mars01
-Given: 700
-Receive: 1775
« Reply #175 on: June 23, 2018, 02:34:28 14:34 » |
Patch may be working but with the new GCC "look', MPLABX can't see the xc.h therefore I reverted to XC8 1.45 which works fine.
Catcatcat
-Given: 288
-Receive: 1735
« Reply #176 on: June 23, 2018, 06:57:41 18:57 » |
mars01
-Given: 700
-Receive: 1775
« Reply #177 on: June 23, 2018, 07:10:39 19:10 » |
I guess we should stay away from v2.0 until they get the hang of it. The developers may have attempted too much for this release.
« Reply #178 on: June 23, 2018, 10:49:47 22:49 » |
what is the "new GCC "look'"? Did they abandon HI-TECH compilers?
mars01
-Given: 700
-Receive: 1775
« Reply #179 on: June 23, 2018, 11:52:50 23:52 » |
I think they use a "wrapper". They still use the old compiler but it's deeper in the structure. They use Clang now and they support C99 and C90 as opposed to only C90(C89) up until v1.45. It's because of the AVR compilers ...
Manuel
-Given: 703
-Receive: 194
« Reply #180 on: June 27, 2018, 01:05:29 13:05 » |
I confirm you your written.
So I think investigations should follow on 'xc8-cc.exe'..
take care,
Xo!
« Reply #181 on: June 27, 2018, 03:16:37 15:16 » |
I hope they don't kill microsoft IDE, it is better than Java crap..
mars01
-Given: 700
-Receive: 1775
« Reply #182 on: June 27, 2018, 04:34:39 16:34 » |
I agree, actually I hope they start supporting PIC devices in Atmel Studio since they made the choice to use a GCC-like wrapper.
alichan
-Given: 28
-Receive: 88
« Reply #183 on: August 11, 2018, 09:41:49 21:41 » |
Amen... Adding C99 support is a major change and surely a major bug source.
intel
-Given: 53
-Receive: 2142
« Reply #184 on: November 17, 2018, 12:52:56 12:52 » |
Hello there; I could not get a pro mode of xc8 v2.0 version. I've done everything imaginable. After formatting the computer, I installed the xc8 v2.0 version directly. I don't know if anything was v1.45 installed before. I don't know if I'm connected to the internet. One of the masters should be interested.
koky
-Given: 160
-Receive: 157
« Reply #185 on: November 17, 2018, 04:00:03 16:00 » |
You must see the: « Reply #172 on: June 13, 2018, 01:19:34 13:19 » attention at the right BIN subdirectory
intel
-Given: 53
-Receive: 2142
« Reply #186 on: November 17, 2018, 04:05:30 16:05 » |
Thanks koky; I already made them. I think there is a changing license validation procedure.
Top
-Given: 52
-Receive: 1719
« Reply #187 on: November 17, 2018, 04:09:29 16:09 » |
Open a command prompt as admin and run the following commands: "C:\Program Files (x86)\Microchip\xc8\v2.00\bin\xclm.exe" "C:\Program Files (x86)\Microchip\xc8\v2.00\pic\bin\xclm.exe" Report back with results.
« Last Edit: November 17, 2018, 04:12:48 16:12 by Top »
intel
-Given: 53
-Receive: 2142
« Reply #188 on: November 17, 2018, 04:30:41 16:30 » |
Open a command prompt as admin and run the following commands: "C:\Program Files (x86)\Microchip\xc8\v2.00\bin\xclm.exe" "C:\Program Files (x86)\Microchip\xc8\v2.00\pic\bin\xclm.exe" Report back with results. "C:\Program Files\Microchip\xc8\v2.00\pic\bin\xclm.exe" did not pay attention to the new file location. Now the program as a result worked. Thank you so much Master Top.
