Beltza
-Given: 228
-Receive: 42
« Reply #100 on: September 08, 2014, 10:13:49 10:13 » |
XC8 and C18 are two different beasts. XC8 is derived from HiTech PICC. Microchip adquired HiTech.
jcddcjjcd
« Reply #101 on: September 09, 2014, 06:38:19 06:38 » |
I think my problems arise from not understanding how XC8 does things. For example in converting my USB HID Bootloader I finally realized I was better using TBLPRT and TABLAT directly instead of using pointers. When a ROM pointer is passed and the address is outside the normal programming range as when reading and writing userid and config words it changes the upper byte of TBLPTR to 20 from 30. Probably it assumes you would not want to do that.
Another sticky thing was that in my struct that holds the packet data relating to a bootloader operation I used uint24_t to allow for the 3bytes address but XC8 changed that to a 32 bit value even thought there was a union of 3bytes associated with it. That would have been alright if XC8 had shifted the rest of the struct up by one byte but it happily went along and my data[] was out by a byte. By going back to unsigned short long everything was OK again except for the warning every time an unsigned short long is used. I have plenty of unsigned short long the for the rest it works.
I have a question though. Should I be using XC8 in CCI mode or not. Just changing it requires a whole bunch of other code edits. Do people mainly use CCI?
Regards, John.
« Last Edit: September 09, 2014, 06:42:54 06:42 by jcddcjjcd »
jcddcjjcd
« Reply #102 on: September 12, 2014, 04:06:07 04:06 » |
Well, all sorted now. Managed to make a HID bootloader out of the latest framework, the last one I could shrink to under 0x1000 was v2.1 and now they are up to v2.11 so that was pleasing. Now that I have converted most of my projects over to XC8 and have more experience with it I do like it a lot more the C18 so it was worth the trouble.
Regards, John.
« Last Edit: September 18, 2014, 05:04:48 05:04 by jcddcjjcd »
jnz
« Reply #103 on: September 26, 2014, 11:14:45 23:14 » |
I'm liking more than C18 for certain.
The trouble I'm having is that exceptionally few RTOS have coded to XC8.
donhamilton
« Reply #104 on: November 10, 2014, 03:03:56 03:03 » |
What is the size of the xclm.old file ? I think I deleted the wrong file.
Slasher
« Reply #105 on: November 14, 2014, 07:30:16 07:30 » |
xclm.exe delivered with XC8 v1.33B is 924.160 bytes.
Manuel
-Given: 786
-Receive: 205
« Reply #106 on: January 07, 2015, 02:28:27 14:28 » |
yoda2020
« Reply #107 on: February 16, 2015, 10:23:16 10:23 » |
my complaint with the compiler is that it 'decides' what to compile in certain cases. for no reason, when i was using a variable in a loop and loading values inside and reusing outside the loop and compiler (with and without optimisations enabled) told me in the log file "variable unused" and did not compiled some lines of code, then i got weird behavior while debugging coff file.. does anybody have experienced that behavior?
This can get particularly annoying with routines using SPI where you need to ensure you clear SSPBUF by reading it then discarding the result. XC8 and Hi-Tech PICC both 'optimize' out code that has no further action. I think the suggestion here is to define the variable to we put SSPBUF into as volatile, I'll give that a try. Thanks for the idea as it's much more elegant than my approach of adding an if(....) type structure after the SSPBUF read to fool the compiler. If anyone has a tried and trusted method for such circumstances I'd really love to hear it. Dave
Linko
« Reply #108 on: February 16, 2015, 04:14:33 16:14 » |
Dave, in my code to manage UART I had a similar need: in case of error it becomes necessary to clear the RCREG by reading it.
I've used in the past the volatile variable approach, but I found later I could simply put a "RCREG;" statement, i.e. without any explicit assignment. XC8 (1.33) compiler generates the correct opcode, a simple assignment to w register.
... 2858 ;rs232.c: 162: RCREG; 2859 001A36 50AE movf 4014,w,c ;volatile ...
