November 21, 2024, 09:38:22 09:38
XC32 Compilers Discussion Topic
Pages: 1 2 [3] 4  All
Author Topic: XC32 Compilers Discussion  (Read 72725 times)
Catcatcat
-Given: 284
-Receive: 1644
« Reply #50 on: June 24, 2021, 06:16:17 06:16 »
Thank you, it turned out to be activated! The problem was that I launched the cmd in normal mode, and not as an administrator. Cheesy
IVN1479
« Reply #51 on: June 24, 2021, 10:19:15 22:19 »
Hi.
Is the medicine compressed or has only the file extension been changed?
It doesn't work for me.
Posted on: June 17, 2021, 04:10:44 16:10 - Automerged
It has been compressed, sorry for the misunderstanding. It has worked correctly.
Regarding the new version (3.xx), there are changes in the concept of the C language.
My projects without harmony v2 or v3 compile perfectly with version XC32 v3.00, but those who use that tool, the compiler gives errors. Any suggestions what can be done?
I have fixed the problem with Harmony 3 and XC32 version 3.xx.
The solution is the next:
1. Harmony 3 packages must be updated.
2. Open the MHC and regenerate the project code.
The new generated code has the property of detecting if the compiler version is 2 or 3 is being used, depending on that it modifies the code so that there are no compilation errors.
There is no solution for Harmony 2 version, you must use the latest version of xc32 (2.50)
Manuel
-Given: 678
-Receive: 192
« Reply #52 on: December 13, 2021, 02:06:26 14:06 »
XC32 v4.0 Arrived...
Manuel.
« Last Edit: December 13, 2021, 02:21:11 14:21 by Manuel » Logged
Catcatcat
-Given: 284
-Receive: 1644
« Reply #53 on: December 13, 2021, 07:24:41 19:24 »
Installed, performed wellness procedures, it works! Cheesy
danymogh
-Receive: 24
« Reply #54 on: December 15, 2021, 05:51:26 17:51 »
Where did you get the installer file? it's not available online on the website.
giappolo
-Given: 1620
-Receive: 601
« Reply #55 on: December 16, 2021, 03:38:53 03:38 »
Link is on first post, i.e.
http://www.microchip.com/mplabxc32windows
Catcatcat
-Given: 284
-Receive: 1644
« Reply #56 on: December 17, 2021, 04:32:16 04:32 »
But today the license stopped working for both 4.00 and 3.01 Sad
Manuel
-Given: 678
-Receive: 192
« Reply #57 on: December 17, 2021, 08:49:36 08:49 »
Used TOP medicine.
A small example for AT compiled properly including Analysis too.
Take Care,
Manuel.
sparkybg
« Reply #58 on: December 18, 2021, 11:40:07 11:40 »
Fresh install. It does not find any licenses. xclm -status only says: "Microchip XC License Manager Version: 2.30".
This is both for 3.01 and 2.50.
I am using the medicine from this post:
http://www.sonsivri.to/forum/index.php?topic=45710.msg200806#msg200806
Any advice what to do?
-Given: 833
-Receive: 4319
« Reply #59 on: December 18, 2021, 03:11:48 15:11 »
Try Google.com
sparkybg
« Reply #60 on: December 18, 2021, 05:24:29 17:24 »
Try Google.com
Trying it multiple times every day since it exists. Still no luck.  Grin
Catcatcat
-Given: 284
-Receive: 1644
« Reply #61 on: December 19, 2021, 11:52:43 11:52 »
The medicine does not help and no dancing with a tambourine helps.
I noticed that everything was fine until the last Windows update, after that the licensing stopped working. Sad
sparkybg
« Reply #62 on: December 20, 2021, 01:25:11 13:25 »
Used TOP medicine.
Manuel, please tell us where to download this "TOP medicine" from, because it is a bit confusing (for me at least) which one should we use.
@Catcatcat: If it will help, I can make a Windows 7 or Linux vitual machine and work from there if someone can confirm that there is a medicine wotking in this OS.
I only need MIPS16 option to be active, because the project is using the legacy libraries for PIC32 USB and refuses to compile without it.
« Last Edit: December 20, 2021, 01:27:50 13:27 by sparkybg » Logged
piccolo
-Given: 823
-Receive: 957
« Reply #63 on: December 20, 2021, 04:58:48 16:58 »
http://www.sonsivri.to/forum/index.php?topic=44014.msg129986#msg129986
Catcatcat
-Given: 284
-Receive: 1644
« Reply #64 on: December 21, 2021, 05:13:51 05:13 »
Initially, as soon as I installed version 4.0, all the treatment went off with a bang!
