April 30, 2025, 02:27:24 02:27
Author Topic: SD card Interfacing with 8051(P89v51rd2)  (Read 8991 times)
SANEMB
« on: September 04, 2012, 07:09:47 07:09 »
i want to interface sd card with p89v51rd2,wat is the hardware interface bz for sd card requires 3.3 v supply but p89v51rd2 has minimum 4.5 v supply is required please suggest.
suggest a circuit diagram
Thanks in advance
pablo2048
-Given: 136
-Receive: 86
« Reply #1 on: September 04, 2012, 07:53:10 07:53 »
Use the same schematic as for older AVR CPUs which have same 5V power supply. (If you are too lazy to search internet, use this http://project.irone.org/interface-avr-with-sd-card.html for example...)
rentau
-Receive: 15
« Reply #2 on: September 05, 2012, 04:18:08 16:18 »
you can have level shiftier, to convert 5 to 3 and v.v...
and for SW, this is a good module to use
http://elm-chan.org/fsw/ff/00index_e.html
everything has its beginning ,not all has its end~
wellnerson1
-Given: 35
-Receive: 153
« Reply #3 on: September 05, 2012, 04:26:17 16:26 »
Dear friend,
See this link may be useful for you.
http://www.dharmanitech.com/
http://www.dharmanitech.com/2011/05/microsd-atmega32-datalogger.html
Brosske
-Given: 75
-Receive: 292
« Reply #4 on: September 05, 2012, 04:50:42 16:50 »
Hi all,
Look in the datasheet if the logic '1' level for the p89v51rd2 is detected on 3.3V. Sometimes the chip is compatible...
For the signals that go to the SD-card, I use 10k resistor.
But I agree that level-shifter is more proper way to do it.
greetz.
Do or do not - there is no try
« Reply #5 on: September 06, 2012, 05:20:33 05:20 »
You should Google before you waste everyone's time asking here. No problem answering questions to help you understand a particular problem, but you should at least make an effort on your own.
See the 1st hit.
http://www.google.com/search?q=8051+sd+card
flo0319
« Reply #6 on: October 24, 2012, 10:59:36 22:59 »
Hi, if you want to interface a SD/MMC card with a MCU using SPI bus you need to know that the SPI lines are unidirectional and signal is digital and if your MCU work at 5V you can use 2 simple method for level voltage shift: 1) zenner diode 3v3(or 3v6) between MOSI,SCK,CS line and Ground; 2) resistors (1K - 10K ohms, depends of mcu output current on pin) in series with MOSI,SCK and CS line. Other method like a voltage divider are not so good because after Init a memory card need to work at a high speed and signal wave is change from square in sine (partial, but at a very high speed is a problem with the sample moment).