Linko
jnz
« Reply #109 on: February 16, 2015, 04:32:38 16:32 » |
Linko
I'm still using volatile if the issue comes up, I just watch for "variable is not used" in the output... But that still doesn't mean this is a good compiler or a good option. Everyday, PIC is pushing me further into ARM's arms.
Manuel
-Given: 786
-Receive: 205
« Reply #110 on: February 27, 2015, 12:32:21 12:32 » |
Released Update to XC8 v1.34. >>New license manager and installers
and to XC8 part support v1.34. Released Update to MPLABX v2.35 and Released BETA MPLABX v3.0.
>> TOP, great WORK U DID! <<
I confirm the claimed: Comparison optimizations Code associated with equality and relational comparisons has been improved in many situations.... (in one of my case test the generated moved from 502 to 497...and the generated work :-) )
Manuel
« Last Edit: February 27, 2015, 06:33:47 18:33 by Manuel »
Cybernando
« Reply #111 on: March 03, 2015, 04:08:54 16:08 » |
xc8 v1.34 error USB hid framework !!! microchip/mla/v2014_07_22/framework/usb/src/usb_device.c:25039: error: (800) undefined symbol "l11805" (908) exit status = 1 with v1.33 all ok
Manuel
-Given: 786
-Receive: 205
« Reply #112 on: June 13, 2015, 02:29:52 14:29 » |
UPDATED: XC8 Compiler Part-Support Patch v1.34B
manuel.
« Last Edit: June 13, 2015, 02:32:44 14:32 by Manuel »
Manuel
-Given: 786
-Receive: 205
« Reply #113 on: July 11, 2015, 09:31:07 09:31 » |
Seen XC8 3 compiler "issues"... and related workaround...
1) BIT vars are located on a different BANK for some processors even if there is still space in the main bank. This involve into BANK SWITCHING compiler instruction generation. So code is not optimized. It has been checked in the trial PRO mode.
workaround: use UNION bits with a char. Then this char (bits) are placed on the same main BANK (if still space is present). So this avoid unnecessary "buggy" BANK SWITCHING..... so you use less power...power optimized application.
2) condition: if you use just 1 BANK....without bank switching.....the following sequence
WAIT_VREG: NOP(); if(nDONE) goto WAIT_VREG;
become in generated ASM:
181 126 l508: 182 183 ;main.c: 195: __nop(); 184 126 000 nop 185 186 ;main.c: 196: if(nDONE) goto WAIT_VREG; 187 127 4A4 bcf 4,5 ;FSR5=0, select bank0 188 128 628 btfsc 8,1 ;volatile 189 129 B26 goto l508
the BOLD instruction is silly added by the compiler.....and it is generated by using the NOP(); instruction.
workaround:
generate a BIT var,
WAIT_TEMP: BITS.BITs.DUMMY=0; if(nDONE) goto WAIT_TEMP;
181 128 l506: 182 183 ;main.c: 197: BITS.BITs.DUMMY=0; 184 128 452 bcf _BITS,2 185 186 ;main.c: 198: if(nDONE) goto WAIT_VREG; 187 129 628 btfsc 8,1 ;volatile 188 12A B28 goto l506
now it's optimized!
3) xc8 TERRIBLE GENERATED CODE 1 MORE INSTRUCTION USED. 196 ;main.c: 205: Mean=(TMR0&0x07); 197 12F 201 movf 1,w ;volatile 198 130 038 movwf _Mean 199 131 C07 movlw 7 200 132 178 andwf _Mean,f
RIGHT OPTIMIZED GENERATED CODE :
82 ;main.c: 190: Mean=(TMR0&0x07); 83 134 201 movf 1,w ;volatile 84 135 E07 andlw 7 85 136 034 movwf _Mean
what a terrible compiler.....i PERSONALLY STOP COMPARING....IN A SOURCE I COMPILED THERE ARE SO MANY ISSUES ABOUT OPTIMIZZATION.....
how many further work around should have to find to such optimization issue?
for this reason i prefer always to write my own asm.
manuel.
