
Download modification for LPT port expander PCB printout in pdf format file (51.164 Bytes).
Go directly to Decoder page.
 Relay driver board project. Up to 8 relays can be interfacing to your computer, using LPT printer parallel port or just any other port type like PPI-8255 from LPT expander card, or using any decoder card. Software to test available.
Download Relay driver board in zip file (111.711 Bytes)
Download Relay driver board schematic in gif format file (31.667 Bytes)
Download Relay driver board PCB layout in gif format file (17.635 Bytes)
Download Windows based software testing program (123.561 Bytes)
Download DOS based software testing program (36.341 Bytes)
Download Relay driver board PCB printout in pdf format file (90.414 Bytes)
Go directly to Relay driver board page.
 Infrared remote receiver project. Toggle one channel remote receiver using available remote control unit. Very suitable for home application.
Download Infrared remote receiver in zip file (38.964 Bytes)
Download Infrared remote receiver schematic in gif format file (33.094 Bytes)
Download Infrared remote receiver PCB layout in gif format file (9.127 Bytes)
Download Infrared remote receiver PCB printout in pdf format file (28.468 Bytes)
Go directly to Infrared remote receiver page.
 Electronic Work Bench (EWB) project. Build your simple tools to accompanied a bread board tool. More creativity, more productive works.
Download EWB in zip file (106.837 Bytes)
Download EWB schematic in gif format file (72.371 Bytes)
Download EWB1 schematic in gif format file (61.072 Bytes)
Download all EWB PCB printout in pdf format file (130.749 Bytes)
Go directly to EWB page.
 Washing machine controller project. Build your simple embedded controlled board using PIC microcontroller PIC-16F84A.
Download Washing controller in zip file (36.530 Bytes)
Download Washing controller schematic in pdf format file (22.056 Bytes)
Download washing controller firmware in zip file (3.468 Bytes)
Download compact version Washing controller schematic in pdf format file (21.721 Bytes)
Download compact version washing controller firmware in zip file (3.609 Bytes)
Download washing controller PCB printout in pdf format file (30.904 Bytes)
Download 2 relays PCB printout in pdf format file (12.842 Bytes)
Download compact version Washing controller PCB printout in pdf format file (30.934 Bytes)
Go directly to Washing machine controller page.
 Computerized Numerical Controlled (CNC) controller project, stepper motor controller board, using the most popular PIC microcontroller PIC-16F84A. Build your simple CNC controller card (An open loop system control, without feed back). A key to the controlled world and embedded system. Connected to LPT parallel port.
Download CNC controller package in zip file (93.360 Bytes)
Download Stepper motor schematic in pdf format file (23.943 Bytes)
Download CNC LPT interface schematic in pdf format file (22.661 Bytes)
Download CNC controlled block schematic in pdf format file (20.652 Bytes)
Download 5-phase stepper controller PCB printout in pdf format file (30.476 Bytes)
Download CNC LPT interface card PCB printout in pdf format file (33.233 Bytes)
Go directly to CNC table page or CNC controller page.
 Intel MCS51 family development board.microcontroller for 8031/32, 87XX series, 89XX series, or BASIC interpreter series. 3 kind of designed versions, to run an asm monitor program like PaulMon, to run intel BASIC52 interpreter and to run BASIC31 interpreter. Connection to PC using serial port COM.
Download 8031/32 development board package in zip file (446.031 Bytes)
Download 8031/32 development board schematic in pdf format file (40.598 Bytes)
Download 8031/32 development board PCB printout in pdf format file (97.896 Bytes)
Download 8031/32 development board PCB printout mirrored version in pdf format file (97.905 Bytes)
Download MCS51 BASIC31 V1.2a development board package in zip file (298.645 Bytes)
Download MCS51 BASIC31 V1.2a development board schematic in pdf format file (42.051 Bytes)
Download MCS51 BASIC31 V1.2a development board PCB printout in pdf format file (105.092 Bytes)
Download MCS51 BASIC31 V1.2a development board PCB printout mirrored version in pdf format file (104.845 Bytes)
Download MCS51 BASIC52 V1.1 development board package in zip file (333.021 Bytes)
Download MCS51 BASIC52 V1.1 development board schematic in pdf format file (39.901 Bytes)
Download MCS51 BASIC52 V1.1 development board PCB printout in pdf format file (98.741 Bytes)
Download MCS51 BASIC52 V1.1 development board PCB printout mirrored version in pdf format file (99.006 Bytes)
Download Intel MCS51 BASIC52 Manual book in pdf format file (795.231 Bytes)
Download STTS Edu MCS51 BASIC52 Manual book in pdf format file (1.188.345 Bytes)
Download Intel MCS51 BASIC52 Manual text version package in zip file (429.206 Bytes)
Download Jan Axelson Quick Reference Guide from MIB book in pdf format file (44.021 Bytes)
Go directly to MCS51 development board or BASIC31 development board or BASIC52 development board
B. ANY KINDS
 Have you ever play the legendaric digger game (85.073 Bytes)?. A long time ago, this game very popular, but it can run only in PC/XT computer type. I am very fond of this game. Now this version can run in windows dos box (win'9x). The speed can be adjusted.
