SANEMB
« on: August 15, 2012, 01:22:26 13:22 » |
While flashing the code in pic18f27j13 controller.we are getting the below programming error using PICKIT 3 as well as MPLAB ICD 3 programmer. Please find the attached snapshot.
Target Device ID (00000000) does not match Expected Device ID(00005690).
Please advice.
gan_canny
-Given: 101
-Receive: 26
« Reply #1 on: August 15, 2012, 02:16:41 14:16 » |
Read the data sheet for the PIC twice.. especially the programming section Check MCLR has a pull up ( 10k works) Check PGC PGD .....now if they aren't on the standard pins (ex RB7 RB6) make sure your fuse points to the pair you have wired. Check ground and Vcc
Amon
-Given: 65
-Receive: 50
« Reply #2 on: August 16, 2012, 09:50:15 09:50 » |
And power your board.
« Reply #3 on: August 16, 2012, 10:42:08 10:42 » |
and update your MPLAB copy.
motox
-Given: 259
-Receive: 327
« Reply #4 on: August 16, 2012, 12:06:15 12:06 » |
That’s an electrical problem. Check all connections, power supply and keep the cable between the programmer and the device shorter than 15cm. I had soooo many programming issues because the cable was too long.
Skarden
-Given: 20
-Receive: 26
« Reply #5 on: January 03, 2013, 10:49:39 10:49 » |
I had the same problem and it was caused by the printer driver (Samsung cpl-310) in my case. Stopping the application running in the taskbar (the one that gives the ink level status) fixed the problem. Regards
piappo
« Reply #6 on: January 03, 2013, 01:35:04 13:35 » |
The pic is bad or the problem is in the two line pgc pgd.
Skarden
-Given: 20
-Receive: 26
« Reply #7 on: January 11, 2013, 08:01:07 08:01 » |
Hello, I have another (strange) message like that :
"Target Device ID (0x0) does not match Expected Device ID (0x0)"
This happens since I installed MPLABX 1.6 trying to program a 16F1455 with a pickit 3.
Trying to program a pic32, this doesn't happens.
The (strange) think is that, if I ignore this message, the pic is programmed properly even in debug mode!
So I think it's a bug of the 1.6 version (maybe in the firmware uploaded in the pickit 3).
Wait for next release ? .....
« Last Edit: January 11, 2013, 01:06:24 13:06 by Skarden »
xpress_embedo
-Given: 122
-Receive: 254
« Reply #8 on: January 12, 2013, 01:12:33 13:12 » |
Are you using a Genuine PIC Kit 3 from Microchip or some clone as i read somewhere you are suggesting someone to use PIC KIT 3 Clone from ebay. May be it is the Problem of that clone. Try to program some other controller on some other board, to check whether your PIC KIT 3 is okay or not. I get this error few days back, and my case the controller was faulty, i don't know how  Also check your connections and power supply voltage.
Skarden
-Given: 20
-Receive: 26
« Reply #9 on: January 12, 2013, 02:14:32 14:14 » |
Hello, my programmer is a clone bought on ebay but it's build on the original schematics and use the original software. The bug relates just to the error message as, if I ignore it, the programming and the debug works properly. The snag I found concerns only the 16F1455 as it works without any problem with other kinds of PICs.
I tried to roll back to MPLAB-X 1.51 and I confirm that the problem disappear.
juvann
-Receive: 61
« Reply #10 on: January 12, 2013, 03:34:57 15:34 » |
I will receive PIC16F1455 in a few days, I have an original PicKit3 so I will try it. You can try to open a case in Microchip's support. Have you tested also with Mplab IPE?
Skarden
-Given: 20
-Receive: 26
« Reply #11 on: January 12, 2013, 04:00:40 16:00 » |
Yes, same problem.
juvann
-Receive: 61
« Reply #12 on: February 11, 2013, 01:11:10 13:11 » |
Microchip tell me, they will resolve the issue in the next release of MPLabX
Skarden
-Given: 20
-Receive: 26
« Reply #13 on: February 15, 2013, 01:38:58 13:38 » |
Same problem for the 16F1459 too !
thunderer
-Given: 19
-Receive: 69
I try to be patient
« Reply #14 on: February 16, 2013, 02:43:26 02:43 » |
Those chips are younger than Pickit3 (and even Pickit2) so some hiccups are normal. They said both Pickit 2 and 3 will have a fix for these chips. Go to Michochip forums for more details. Then get back here once solved to let us know
pheonixtech
« Reply #15 on: December 28, 2015, 11:21:45 23:21 » |
I'm not too familiar with the 18F series, but it may be worth checking your config bits to make sure that you have the correct ICSP port selected on the micro. I know with the 24FJ64GA002 et al that you have 2 or 3 sets of PGD and PGC pins. I've had a headache before with this...