« Last Edit: July 12, 2015, 07:53:36 07:53 by Manuel »
flo0319
« Reply #114 on: July 11, 2015, 04:45:28 16:45 » |
Hi manuel, can you please to tell me which xc8 version have you used for those examples? and also if you are using in optimization the option +space. Thanks
Manuel
-Given: 786
-Receive: 205
« Reply #115 on: July 12, 2015, 07:36:40 07:36 » |
The "issue" is present on both 1.33 and 1.34 compilers.
The second compiler used for comparing....is not important...since the evidence is logically clear, the compiler leak in his management. and it's quite strange from my point of view. Strange is the fact that the compiler developer did not see such silly problems....or better did not tight the proper solutions ....
+space was not used.
Anyhow....just to complete the question, TWO more "ISSUEs"...that make me decide to avoid using XC8, and go on with ASM coding...
all vars are UNSIGNED CHAR ! apart for IO_IMAGE....that is a UNION bit.
XC8 "ISSUE" 1:
520 ;main.c: 377: if(DB == IntCount) IO_IMAGE.PIN.PIN_B =0; 521 1DA 217 movf _IntCount,w 522 1DB 02F movwf 15 523 1DC 193 xorwf _DB,w 524 1DD 643 btfsc 3,2 525 1DE 4B6 bcf _IO_IMAGE,5 526 527 ;main.c: 378: if(DG == IntCount) IO_IMAGE.PIN.PIN_G=0; 528 1DF 217 movf _IntCount,w 529 1E0 02F movwf 15 530 1E1 194 xorwf _DG,w 531 1E2 643 btfsc 3,2 532 1E3 436 bcf _IO_IMAGE,1 533 534 ;main.c: 379: if(DR == IntCount) IO_IMAGE.PIN.PIN_R =0; 535 1E4 217 movf _IntCount,w 536 1E5 02F movwf 15 537 1E6 195 xorwf _DR,w 538 1E7 643 btfsc 3,2 539 1E8 496 bcf _IO_IMAGE,4
15 instructions.
Right Compiling instead:
;main.c: 361: if(DB == IntCount) IO_IMAGE.PIN.PIN_B =0; 339 ;main.c: 361: { 340 1DD 20E movf _DB,w 341 1DE 192 xorwf _IntCount,w 342 1DF 643 btfsc 3,2 343 1E0 4B1 bcf _IO_IMAGE,5 344 ;main.c: 363: if(DG == IntCount) IO_IMAGE.PIN.PIN_G=0; 345 1E1 20F movf _DG,w 346 1E2 192 xorwf _IntCount,w 347 1E3 643 btfsc 3,2 348 1E4 431 bcf _IO_IMAGE,1 349 ;main.c: 364: if(DR == IntCount) IO_IMAGE.PIN.PIN_R =0; 350 1E5 210 movf _DR,w 351 1E6 192 xorwf _IntCount,w 352 1E7 643 btfsc 3,2 353 1E8 491 bcf _IO_IMAGE,4
12 instructions.
It maybe seems silly 12 vs 15 is really important in optimizzation....
XC8 "ISSUE" 2: 520 ;main.c: 377: if((DB - IntCount)==0) IO_IMAGE.PIN.PIN_B =0; 521 1D2 213 movf _DB,w 522 1D3 02A movwf 10 523 1D4 06B clrf 11 524 1D5 20B movf 11,w 525 1D6 02F movwf 15 526 1D7 217 movf _IntCount,w 527 1D8 08A subwf 10,w 528 1D9 02E movwf 14 529 1DA 703 skipc 530 1DB 0EF decf 15,f 531 1DC 10F iorwf 15,w 532 1DD 643 btfsc 3,2 533 1DE 4B6 bcf _IO_IMAGE,5
Can it be possible no one have ever seen this? I can not believe !!!! essentially a ZERO compare con unsigned bytes can not be converted in a real MATH sequence!!
hope more real improvement will be done on this compiler and not just adding processors....
Now the questions are: - does XC8 compile same way for XLP processors? if so, why such effort to add XLP family processors if compiler then does not respect the investments done to realize XLP? (terrible) -who produce a real optimized compiler for the MICROCHIP family processors? -does both XC16 and XC32 have been developed with same core?
manuel.
