April 26, 2025, 12:16:27 12:16
Author Topic: J-Link EDU Nag Screen Remover  (Read 7236 times)
Goooo
« on: October 03, 2012, 05:51:12 17:51 »
As it's annoying to accept the “J-LINK EDU Terms of Use” every day, I suggest you this patch that works with the last version (V4.54a).
This patch remove the “J-LINK EDU Terms of Use" nag screen. So you are don't require to accept it every day.
This file is for educational purposes only. I don't support cracking software as an alternative to paying for it, and I sincerely ask anyone who uses this patch not to distribute it.
PW: sonsivri
Update:
01/01/2013 : New update for the new year ! V4.58a
« Last Edit: January 01, 2013, 12:54:14 12:54 by Goooo » Logged
kreutz
-Given: 1004
-Receive: 127
« Reply #1 on: November 14, 2012, 12:22:52 00:22 »
Hi;
The latest version is V456d. Does the patch work on this version too?
Best regards,
k
Goooo
« Reply #2 on: January 01, 2013, 12:00:23 12:00 »
Unfortunately I think it will not work since the DLL is updated in each new version.
Since it seems to be helpful, I will update it.
Update:
I have added the patch for the last version. If you really require V4.56d, just ask.
« Last Edit: January 01, 2013, 12:55:34 12:55 by Goooo » Logged
diaz
-Given: 41
« Reply #3 on: March 21, 2013, 12:51:49 00:51 »
Can I bother you to ask if you have a patch of the current version V4.66 ? Or failing that can you share a copy of the V4.58a software ?
Thanks.
Diaz.
EDIT, found previous versions here http://www.segger.com/j-link-older-versions.html no idea why Google took so long to find this for me !!!! Still interested in a fresh crack if it's about.
Posted on: March 18, 2013, 08:39:43 20:39 - Automerged
OK, I medicated V4.66. I am a reversing noob so there may still be errors, sorry. Structure of the dll had changed since 4.58.
Worth noting Altium produced the nag screen when loading even with the patched version installed in the usual place. This is because Altium accesses a dll kept in the following location C:\Program Files\Atmel\sam-ba_2.11\drv change this dll as well and the nag disappears Smiley
password: sonsivri
« Last Edit: March 21, 2013, 12:57:13 00:57 by diaz » Logged