http://www.geocities.com/dsaproject/downloads/downloads.html
 Have you ever made a mosquito electronic repellant (186.146 Bytes)? This is another kind of it but all software, man!
 This two programs, utilize the PC sound card to become a simple oscilloscope (154.020 Bytes) or a sine wave generator (119.394 Bytes) from BIP Electronics Labs 3 by Marcel Veldhuijzen. Very good display.
 I found this program to demostrate the capabilities of PPI-8255 (240.572 Bytes) from Electronics Australia Today, programming as mode-0 ~ mode-2 and any combinations possible. A good example program.
egealtay
-Receive: 78
« Reply #1 on: August 31, 2007, 02:53:34 14:53 »
http://rapidshare.com/files/52465402/ELECTRONICS_PROJECTS.txt.html
B. ANY KINDS
smainj
-Given: 70
-Receive: 75
« Reply #2 on: August 31, 2007, 07:35:58 19:35 »
www.geocities.com is colsed in my country
please anyone can help me Smiley
techno
-Given: 809
-Receive: 132
« Reply #3 on: September 01, 2007, 02:21:40 14:21 »
couldn't accessed !!!
Tarekovitch
« Reply #4 on: December 01, 2007, 10:47:19 10:47 »
how can i download that projects pilzzzzzz  Roll Eyes
analog
« Reply #5 on: December 03, 2007, 10:17:12 10:17 »
Good project, that's useful!!!
MAXPAYNE
-Given: 499
-Receive: 364
It's a little funny......
« Reply #6 on: December 06, 2007, 07:52:35 07:52 »
Where is the links Huh
Mr Dee
-Given: 28
« Reply #7 on: December 12, 2007, 07:57:28 07:57 »
can't download it !
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #8 on: December 17, 2007, 12:31:14 00:31 »
there are link for page with all links  Shocked just read Smiley
for me there are two nice project Smiley cnc and Washing machine controller project
Mr Dee Huh why I try and all links work....  Roll Eyes
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #9 on: December 18, 2007, 07:22:45 07:22 »
 Embarrassed probably your country have problem with geocities ... you can try to use some proxy or some program wit hide ip... or if you still cant do that tel me what you wont to dl and I will found link for you on other server...  Undecided
« Last Edit: December 19, 2007, 02:36:08 02:36 by zokij » Logged
yugal
 Warned
-Given: 919
-Receive: 73
« Reply #10 on: December 18, 2007, 09:29:59 09:29 »
       Cnc project is very good design.Eprom programmer is also good.
                                                           yugal
JimBaton
« Reply #11 on: December 20, 2007, 02:29:42 14:29 »
very helpfull and good project
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #12 on: December 20, 2007, 02:36:59 14:36 »
 Shocked The best project which I see on some website is on gevv website (I have little problem with language but still is very nice) Best design of website very useful project some nice useful programs  Roll Eyes
You must see it  Wink
Mr Dee
-Given: 28
« Reply #13 on: December 20, 2007, 06:52:34 18:52 »
finaly, i can download it
genviktr
« Reply #14 on: February 07, 2008, 07:25:11 19:25 »
Useful site about electronic projects  http://www.edn.com/  Smiley
MAXPAYNE
-Given: 499
-Receive: 364
« Reply #15 on: February 08, 2008, 12:28:58 00:28 »
what is gevv site address ?
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #16 on: February 12, 2008, 03:41:54 03:41 »
 Wink As you can see on members info gevv website is   Shocked  http://320volt.com/   Roll Eyes
otakis
« Reply #17 on: March 14, 2008, 10:18:39 22:18 »
very usefull project for newbies, like me Smiley Smiley Smiley
pance
« Reply #18 on: September 26, 2008, 05:29:05 17:29 »
Hi can you help me to download cnc project from
i cant download
godblessu
-Given: 133
-Receive: 297
« Reply #19 on: September 26, 2008, 07:06:16 19:06 »
i cant download
Here is CNC project files.
http://rapidshare.com/files/148615351/5_Phase.zip
