November 23, 2024, 11:25:29 11:25
Author Topic: GTP-USB-Lite Programmer (again)  (Read 17230 times)
tripp
-Given: 27
-Receive: 52
« on: August 30, 2007, 06:12:56 18:12 »
Nice design. Grin
http://ali3nworld.blogspot.com/
Schematic + PCB Design + Component Layout
Have a look.
boris
-Given: 60
« Reply #1 on: August 31, 2007, 01:18:27 01:18 »
The only problem with the LITE version is, that is works ONLY with winpic 3.55, wich supports less PICs and other uPs than the latest version.
iphone
-Given: 115
« Reply #2 on: August 31, 2007, 11:29:27 11:29 »
So far ... USB Lite version can programmer 18F2550, 18F4550 also 16F877A
Others PIC, I dont test it.
aj49m
-Given: 36
-Receive: 41
« Reply #3 on: August 31, 2007, 04:18:35 16:18 »
look in http://www.freewebs.com/eclip-se/inicio.html
is similar.
iphone
-Given: 115
« Reply #4 on: August 31, 2007, 06:43:08 18:43 »
looks good.
Do you make one ?
hodahel
-Given: 189
Catch me...
« Reply #5 on: September 01, 2007, 07:43:38 07:43 »
Can I used PIC18F2455 instead of 18F2550?
BR
iphone
-Given: 115
« Reply #6 on: September 01, 2007, 04:10:28 16:10 »
BR
Why not you tried it ... because 18F2455 & 18F2550 have same amount of pin ... but dont check on pin position on either one.
Just tried it ... and share over here the result as info for others.  Wink
-Given: 553
« Reply #7 on: September 01, 2007, 05:16:39 17:16 »
has some got 3.55 vesrion of winpic I want to try something out ha it does not work in the later version
cheers
wizpic
aj49m
-Given: 36
-Receive: 41
« Reply #8 on: September 01, 2007, 05:37:58 17:37 »
Still not  Sad
chyelim
-Given: 740
-Receive: 134
« Reply #9 on: September 01, 2007, 05:39:27 17:39 »
cheers
wizpic
Hi, wizpic, here is what you want : http://www.linkbucks.com/link/faa9fd67/6322
valajor
If we do, we understand.
« Reply #10 on: September 01, 2007, 06:15:10 18:15 »
Hey friends,
in my blog I put some links to download WinPIC 3.55g and .hex, visit http://ingeniebrio-peru.blogspot.com, is in Spanish but you can find easily the links. You can find Schematics and PCB, too.
I have tested it with 16F84A, 16F628A, 16F877A, 18F2550, 18F4550, 18F448 and dsPIC30F4013 without problems, it's great.
See ya...
Share the Knowledge!!
Kesitinh
« Reply #11 on: September 02, 2007, 04:29:37 04:29 »
          link die.
iphone
-Given: 115
« Reply #12 on: September 02, 2007, 07:53:59 07:53 »
          link die.
The link working ...  Smiley
hodahel
-Given: 189
Catch me...
« Reply #13 on: September 03, 2007, 02:49:42 02:49 »
BR
I'll try it and share it here if it works..
olotill
« Reply #14 on: September 03, 2007, 03:13:59 03:13 »
Hi mates...
If somebody needs GTP USB LITE, I have a design including ZIF socket... Maybe you need it... so please if you are interested just write on this post and I will upload gerber files and pdf files for your building...
Best Regards.,..
Olotill
gem1144aaa
-Given: 134
-Receive: 27
« Reply #15 on: October 27, 2007, 05:08:22 17:08 »
BR
Dear the 18f2455 is pin to pin replacement of 18f2550 but 1/2 the program memeory size of 18f2550
so you have to check the size of code that shall be used
tn
« Reply #16 on: November 04, 2007, 01:01:42 13:01 »
great thank you
sohel
-Given: 167
-Receive: 149
« Reply #17 on: November 04, 2007, 01:10:48 13:10 »
it ur first topics.
"THANK YOU" button have been added
Users who post (Thank u) posts will have a (warning) or a (Ban)...