« Last Edit: July 12, 2015, 08:42:46 08:42 by Manuel »
flo0319
« Reply #116 on: July 12, 2015, 12:27:29 12:27 » |
Hi again and many thanks for all those examples, will be very nice for me if you can add the c code for the last 2 issues (more interesting will be how they are declared ). I am very interested in this compiler optimization problems and I have seen similar problems. I do not understand why it save the previous value of IntCount, are you use a re-entrant model? for which controller are you build this code? Thanks a lot!
Manuel
-Given: 786
-Receive: 205
« Reply #117 on: July 12, 2015, 02:40:59 14:40 » |
Mchp Man!
Anyhow, NO REENTRANT.
some declares to workaround compiler ISSUES discussed:
pack in BANK0 if there is space....otherwise if vars declared as BITS goes on BANK1
typedef union { struct { unsigned DID : 1; unsigned GOT_FIRST_T : 1; unsigned DUMMY : 1; unsigned : 5;
} BITs; unsigned char BITS_ALL; } BITS_VAL;
As requested:
unsigned char DB; unsigned char DG; unsigned char DB; unsigned char IntCount;
STRANGE MANAGEMENT see the following with XC8 1.33 and 1.34 for two different COMPAREs:
554 ;main.c: 385: if(DB != 63) IO_IMAGE.PIN.PIN_B =1; 555 1ED C3F movlw 63 556 1EE 193 xorwf _DB,w 557 1EF 743 btfss 3,2 558 1F0 5B6 bsf _IO_IMAGE,5
if you compare to the following you will notice one time not optimed...one time correct....a ZERO compare and a non zero value compare....
I also checked just for my personal interest many other interesting ISSUES....and till XC8 is not as I would like it could be....I will only go on writing my own ASM.
Anyhow, PIC12F5xx checked....but same issues apply to many other target processor.
Hope can help someone to decide direction when deciding to do investments...fortunately the trial exhist.
manuel.
Manuel
-Given: 786
-Receive: 205
« Reply #119 on: July 13, 2015, 08:11:05 08:11 » |
No, as time limited PRO mode.
I checked even FREE mode in advance just to compare both results...and FREE is FREE and PRO is PRO, but the PRO mode does not satisfy obvious optimizations. This is the question. And consider that it should be so easy to adjust the PRO mode to be really efficient.... I do not understand why noone ever considered or discussed really those questions in deep detail. I would have expected XC8, since the development stared many years ago deriving from HI-TECH compiler, could be more efficient, cosidering even that the old HI-TECH itself is more efficient in general for the supported processors....
Manuel.
Manuel
-Given: 786
-Receive: 205
« Reply #120 on: July 17, 2015, 07:07:42 19:07 » |
Got the question about unoptimized compiler...
At a certain point developers decided to use a resister variable located in BANK0 (I saw) as temporary storage in place of the W register.. This is suitable for processors where INT have to be managed in a "certain way"...but for code where no interrupt are used..this management is a BAD way to get optimized code...
This is mainly the question I think.
Related to BIT question.... an ODD BANKING is present starting from 9.60PL4. Anyhow you have the wayout explained previously.
Hope this can help for further development including compiler developer too.
I know not all is easy to be done but at least managing exceptions can help many developers i think.....so I go on with ASM.
take care, Manuel.
« Last Edit: July 18, 2015, 10:39:07 10:39 by Manuel »
Manuel
-Given: 786
-Receive: 205
« Reply #121 on: September 17, 2015, 12:21:42 12:21 » |
UPDATED: XC8 Compiler Part-Support Patch v1.35B
manuel.
Catcatcat
-Given: 316
-Receive: 1879
« Reply #122 on: January 28, 2016, 03:52:03 15:52 » |
nagkiller
-Given: 181
-Receive: 49
« Reply #123 on: January 30, 2016, 02:31:17 14:31 » |
Where is medicine???
(\ /) ( . .) c(")(") This is Bunny. Copy and paste Bunny into your signature to help him gain world domination.
Thiru09
-Given: 411
-Receive: 1188
« Reply #124 on: January 30, 2016, 03:21:00 15:21 » |
