November 21, 2024, 09:50:56 09:50
XC16 Compilers Discussion Topic
« Last Edit: June 29, 2012, 12:21:39 00:21 by metal »
Pages: [1] 2  All
Author Topic: XC16 Compilers Discussion  (Read 42599 times)
« on: June 29, 2012, 12:19:17 00:19 »
« Last Edit: June 29, 2012, 12:21:39 00:21 by metal » Logged
8bitMCU
-Receive: 19
« Reply #1 on: August 10, 2012, 11:38:27 23:38 »
MPLAB xc16 v1.10 has been release
http://www.microchip.com/mplabxc16windows
respected
« Reply #2 on: November 28, 2012, 01:02:03 13:02 »
I tried it. But I don't compile
« Reply #3 on: November 28, 2012, 01:17:46 13:17 »
really, how is that, explain!?
respected
« Reply #4 on: November 28, 2012, 01:55:45 13:55 »
compiler messages;
elf-cpp.exe: PIC24F08KA102.gld: No such file or directory
elf-cpp.exe: warning: '-x c' after last input file has no effect
« Reply #5 on: November 28, 2012, 03:23:45 15:23 »
Sounds like a question for the microchip forums Smiley
You've got something misconfigured if that is in fact a supported processor in this version of the compiler.  The gld file, unless you explicitly included it should be automatically loaded from the various include paths.
respected
« Reply #6 on: November 28, 2012, 08:39:27 20:39 »
I changed PIC****.gld file P*****.gld.   I compiled .  Thanks.
marcodassi
 Warned
-Given: 73
-Receive: 26
« Reply #7 on: December 14, 2012, 11:13:46 23:13 »
XC16 1.11 is out!
testing medicine...   medicine still seems to work  Cheesy
« Last Edit: December 14, 2012, 11:23:43 23:23 by marcodassi » Logged
-Given: 496
« Reply #8 on: April 18, 2013, 10:32:07 10:32 »
Question.
Anyone have a library for HD44780 for the XC16 and XC32?
After playing with XC16 for a week I seem to start thinking that it is quite rotten.
Catcatcat
-Given: 284
-Receive: 1644
« Reply #9 on: April 18, 2013, 01:32:46 13:32 »
Here is my production Library for LCD indicators on the driver HD44780 or KS0066U
Catcatcat
-Given: 284
-Receive: 1644
« Reply #10 on: November 01, 2013, 03:24:38 15:24 »
new version MPLAB® XC16 Compiler v1.20
marcodassi
 Warned
-Given: 73
-Receive: 26
« Reply #11 on: January 14, 2014, 08:24:41 08:24 »
XC16 1.21 is out! Smiley
(it's still listed as 1.20, but just click on the link and download!)
Catcatcat
-Given: 284
-Receive: 1644
« Reply #12 on: September 15, 2014, 02:01:26 14:01 »
A new version
MPLAB® XC16 Compiler v1.22
Catcatcat
-Given: 284
-Receive: 1644
« Reply #13 on: October 11, 2014, 08:56:15 08:56 »
updated compiler
MPLAB® XC16 Compiler v1.23
Binary1955
« Reply #14 on: January 26, 2015, 04:19:02 16:19 »
updated compiler
MPLAB® XC16 Compiler v1.24
don't forget the part support
XC16 v1.24 part support
Part-support updates can be applied to any compiler version, but some functionality may require a later compiler version.
medicine still seems to work   Grin
mitsos
-Given: 3086
-Receive: 4596
« Reply #15 on: March 04, 2016, 07:31:21 19:31 »
hi
v1.26 released
http://www.microchip.com/mplabxc16windows/
mitsos
Catcatcat
-Given: 284
-Receive: 1644
« Reply #16 on: December 03, 2016, 10:36:46 10:36 »
updated compiler
MPLAB® XC16 Compiler v1.30
testing, optimization level
0
1
2
s
3
medicine works!
Catcatcat
-Given: 284
-Receive: 1644
« Reply #17 on: November 01, 2017, 10:29:38 22:29 »
A new version
MPLAB® XC16 Compiler v1.36
« Last Edit: December 22, 2018, 06:22:07 06:22 by Catcatcat » Logged
Catcatcat
-Given: 284
-Receive: 1644
« Reply #18 on: December 22, 2018, 06:47:46 06:47 »
Comparing the latest versions in code size optimization mode:
Catcatcat
-Given: 284
-Receive: 1644
« Reply #19 on: August 17, 2019, 06:11:49 18:11 »
MPLAB XC16 Compiler v1.40
checked, it works Wink
But, the truth, the header files of some microcontrollers have different register names, for example, for PIC24FJ128GA204 in 1.36 there is a register REFOTRIMHL in version 1.40 it is called a register REFOTRIMH. This is what I have noticed so far.
uCApps
-Given: 40
« Reply #20 on: September 21, 2019, 02:34:07 14:34 »
MPLAB XC16 Compiler v1.41(Bug-fix release?)
Medicine works like a charm;)
Manuel
-Given: 678
-Receive: 192
« Reply #21 on: February 05, 2020, 02:14:44 14:14 »
MPLAB XC16 Compiler v1.50 (porting to x64 version)
After Checking TOP's x86 solution I confirm it's working . Actually no need of x64 solution.
(PS: I did a mistake, I did not consider that different compiler versions can have also different DEFINE)
SORRY MY FAULT !!!!
X!
Release:  v1.50
    This release is a 64bit only release. All executables shipped with release are 64bit executables. This affects MacOS, Linux and Windows installers.
    Updated MacOS release is Catalina compatible. Catalina has dropped 32bit executable support. This release of MPLAB XC16 is now a 64bit package.
    New linker options that add section attributes to all code, data or PSV (.const) type sections. Additional information is available in the provided User's Guide (DS50002106E).
    Added new functionality in compiler that helps user program inactive slave section of PRAM on dual core devices that have this feature. Users can use the function _program_inactive_slave(slave_number, verify, image); to program the inactive slave panel with the image. The function performs similar to _program_slave() but works only on the inactive panel.
    Added a ported version of objcopy to the release. XC16 version is called xc16-objcopy. This version of objcopy only recognizes XC16 object code. Any other type of object code is not recognized by this objcopy.
« Last Edit: February 07, 2020, 11:40:19 11:40 by Manuel » Logged
Top
-Given: 52
-Receive: 1719
« Reply #22 on: February 05, 2020, 04:50:47 16:50 »
Medicine does not work anymore I would say.
I will recompile the fix for 64-bit but Windows should still be OK. Can you test it?
mars01
-Given: 696
-Receive: 1774
« Reply #23 on: February 05, 2020, 05:22:10 17:22 »
Hi Top,
It looks like it works. I applied the patch and it reported patch completed.  I made a bogus project, compiled it with Os optimizations and it has done it without complaints.
Catcatcat
-Given: 284
-Receive: 1644
« Reply #24 on: February 07, 2020, 07:49:35 07:49 »
This universal link will always show the latest version.
Pages: [1] 2  All