Here is the logo of the process:
C:\WINDOWS\system32>cd C:\Program Files\Microchip\xc32\v4.00
C:\Program Files\Microchip\xc32\v4.00>SHA-Patcher -i ./bin/xclm.old -o ./bin/xclm.exe -b
Searching for SHA:DB297365F560A50DB756F79A616F4F8DCB5656D9BBB70A8451F043ACBF4B0961 of file C:\Program Files\Microchip\xc32\v4.00\bin\xclm.old in directory:C:\Program Files\Microchip\xc32\v4.00
I/O Exception: The process cannot access the file 'C:\Program Files\Microchip\xc32\v4.00\SHA-Patcher.exe' because it is being used by another process.
Found match in C:\Program Files\Microchip\xc32\v4.00\bin\bin\pic32c-pa.exe
Found match in C:\Program Files\Microchip\xc32\v4.00\lib\gcc\pic32c\8.3.1\cc1.exe
Found match in C:\Program Files\Microchip\xc32\v4.00\lib\gcc\pic32c\8.3.1\cc1plus.exe
Found match in C:\Program Files\Microchip\xc32\v4.00\lib\gcc\pic32c\8.3.1\lto1.exe
Found match in C:\Program Files\Microchip\xc32\v4.00\bin\bin\gcc\pic32mx\8.3.1\cc1.exe
Found match in C:\Program Files\Microchip\xc32\v4.00\bin\bin\gcc\pic32mx\8.3.1\cc1plus.exe
Found match in C:\Program Files\Microchip\xc32\v4.00\bin\bin\gcc\pic32mx\8.3.1\lto1.exe
Found 7 matches
Patched 7 of 7 files
C:\Program Files\Microchip\xc32\v4.00>cd C:\Program Files\Microchip\xc32\v4.00\bin
C:\Program Files\Microchip\xc32\v4.00\bin>xclm -status
License Path: C:\ProgramData\Microchip\xclm/license/\
        Product: xc32 Type: Workstation Version: 1.0 Mode: cpp License Expires: 14-dec-2021
        Product: xc32 Type: Workstation Version: 1.0 Mode: PRO License Expires: 14-dec-2021
I downloaded the project, checked it at different optimization levels, everything is ok.
But literally a couple of days later, an error appeared and what is interesting for both version 4.0 and 3.01.
After that, I tried to reinstall the compilers, when checking the license, the result is zero.
Manuel
-Given: 678
-Receive: 192
« Reply #65 on: December 23, 2021, 01:57:47 13:57 »
Just for information,
v.4.00 is not present anymore on the site...(have no idea why)
take care,
X!
Catcatcat
-Given: 284
-Receive: 1644
« Reply #66 on: December 23, 2021, 06:09:45 18:09 »
The microchip always has universal links to download the copiers. This link will always download the latest version.
https://www.microchip.com/mplabxc32windows
Manuel
-Given: 678
-Receive: 192
« Reply #67 on: December 23, 2021, 07:41:54 19:41 »
Yes CatCatCat,
but if you follow the link from the site you will never be able to get it now.
That's the strange....I just wanted to underline the fact.
take care,
X!
patchjack
-Given: 11
-Receive: 49
« Reply #68 on: March 09, 2022, 04:50:26 04:50 »
Here use this medicine, it should work for all future V3.xx as well
The link in the attachment is not available. Please send another one. Thank you!
Posted on: March 09, 2022, 04:41:56 04:41 - Automerged
Hello, moderator, please update the link address of the latest cracked file link.txt file.
Manuel
-Given: 678
-Receive: 192
« Reply #69 on: November 14, 2022, 10:34:08 10:34 »
v.4.20 is on the site...
take care,
X!
Manuel
-Given: 678
-Receive: 192
« Reply #70 on: December 27, 2022, 09:21:01 09:21 »
v.4.21 is on the site...
Checked with SAMPLE's included in the distribution and it seems working using TOP's (27K) swiss-knife tool ... can be confirmed with further compiling sessions ?
take care,
X!
« Last Edit: December 27, 2022, 11:04:08 11:04 by Manuel » Logged
patchjack
-Given: 11
-Receive: 49
« Reply #71 on: January 12, 2023, 11:44:23 11:44 »
take care,
X!
I'll provide the proof. Please refer to the attachment.
IVN1479
« Reply #72 on: March 12, 2023, 04:47:54 16:47 »
Hi.
The medicine works correctly with the latest version 4.21, but only with MX and MZ devices.
For ATSAM32, it isn't possible, since it is literally another compiler dedicated to them.
Any comment or suggestion is welcome.
Manuel
-Given: 678
-Receive: 192
« Reply #73 on: September 25, 2023, 09:43:38 09:43 »
v.4.35 is on the site...
Xo!
Manuel
-Given: 678
-Receive: 192
« Reply #74 on: May 03, 2024, 03:04:52 15:04 »
Again, just for information,
v.4.40 is on the site...
Xo!
