November 28, 2024, 10:38:18 10:38
Author Topic: Help with understanding this circuit  (Read 4723 times)
pjmelect
 Warned
« on: June 20, 2012, 09:10:20 09:10 »
http://xkcd.com/730/
« Reply #1 on: June 20, 2012, 11:01:10 11:01 »
There's an error in the circuit.
The most expensive chip available should be wired across the 500V AC supply
-Given: 834
-Receive: 4322
« Reply #2 on: June 20, 2012, 11:44:48 11:44 »
Repeat post x 3
-Given: 496
« Reply #3 on: June 21, 2012, 12:01:20 00:01 »
So there is where my jock strap went..
You thief..
pirvcb
-Given: 147
-Receive: 245
« Reply #4 on: June 21, 2012, 03:27:35 03:27 »
Can it make coffee?
-Given: 554
« Reply #5 on: June 21, 2012, 04:32:43 04:32 »
Change the magic smoke to laughing gas then it will work if not then replace the sad face with happy face that will definitely do the trick
CocaCola
-Given: 169
« Reply #6 on: June 21, 2012, 05:45:09 17:45 »
I love that they used an Arduino for Blog Cred. Smiley
txjammer
« Reply #7 on: June 27, 2012, 11:15:16 23:15 »
So its a map!
optikon
-Given: 1106
-Receive: 2007
« Reply #8 on: June 28, 2012, 02:29:40 02:29 »
Pin 5 of the 666 timer needs to go to the holy water ground. Duh.