Posted on: December 29, 2015, 12:19:59 00:19 - Automerged
BharatSujanani
-Given: 32
-Receive: 24
All is Well
« Reply #16 on: March 16, 2016, 12:04:43 12:04 » |
I had same problem with MPLAB IDE. Than i have tried this in MPLAB x IDE than there is no problem. PLease try this.
Bharat Sujanani
sakugava
Translator
-Given: 291
-Receive: 188
« Reply #17 on: March 27, 2016, 02:49:08 14:49 » |
hanle
Warned
-Given: 21
« Reply #18 on: May 24, 2017, 04:21:22 04:21 » |
You can use function "Download PICkit Operating System" from Tool menu. It maybe resolve this problem.
hunter07
-Given: 19
« Reply #19 on: July 18, 2017, 08:28:31 20:28 » |
Clean your PCB with isopropyl alcohol then pressured air. There may be some short circuit or low resistance between pads/tracks due to solder paste residue. Good luck
« Last Edit: January 28, 2019, 07:51:49 19:51 by hunter07 »
GroundPlaneLoop
« Reply #20 on: September 08, 2017, 07:52:13 19:52 » |
Check comm on PGC/PGD and MCLR level w scope. Seems to be a problem related with connection. Also try to reflash the bootloader in the Pickit - holding the button and connecting USB, then download OS with the pickit3 app. The pickit3 standalone app is somewhat buggy, and regarding clones, I have also a clone and sometimes the OS upgrade is stuck, but with the button trick, it is possible to recovery it. Have some problems with uploading OS from MPLAB also, but only use it for programming.
natur3k
« Reply #21 on: March 29, 2018, 06:18:21 18:18 » |
I came across a similar problem with PIC18 and original PICKIT3. At first we suspected a HW issue but many more brand new MCUs were tested with the same result.
I checked and excluded other problems first i.e. configuration, MCU to PICKIT3 connection, software.
Environment: MPLAB X IDE v4.05 @ Windows 7 x64
Solution that worked for me: I tried the older firmware from MPLAB IDE v8.92, i.e. PK3FW_012890.jam (2013-06-13), from Microchip archives. In your project go to Options, 'Firmware' category, uncheck 'Use Latest Firmware' and choose the older firmware.
« Last Edit: April 03, 2018, 05:40:20 17:40 by natur3k »
PM3295
-Given: 365
-Receive: 155
« Reply #22 on: April 03, 2018, 07:06:25 07:06 » |
I found, for some reason, when I use MPLAB IDE v8.84, I get the same ID problem, but only on a Win 7-64 machine. On a 32 bit machine, it works without a problem.
towlerg
-Given: 474
-Receive: 104
What is this for?
« Reply #23 on: April 03, 2018, 12:25:04 12:25 » |
Given the previous post this clearly isn't the problem but for anyone reading this thread at a later date. On another board it was pointed out the with PGD and PGC TISE'ed as outputs, MCLR disabled and some combination of fuses it was necessay to use the "Use Vpp first program entry" option (available on both Pickit2 and 3 GUI and IPE).
Win 7 Ult x64 SP1 on HP2570p
natur3k
« Reply #24 on: April 03, 2018, 05:33:32 17:33 » |
Well, my solution was an answer to a rather different question, i.e. 'my PICKIT3 is properly attached to target MCU, I followed the documentation and googled a lot, but still the device ID cannot be found', and flashing brand new MCUs. Just now I checked Microchip forums, where 8.92 version was mentioned as a working one (however, older than 8.92 versions were disadvised). PICKIT3 reflashing is not such a problem, really.
« Last Edit: April 03, 2018, 05:43:36 17:43 by natur3k »
