November 25, 2024, 10:23:34 10:23
Author Topic: Request for float charger design 12v  (Read 3862 times)
moosh
-Given: 35
« on: August 24, 2007, 03:53:48 03:53 »
Hi. Does anyone have a working 12vdc float charger design using a sealed lead acid battery and 240vac mains supply? The charger should normally power a 12 v circuit and trickle charge the sla battery which kicks in when the mains supply fail. You'll find this charger in card-access systems and alarm panels.
Any leads much appreciated.
Breixo
-Given: 22
« Reply #1 on: August 25, 2007, 06:43:12 18:43 »
Hi moosh,
Look in the Microchip site for the Application Note AN714 'Wireless Home Security Implementing KEELOQ® and the PICmicro® Microcontroller'. It has a full documented Battery Charger for a 12V lead-acid battery from YUASA (for 4Ah or 7Ah) and a 5V 1A Power Supply with automatic switching between AC source and Battery source.
Bye,
moosh
-Given: 35
« Reply #2 on: August 28, 2007, 10:35:00 10:35 »
Thanks for the lead, Breixo. Looks like it's a simple and usable design.
crowinu
« Reply #3 on: August 31, 2007, 09:38:48 09:38 »
do you need it with descreet components, once i found some dedicated ic's which does the job for float charging
http://focus.ti.com/docs/prod/folders/print/uc3906.html
« Last Edit: September 01, 2007, 10:22:35 10:22 by crowinu » Logged
It Can't Rain All The Time
moosh
-Given: 35
« Reply #4 on: September 05, 2007, 09:22:58 09:22 »
Will the circuit work with a load on the power supply? The battery is being trickle charged and on standby.
