You think I am funny guy huh?
November 21, 2024, 09:55:26 09:55
XC32 Compilers Discussion Topic
Pages: 1 [2] 3 4  All
Author Topic: XC32 Compilers Discussion  (Read 72728 times)
pic64
« Reply #25 on: June 18, 2015, 08:51:43 20:51 »
New XC32 1.40
http://www.microchip.com/mplabxc32windows
Manuel
-Given: 678
-Receive: 192
« Reply #26 on: June 19, 2015, 08:19:40 08:19 »
Even updated 1.40 XC32 part support
https://www.microchip.com/mplabxc32-ps-windows
Manuel
Armageddon
-Given: 58
-Receive: 56
« Reply #27 on: December 04, 2015, 08:37:39 20:37 »
Fix for XC32 v1.40.
Steps:
 1. Open "C:\Program Files\Microchip\xc32\v1.40\bin\bin\gcc\pic32mx\4.8.3\cc1.exe" file with your favorite hex editor.
 2. Find and replace these bytes "0F 85 CC 00 00 00 8D 44" with "90 E9 00 00 00 00 8D 44".
 3. Do same with "C:\Program Files\Microchip\xc32\v1.40\bin\bin\gcc\pic32mx\4.8.3\cc1plus.exe" and "C:\Program Files\Microchip\xc32\v1.40\bin\bin\gcc\pic32mx\4.8.3\lto1.exe" files.
 4. Use latest "xclm" file from here, i.e:
xclm
int main(){
    return 2;
Tested under Windows 10 and MPLAB X IDE v3.15.
More info: http://www.jubatian.com/articles/turning-on-optimizations-in-microchips-xc32/
Note: I used the same technique that petarp, but now:
90 = nop
E9 = jmp
00 00 00 00 = $ + 5
Cheers.
Problems that appear small are large problems that are not fully understood.
Catcatcat
-Given: 284
-Receive: 1644
« Reply #28 on: July 14, 2017, 10:51:16 10:51 »
Update MPLAB® XC32 v1.44
Fixed in v1.44
XC32-720
In the MPLAB XC32 v1.43 release, the linker incorrectly treated all symbols in the input object files as weak. This meant that non-weak symbols could not override weak symbols. The correct behavior of weak and non-weak symbols has been restored.
XC32-709
When compiling and linking with Smart IO and the Legacy Libc, printf() and related functions may print incorrect output. Under some conditions, the format specifier could get printed. This issue has been fixed.
XC32-708
In XC32 v1.43 and earlier, When compiling and linking with the Non-Legacy Libc, printf() and related functions did not handle the %ll conversion specifier correctly when the value has non-zero bits in the upper 32-bit positions.
XC32-707
XC32 v1.43 emitted a linker error when applying the coherent attribute to a zero-sized section. (Ex: uint8_t __attribute__((coherent)) ary[0]; ) The linker now emits an error when it can't allocate only non-zero sized sections.
The medicine works !!
Git
-Given: 94
-Receive: 19
« Reply #29 on: February 08, 2018, 10:24:09 22:24 »
Any medicine for XC32 2.05 please?
Catcatcat
-Given: 284
-Receive: 1644
« Reply #30 on: February 09, 2018, 08:07:33 08:07 »
Compared the work of version 1.44 and 2.05
- 3 - Optimize yet more favoring speed
medicine "standard"  Cheesy
as for my project, it makes no difference, everything works!
Git
-Given: 94
-Receive: 19
« Reply #31 on: February 09, 2018, 01:10:43 13:10 »
I looked with a magnifier, but still no difference to see Smiley
Plenty of    0F 85 CC 00 00 00 xx xx
but no       0F 85 CC 00 00 00 8D 44
« Last Edit: February 09, 2018, 02:16:53 14:16 by Git » Logged
tumbleweed
-Given: 58
-Receive: 41
« Reply #32 on: February 10, 2018, 11:57:41 11:57 »
I don't know about the patch shown here, but the medicine in the 'XC - software only' thread appears to work for XC32 2.05
http://www.sonsivri.to/forum/index.php?topic=44014.0
adamantium
-Given: 17
« Reply #33 on: February 19, 2018, 03:25:28 03:25 »
I can also confirm the old xclm.exe works, just rename the one in the /bin directory to xclm.old, copy in the xclm.exe patcher and run as administrator.
