November 24, 2024, 12:21:37 00:21
Author Topic: TURBOCNC  (Read 17605 times)
fernandodiaz
« on: August 26, 2007, 11:19:33 23:19 »
Hi some have turbocnc 4.01 in code open source pascal for make modification
avr123
« Reply #1 on: August 31, 2007, 07:08:20 07:08 »
I find it too.
fernandodiaz
« Reply #2 on: August 31, 2007, 10:29:11 22:29 »
 Cheesy  THE TURBOCNC IS THE BEST INTERPRETER G & M CODE
VERY MUCH STABLE  DOS  OPERATION.
mits
« Reply #3 on: September 12, 2007, 04:57:21 04:57 »
  A better choice is CNCPRO, once an expensive software now an open source project,
  you can get it here: http://tech.groups.yahoo.com/group/CNCPro/ , including its
  source code, is written in "C", also works in DOS.
       Mits
       Saludos
avralam
-Given: 153
-Receive: 30
« Reply #4 on: September 12, 2007, 08:07:05 20:07 »
Yahoo groups says: Request to join CNCPro denied. cannot see nothing.
 Please everyone upload CNC Pro in rapidshare or better mihd.net.
mits
« Reply #5 on: September 13, 2007, 06:38:03 06:38 »
  As requested here it is:
              http://rapidshare.com/files/55297772/CNCPRO.rar
  Includes the exes, source code, and versions modified by some users,
  just needs the Borland Compiler to make mods, I donĀ·t have it at hand
  at this moment but as soon I find it, I will put it here.
     Mits
      Saludos
ceracera
-Given: 12
-Receive: 73
« Reply #6 on: September 13, 2007, 09:58:59 09:58 »
Thanks for CNCPRO but I also would like to see Source code Turbocnc, does anybody have it?
fernandodiaz
« Reply #7 on: September 14, 2007, 04:30:43 04:30 »
Hi friends is just with i need
micropar
-Given: 44
« Reply #8 on: September 17, 2007, 04:25:15 04:25 »
Hi all,
TurboCNC is better, stable, proven software with source codes for long times, currently running or still supported upto version 4.01.
Very long inning indeed, for the shareware software.
Glad if someone share.
Thanks in advance,
--micropar--
fernandodiaz
« Reply #9 on: September 18, 2007, 04:26:38 04:26 »
Yes turbocnc is a good shareware is very faster  run up 20 Khz pulse  in the prnter port in no very new PC support up 5 axis at same time but no have the surce in pascal Cry
djohn
-Given: 8
-Receive: 19
« Reply #10 on: October 03, 2007, 08:29:02 08:29 »
       Mits
       Saludos
Is this CNCPRO same as the one offered by camsoft? Got confused a bit because Camsoft (www.camsoftcorp.com) seems to be offering the CNC PRO at their website and seems to be still expensive Smiley
mcr
-Given: 217
-Receive: 23
« Reply #11 on: February 28, 2008, 11:34:14 23:34 »
Any body has TURBO CNC.
Please.
CDT
« Reply #12 on: March 01, 2008, 11:13:11 11:13 »
 have you got circuits which use microcontroller(AVR,PIC) accord with TURBOCNC?
Please share.
sevesa
« Reply #13 on: March 14, 2008, 11:15:18 23:15 »
Hi friends
I need cnc source code
Thanks.
hhh4h
« Reply #14 on: April 20, 2008, 04:54:27 16:54 »
Any open source sites on CNC control software?
FTL
-Given: 170
-Receive: 33
« Reply #15 on: June 08, 2012, 10:08:51 22:08 »
I know this is a pretty old topic, but here is some information:
You can download TurboCNC from:
http://www.dakeng.com/turbo.html
You can download the Borland Pascal source code from:
http://www.dakeng.com/super_secret_code_link_do_not_distribute/sourcearchive.html
You need to know the pasword, which is attached below.
« Last Edit: June 08, 2012, 10:34:41 22:34 by FTL » Logged
« Reply #16 on: June 09, 2012, 06:44:10 06:44 »
Don't waste your time, people, like I did. It only runs on DOS, or command prompt Win 97.
Why are you posting DOS stuff in a 5 year old thread? Does this mean we should all be digging out our 8 inch floppy drives?
Please post CNC source for Win 7 and modern machine architectures that people can actually use, like:.
LinuxCNC http://linuxcnc.org/
Something like that for Win 7 machines for example.
FTL
-Given: 170
-Receive: 33
« Reply #17 on: June 09, 2012, 07:33:52 07:33 »
Solutions, you are correct, TurboCNC is an old piece of software (last updated in 2005) that only runs on a PC under DOS. I'm sorry, that was mentioned in somewhat subtly in an earlier post. Even that old post was from when DOS stuff was pretty much obsolete.
It still does have a place in the modern world. If you have a CNC device with a dumb controller that is driven by a parallel port, my understanding is that this is one of the few options for driving it. You pretty much have to dedicate an old PC to be in the shop beside the CNC machine (you probably don't want to put a new one there). The PC must have a real parallel port, or at least one on a PCI card. USB-parallel devices will not work.
TurboCNC can drive up to three steppers (x,y,z) connected to a dumb controller (using 4 I/O lines per stepper to drive the stepper phases) via a parallel port at up to 20KHz. It apparently does have a good G-code interpreter and is still used a bunch in the real world.
« Reply #18 on: June 09, 2012, 04:44:06 16:44 »
No, it's not one of the few options. I know a bit about old machines and parallel ports - got one. Mach3 does it, and I recall it does 5 or 6 axes. And PCI cards work just fine - SOME USB/Parallel work, most don't from what I've heard.
http://www.sonsivri.to/forum/index.php?topic=11590.msg64311#msg64311
A lot of guys are doing some amazing hacks on existing machines with LinuxCNC. Check this out (it used to be a three axis machine and runs off a parallel port or two, now):
http://www.youtube.com/watch?v=7WCrqqoZkPg
http://www.youtube.com/watch?v=1EYaM4FkASA
