koky
-Given: 160
-Receive: 157
« Reply #200 on: July 28, 2019, 08:37:08 20:37 » |
for me not work ::: error: (2052) The current license does not permit the selected optimization level and other levels are not permitted by the NOFALLBACK option (908) exit status = 1
tumbleweed
-Given: 58
-Receive: 41
« Reply #201 on: July 29, 2019, 11:18:44 11:18 » |
I haven't tried to install it yet, but there may be something different about the new XC '09' versions. For XC16- Release Notes for MPLAB XC16 C Compiler v1.39 Mar 22 2019
This release of the Microchip MPLAB XC16 C compiler is a functional safety compiler based on MPLAB XC16 v1.36B. This compiler requires a functional safety license in order to operate. Once activated, all optimisation levels and compiler features are available. Maybe they use a different licensing scheme...
Top
-Given: 52
-Receive: 1719
« Reply #202 on: July 29, 2019, 04:25:10 16:25 » |
Not a different scheme but there are some changes.
« Last Edit: July 30, 2019, 01:41:12 13:41 by Top »
tumbleweed
-Given: 58
-Receive: 41
« Reply #203 on: July 30, 2019, 10:45:23 10:45 » |
FYI - from one of the XC developers... Just to confirm what it looks like you already know, the XC8 2.09 is a functional safety compiler. It requires a special license, so at this stage you will not be able to run it. It has not actually been officially released yet; however, it made its way onto the list of compilers offered as update by MPLAB X IDE. That issue is being looked into. There will be special functional safety compilers for XC8/16/32 released later in the year.
uCApps
-Given: 40
« Reply #204 on: August 17, 2019, 12:48:40 12:48 » |
Hello, xc8 ver. 2.10 was released and currently medicine does not works anymore. I checked in xclm binary and it is updated in this version.
Top
-Given: 52
-Receive: 1719
« Reply #205 on: August 17, 2019, 01:52:17 13:52 » |
Open a command prompt as admin and run the following commands: "C:\Program Files (x86)\Microchip\xc8\v2.10\bin\xclm.exe" "C:\Program Files (x86)\Microchip\xc8\v2.10\pic\bin\xclm.exe" Report back with results.
uCApps
-Given: 40
« Reply #206 on: August 17, 2019, 03:06:32 15:06 » |
Open a command prompt as admin and run the following commands: "C:\Program Files (x86)\Microchip\xc8\v2.10\bin\xclm.exe" "C:\Program Files (x86)\Microchip\xc8\v2.10\pic\bin\xclm.exe" Report back with results. Dear Top, thanks for kindness, here it is. Successfully it patched binary,but it doesn't work in MPLAB X. --- C:\Program Files (x86)\Microchip\xc8\v2.10\pic\bin>xclm.exe Patched 40 bytes in file ./aspic.exe Patched 40 bytes in file ./aspic18.exe Patched 40 bytes in file ./cgpic.exe Patched 40 bytes in file ./cgpic18.exe Patched 40 bytes in file ./picc.exe Patched 40 bytes in file ./picc18.exe Patched SHA in 6 of 6 files C:\Program Files (x86)\Microchip\xc8\v2.10\pic\bin> C:\Program Files (x86)\Microchip\xc8\v2.10\bin>xclm.exe Nothing to do C:\Program Files (x86)\Microchip\xc8\v2.10\bin> ---
Top
-Given: 52
-Receive: 1719
« Reply #207 on: August 17, 2019, 03:12:30 15:12 » |
When you say "doesn't work" be more specific, give an example, what exactly is not working?
uCApps
-Given: 40
« Reply #208 on: August 17, 2019, 04:49:57 16:49 » |
Dear Top, Sorry for that, I meant optimizations in XC8 ver. 2.10 didn't works in Os, O3 on MPLAB X once, but it WORKS well now after I deleted cache files. Many apologizes for my recognization...lots of thanks for nice madecine! uCApps
Catcatcat
-Given: 288
-Receive: 1735
« Reply #209 on: August 17, 2019, 06:31:54 18:31 » |
How I cure version 2.XX. First, as usual, I do with the files in the folder C:\Program Files (x86)\Microchip\xc8\v2.10\bin I get two files xclm.exe (26 KB) and xclm.old (1719KB). Then copy them to the folder C:\Program Files (x86)\Microchip\xc8\v2.10\pic\bin and C:\Program Files (x86)\Microchip\xc8\v2.10\avr\bin And then in each of these folders I perform the treatment, it seems so far, everything works.
Mr. Spock
-Given: 475
-Receive: 827
« Reply #210 on: August 21, 2019, 07:38:21 07:38 » |
"And then in each of these folders I perform the treatment"
Hi Do you mean running again xclm.exe ? Best regards
Catcatcat
-Given: 288
-Receive: 1735
« Reply #211 on: August 21, 2019, 11:19:48 11:19 » |
Yes.