MetaMetal
-Given: 66
-Receive: 242
« Reply #34 on: December 15, 2018, 02:50:29 14:50 »
xc32 v2.15 is out.
medicine works fine.
Catcatcat
-Given: 284
-Receive: 1644
« Reply #35 on: June 08, 2019, 06:24:33 18:24 »
MPLAB® XC32/32++ Compiler v2.20 (link to the latest compiler version)
everything is working!
Catcatcat
-Given: 284
-Receive: 1644
« Reply #36 on: August 30, 2019, 06:56:57 06:56 »
MPLAB® XC32/32++ Compiler v2.40 (link to the latest compiler version)
« Last Edit: February 22, 2020, 07:49:50 19:49 by Catcatcat » Logged
Manuel
-Given: 678
-Receive: 192
« Reply #37 on: May 30, 2020, 02:04:10 14:04 »
updated to MPLAB® XC32/32++ Compiler v2.41
Thank you , still perfect.
X!
Catcatcat
-Given: 284
-Receive: 1644
« Reply #38 on: September 24, 2020, 08:39:35 08:39 »
MPLAB® XC32/32++ Compiler v2.50 (link to the latest compiler version)
On my projects, the new version of the compiler has shown an improvement in optimization for data in RAM (packs 1.2.51).
marcodassi
 Warned
-Given: 73
-Receive: 26
« Reply #39 on: May 13, 2021, 01:30:09 13:30 »
MPLAB XC32 32++ Compiler 3.00
Just tested with the "classic" medicine... no luck this time - the patch crashes cc1.exe
BTW, there are some undocumented changes... specifically, in the gcc options, some of them have changed name
Catcatcat
-Given: 284
-Receive: 1644
« Reply #40 on: May 13, 2021, 06:57:25 18:57 »
And V3.0 did not work for me  Sad
Top
-Given: 52
-Receive: 1719
« Reply #41 on: May 13, 2021, 11:38:48 23:38 »
I just tested my fix with a simple XC32 v3 project and it seems to work fine.
Tell me how to reproduce this issue.
danymogh
-Receive: 24
« Reply #42 on: May 14, 2021, 06:25:33 06:25 »
Here use this medicine, it should work for all future V3.xx as well
« Last Edit: September 06, 2021, 07:43:19 07:43 by danymogh » Logged
Catcatcat
-Given: 284
-Receive: 1644
« Reply #43 on: May 14, 2021, 09:29:17 09:29 »
also, pray for me to become rich.
Thank you very much! The vaccine works! Smiley
To work, I additionally had to update .NET 5.0 Desktop Runtime (v5.0.6) https://dotnet.microsoft.com/download/dotnet/thank-you/runtime-desktop-5.0.6-windows-x64-installer
danymogh
-Receive: 24
« Reply #44 on: May 14, 2021, 10:01:36 10:01 »
yes, sorry I forgot to mention you need .net 5 or above runtime to run the SHA-Patcher
marcodassi
 Warned
-Given: 73
-Receive: 26
« Reply #45 on: May 14, 2021, 11:29:17 11:29 »
Thank you very much, danymogh!
Does this medicine works for XC8 and XC16 too, or is for XC32 only?
Done, are you rich now? Smiley
Best regards
IVN1479
« Reply #46 on: June 17, 2021, 04:59:13 16:59 »
Hi.
Is the medicine compressed or has only the file extension been changed?
It doesn't work for me.
Posted on: June 17, 2021, 04:10:44 16:10 - Automerged
Hi.
It has been compressed, sorry for the misunderstanding. It has worked correctly.
Regarding the new version (3.xx), there are changes in the concept of the C language.
My projects without harmony v2 or v3 compile perfectly with version XC32 v3.00, but those who use that tool, the compiler gives errors. Any suggestions what can be done?
Catcatcat
-Given: 284
-Receive: 1644
« Reply #47 on: June 23, 2021, 06:43:56 18:43 »
I was unable to activate version 3.01. Who managed to accomplish this? Please share. Sad
Top
-Given: 52
-Receive: 1719
« Reply #48 on: June 23, 2021, 08:08:22 20:08 »
My fix seems to work okay on v3.01 too.
danymogh
-Receive: 24
« Reply #49 on: June 24, 2021, 05:07:51 05:07 »
my fix , like i said , should work for all 3.xx version and i checked for 3.01 and it still works.
do a clean install and it should fix any problem
