cup58
-Given: 412
-Receive: 561
« on: October 11, 2012, 04:10:15 04:10 » |
Published in the November 1964 issue of Popular Science magazine, the article "PS builds a laser ... and so can you" is perhaps the first hobby laser project published. It's interesting to see the electronic circuit is quite simple.
« Reply #1 on: October 11, 2012, 04:52:26 16:52 » |
Does it use a ruby rod and Xenon flash pump, which i believe was the tech of that day? If so, building one from a CD burner is a LOT cheaper
« Reply #2 on: October 11, 2012, 06:14:53 18:14 » |
Interesting article.
For these days, a 40 Watt CO2 laser tube is cheap enough to play with.
« Reply #3 on: October 12, 2012, 07:59:47 19:59 » |
The trick with CO2 is the optics. Got plans for a cutting/engraving 40W+ setup?
« Reply #5 on: October 12, 2012, 09:50:38 21:50 » |
Got plans for a cutting/engraving 40W+ setup? Here is on the web: http://www.buildlog.net/cnc_laser/index.phpFor laser tube, lens, power supply, etc - just search on ebay with "CO2 laser tube". I might write my own build someday. -ichan
snowman
-Given: 183
-Receive: 53
« Reply #6 on: October 13, 2012, 12:48:00 00:48 » |
I have a 40w chinese laser and I really appreciate if someone posts laser power supply plans. my power supply does not support pwm input. I need to replace it, without pwm its just a toy. it cannot be used with mach3 like cnc software without pwm input.
PS: and be careful with chinese laser tubes. their gas leaks in time. almost every tube leaks, yes, but come cheap tubes have 6 months shelf life. sealing glass tube with metals is tricky I believe.
« Reply #7 on: October 13, 2012, 04:37:35 04:37 » |
The book is $0.05 on Amazon.com.... The Chinese substitute materials - glass to metal seals need to be pure, O2-free, copper....but it is expensive, so to them...copper is copper...
« Reply #8 on: October 13, 2012, 08:47:54 08:47 » |
Many 40W chinese laser tube for that small laser engraving machine (the $600-ish machine) actually have a real power of 25W, I've been told by one of the machine manufacturer - better ask the seller if the tube is true 40W or not, it should not be lower than $120 at it's origin.
Lower power chinese laser tube mostly only have about 2000 hours lasing time, but higher grade reci tube (80 - 150W) have 10000 hours lasing time warranty and several years of self life.