-Given: 841
-Receive: 4365
« Reply #212 on: November 10, 2019, 04:07:54 16:07 » |
I had a tough time patching xc8 I had to move the files xclm.exe and xclm.old up a level to c:\Program Files\microchip\xc8\v2.10
then it worked.
engiadina
« Reply #213 on: January 31, 2020, 09:02:53 21:02 » |
I'm trying to apply the medicine to a Mac with Catalina. Here it does not work, the OS complains about the 32-Bit nature of the medicine. Should be 64-Bit to be able to run. Is there any help available?
Many thanks
engiadina
pki
« Reply #214 on: February 21, 2020, 06:30:27 18:30 » |
Where can i find the medicine for linux version?
have a nice weekend
MarkWalter
Warned
« Reply #215 on: April 18, 2020, 11:12:43 11:12 » |
Hi to everyone, i'm using this xclm method since forever and really thanks for it. I'm really curious about this, anyone can share the source code of the xclm? or maybe just explain the procedure. I've always been fascinated with those ''softwares'', thanks
tumbleweed
-Given: 58
-Receive: 41
« Reply #216 on: April 30, 2020, 05:03:30 17:03 » |
xc8 v2.20 was just released.
Part of that package contains a new assembler pic-as.exe (xc8\v2.20\pic-as\bin). Does anyone know if that program needs to be patched too?
Catcatcat
-Given: 288
-Receive: 1735
« Reply #217 on: April 30, 2020, 06:54:20 18:54 » |
The medicine works, treated according to the method of copying files to bin folders. (V2.20)
koky
-Given: 160
-Receive: 157
« Reply #218 on: April 30, 2020, 06:55:23 18:55 » |
the new version is 64 bit and the usually medicine work fine
-Given: 841
-Receive: 4365
« Reply #219 on: April 30, 2020, 07:06:34 19:06 » |
why this post after only two post in forum. Both your post after being a member here for over 5 years are like this Quote by you 'Someone can please release the source code of the medicine ?
« Last Edit: April 30, 2020, 07:11:45 19:11 by pickit2 »
tumbleweed
-Given: 58
-Receive: 41
« Reply #220 on: April 30, 2020, 08:07:36 20:07 » |
The medicine works, treated according to the method of copying files to bin folders. (V2.20) Yes, I know. The medicine patches all the 'old' XC8 files in v2.20 fine. v2.20 includes a new standalone assembler pic-as.exe which is intended to replace MPASM. My question is if the new file pic-as.exe needs to be patched as well. pic-as.exe may just be a front-end for calling the existing aspic.exe/aspic18.exe (which ARE patched by the medicine), bit I don't know for sure. Hence the question.
Catcatcat
-Given: 288
-Receive: 1735
« Reply #221 on: April 30, 2020, 09:16:13 21:16 » |
About 10 years ago I threw the assembler back and I can’t say anything about it, but as far as I remember, assembler has always been free.
tumbleweed
-Given: 58
-Receive: 41
« Reply #222 on: May 01, 2020, 12:25:12 00:25 » |
I don't think everyone is getting what I'm saying. Yes, the old MPASM was free. The NEW assembler pic-as.exe is part of XC8 v2.20. Currently the medicine patches the aspic.exe assembler used in XC8 v2.10: Patched 40 bytes in file ./aspic.exe Patched 40 bytes in file ./aspic18.exe
Now, pic-as.exe is meant as a standalone assembler (I think XC8 still calls on aspic to do its work). The question, yet again, is a similar patch as was done for aspic.exe needed for pic-as.exe?
graywolf
-Receive: 19
« Reply #223 on: May 01, 2020, 03:02:52 15:02 » |
Many thanks
engiadina
I have been creating my own patcher for Catalina, it has been tested against XC32 v2.40, XC8 v2.20 and works. I will package and do a release in the next few days. 'pickit2' where or how do I get this live?
Ahmad_k
SCG Moderator
-Given: 176
-Receive: 1298
« Reply #224 on: May 30, 2020, 08:25:51 20:25 » |
I have downloaded the last MLA (Microchip Library v2017) that support PIC18 USB Device also the latest XC8.
All USB samples from MLA compile out of the box without any problem, but non of them are working in Proteus USB simulation. First i thought it was a Proteus problem, i opened usb hid mouse sample provided by proteus and it works, but none of the demo within MLA works. USB analyzer stuck on get device descriptor.
i also tried MikroC simple HID device and it works also in proteus.
The reason i need XC8 and MLA USB stack because it is almost full USB stack and not a light weight stack as provided by MikroC and Proton.
I don't have a real hardware near me to try on real hardware right now.
Please if someone can confirm that USB stacks (XC8 + MLA) (Custom HID sample or mouse sample) is working fine on real hardware or in simulation, if yes then provide the exact version.
Device used : 18F14k50 or 18F45k50
« Last Edit: May 30, 2020, 08:31:53 20:31 by Ahmad_k »
