December 21, 2024, 02:03:42 14:03
Author Topic: Plate welded to bar in solidworks  (Read 5268 times)
element7k
« on: July 03, 2012, 08:49:44 20:49 »
Hi all,
I am wondering how can I model a rectangular plate (e.g 50x50mm, 2mm thick) welded to the curved side of a cylinder? (e.g radius 30mm and 1m long) in solidworks? I will like to create a surface mesh for the model (e.g stl)  so there must be some sort of connection between the plate and the cylinder. It will be great if anyone can advise on how to create this connection in solidworks.
E7k
Buddy
 Warned
-Receive: 19
« Reply #1 on: July 04, 2012, 12:36:03 00:36 »
Extrude up to surface.
cncbasher
-Given: 107
-Receive: 51
« Reply #2 on: July 04, 2012, 08:15:46 08:15 »
attach both parts using mates then add fillets to blend in the joint ( weldments ) .
are you looking at just producing the part for machining or for analysis ?
element7k
« Reply #3 on: July 06, 2012, 08:08:13 20:08 »
@cncbasher - The part will be used for analysis. Your method works great at creating a gradual mesh at the connecting parts. Is it going to be different if its used for machining?
E7k
cncbasher
-Given: 107
-Receive: 51
« Reply #4 on: July 06, 2012, 09:28:22 21:28 »
no the procedure is exactly the same.
what is your goal to manufacture both parts , then weld them together as a process ?
send me sw file and i'll take a look .
what software are you using to take to the cam process for cnc machining etc
Posted on: July 06, 2012, 10:25:06 22:25 - Automerged
using weldments for weld joint should produce the correct welding setup for gaps etc , you just would not fit the fillets and the two parts would be manufactured in their own respective rights , the fillets give you a good representation of the finished part , especialy if you run it through photo renderer for a client etc
element7k
« Reply #5 on: July 07, 2012, 10:02:46 22:02 »
Hi cncbasher,
I've posted a sample part file (at filepost), including iges which was given to me for analysis. I posted the original file and hopefully advise can be given on how to process this model so the sheets can all be made into solid and the final product should be the plates welded onto to the cylinder. All the plates parts should be about 3mm - I know I can extrude the plates to form a solid but the cylinder should also be solid and I am not sure how to get a solid out of the surfaces - The parts given to me for analysis were all in sheets Sad  I have a lot more of such geometries so will appreciate any advice on how to process them for analysis purposes.
http://filepost.com/files/646caa5d/swparts_platesandcylindersurface.zip/
E7K