Users who post empty or meaningless posts will be Banned ..
Don't spam our forum with non sense posts just to increase your posts count...
To say thank u (just click "Thank u" button) in any topic instead of posting a new post
Demo for (Thank you) have been added to this topic   (u can test it here)
it will look like this and it appears in every post
Thank you
jcarlos
« Reply #18 on: November 16, 2007, 08:36:12 20:36 »
Hi mates...
Best Regards.,..
Olotill
Hi Olotill,
   Can you upload please your design, I'm interested in build this programmer.
omidsht
-Given: 60
-Receive: 16
« Reply #19 on: November 17, 2007, 03:11:40 15:11 »
Hi mates...
Best Regards.,..
Olotill
hi olotill ,yes please do it
chyun3
-Given: 43
« Reply #20 on: December 02, 2007, 01:31:21 01:31 »
Hi, those who had built this programmer, may i know wat is the fuses setting to program the 18F2550??
KhepeleSibilo
Translator
-Receive: 412
« Reply #21 on: December 02, 2007, 06:27:38 06:27 »
in edaboard.com Thelux answer some one like this :
http://www.edaboard.com/ftopic131183-0-asc-30.html
Configuration Bits from MPLAB:
USB Clock Source: Clock src from 96MHz PLL/2
CPU System Clock Postscaler: [OSC1/OSC2 Src: /1] [96MHz PLL Src: /2]
96MHz PLL Prescaler: Divide by 3 (12 MHz input)
Oscillator: HS: HS+PLL, USB-HS
Fail-Safe Clock Monitor Enable: Disabled
Int. Ext. Switch Over Mode: Disabled
USB Voltage Regulator: Enabled
Power Up Timer: Disabled
Brown Out Detect: Enabled in hardware, SBOREN disabled
Brown Out Voltage: 2.0V
Watchdog Timer: Disabled-Controlled by SWDTEN bit
Watchdog Postscaler: 1:32768
CCCP2 Mux: RC1
PortB A/D Enable: PORTB<4:0> configured as digital I/O on RESET
Low Power Timer1 Osc Enable: Disabled
Master Clear Enable: MCLR Enabled, RE3 Disabled
Stack Overflow Reset: Enabled
Low Voltage Program: Enabled
Extended CPU Enable: Disabled
Code Protect: ALL Disabled
Data EE Read Protect : Disabled
Table Write Protect Boot: Disabled
Config. Write Protect: Disabled
Table Read Protect: ALL Disabled
Table Read Protect Boot: Disabled
Values: 22 0E 3F 1E 81 85 0F C0 0F E0 0F 40 (From MPLAB)
Values: 0E22 1E3F 8100 0085 C00F E00F 400F (From WinPic800)
With WinPic800 settings from HEX file are OK.
WIth MPLAB you need to change "USB Voltage Regulator" setting to "Enabled"
I know it because the first time I used MPLAB and GTP doesn't work so I used WinPic800 with
JDM and all goes OK.
Later, comparing fuses in both programs I discovered the reason...
I suggest you, if you're building Lite version, to add T_Vdd switch as in the Plus Version:
BC557 with:
E= VCC
C= 10K resistor to GND / T_Vdd OUT to ICSP
B= 2K2 resistor to RB2
My version (3.55g) was downloaded from:
http://snipurl.com/ta29
(found also in http://www.electoday.com/freeware/WinPic800_v355g.rar but not tested)
and it has all hardware and languages files (not found in other files from other sites)
Good work... it's a very useful programmer.
i try to program 18f4550 insteed of 18f2550 but after connect to pc it say:
UNKNOWN DEVICE ...
btkd
« Reply #22 on: December 04, 2007, 07:40:46 19:40 »
GTP USB LITE work fine with Intel chpset but didn't with Nvidia. Any solutions?
Online Online
-Given: 834
-Receive: 4321
« Reply #23 on: February 20, 2015, 09:00:41 21:00 »
Make A pickit2 clone... or buy one and put an end to iy.