Catcatcat
-Given: 288
-Receive: 1735
« Reply #189 on: January 16, 2019, 10:59:16 10:59 » |
The microchip changed the principle of treatment, the "dancing with a tambourine" helped.  If you copy the missing files in the folder C: \ Program Files (x86) \ Microchip \ xc8 \ v2.05 \ pic \ bin, the compiler started working. for comparison v2.05 C standart C 99
« Last Edit: January 16, 2019, 11:37:32 11:37 by Catcatcat »
papy_bidouille
-Given: 133
-Receive: 22
« Reply #190 on: January 17, 2019, 03:43:49 15:43 » |
7264 bytes less for my application I can add additional options Thanks xclm.exe And thank you to those who contributed.
HackAndCrack
-Given: 175
-Receive: 804
« Reply #191 on: January 22, 2019, 12:48:29 12:48 » |
What is the cracking procedure for XC8 v2.05 ?
I installed MPLAB X 5.10 and XC8 v2.05 yesterday and applied the crack as mentioned in latest sticky file and changed compiler options to Free, Standard and PRO and compiled but for all modes I get same .hex. I use PIC16F877A for a Blinky project.
mars01
-Given: 700
-Receive: 1775
« Reply #192 on: January 22, 2019, 01:47:04 13:47 » |
Read the Reply #189, here: http://www.sonsivri.to/forum/index.php?topic=45707.msg191433#msg191433 it explain the extra steps. It's quite simple. 1. Rename xclm file to xclm.old and copy the new xclm.exe file here: C:\Program Files (x86)\Microchip\xc8\v2.05\bin 2. Copy both files (xclm.old and xclm.exe) from the previous location to: C:\Program Files (x86)\Microchip\xc8\v2.05\pic\bin and run the xclm.exe here as admin to patch the files. There are no longer the options: Free, Standard and Pro. There are only different kinds of optimizations in GNU language like: O2, O3, O3 + s, some are available only for the licensed compiler.
« Last Edit: January 22, 2019, 01:50:20 13:50 by mars01 »
Manuel
-Given: 703
-Receive: 194
« Reply #193 on: April 24, 2019, 11:01:49 11:01 » |
Did not investigated digging compiled but 2.05 is anyway bigger than 2.00 in both code and vars generation.
Then in 2.00 or previous the optimizer used to remove unused vars, the 2.05 leave them in.
Quite odd in this.
Those facts noted with Pic15F323 just for your interest...
Does anyone noticed this ?
X!
« Last Edit: April 24, 2019, 11:43:48 11:43 by Manuel »
Catcatcat
-Given: 288
-Receive: 1735
« Reply #194 on: April 25, 2019, 07:22:47 07:22 » |
Version 1.45 gives the most efficient optimization by code size.
Manuel
-Given: 703
-Receive: 194
« Reply #195 on: April 25, 2019, 07:37:09 07:37 » |
I will take time to investigate further so, since for the PIC12F510 there is no real difference between 2.00 and 2.05.
I will check 1.45 as well just for curiosity.
take care, X!
koky
-Given: 160
-Receive: 157
« Reply #196 on: July 28, 2019, 04:39:14 16:39 » |
I have try with 2.09 and seem don't work
Top
-Given: 52
-Receive: 1719
« Reply #197 on: July 28, 2019, 05:03:33 17:03 » |
Open a command prompt as admin and run the following commands: "C:\Program Files (x86)\Microchip\xc8\v2.09\bin\xclm.exe" "C:\Program Files (x86)\Microchip\xc8\v2.09\pic\bin\xclm.exe" Report back with results.
koky
-Given: 160
-Receive: 157
« Reply #198 on: July 28, 2019, 06:50:34 18:50 » |
C:\Program Files (x86)\Microchip\xc8\v2.09\pic\bin>xclm.exe Patched 40 bytes in file ./aspic.exe Patched 40 bytes in file ./aspic18.exe Patched 40 bytes in file ./cgpic.exe Patched 40 bytes in file ./cgpic18.exe Patched 40 bytes in file ./picc.exe Patched 40 bytes in file ./picc18.exe Patched SHA in 6 of 6 files
Top
-Given: 52
-Receive: 1719
« Reply #199 on: July 28, 2019, 08:34:18 20:34 » |
So, does it work now?
